Audi a3 2016 P00B7
maxium
Las Vegas, USA
C?ID=332130
insufficient coolant flow
Saturday,18,January,2020,16:37:27:18491
VIN: WAUA7GFF8G1062994   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F 6C BB BC
VIN: WAUA7GFF8G1062994   Mileage: 89978km-55909miles
Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A1D00122424000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3FDBBE0E27F93F4FF0D-806A
15470 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [036] - -
                    Mileage: 89978 km
                    Date: 2020.01.18
                    Time: 16:14:34
                    Engine speed: 704.50 /min
                    Normed load value: 22.7 %
                    Coolant temperature: 107 °C
                    Intake air temperature: 48 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 14.082 V
                    Engine: operating status: IS
                    Engine temp. management actuator: raw value: 249
                    Engine temperature management actuator: stop open: 135
                    Engine temperature management actuator: after-run stop: 3956
                    RVC_SP: 4.00 °
                    RVC_AV: 7.61 °
                    RVCPWM: 26.306 %
16986 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [096] - -
                    Mileage: 89859 km
                    Date: 2020.01.16
                    Time: 22:41:38
                    Engine speed: 950.25 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 56 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 14.003 V
                    Engine temp. management actuator: raw value: 2136
                    Engine temperature management actuator: stop open: 145
                    Engine temperature management actuator: after-run stop: 3948
                    RVC_SP: 129.25 °
                    RVC_AV: 133.48 °
                    RVCPWM: 28.870 %
16987 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [032] - -
                    Mileage: 89858 km
                    Date: 2020.01.16
                    Time: 18:13:19
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 105 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 12.714 V
                    Unlearning counter according OBD: 37
                    Engine: operating status: ES
                    Engine temp. management actuator: raw value: 3563
                    RVC_SP: 233.50 °
                    RVC_AV: 229.17 °
                    RVCPWM: -28.900 %
Readiness: 0000 0100
   Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4907
   Revision: 06253104    Serial number: TFK01510272167
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 196F3096991D317F2E9-804C
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63075000000066
   Coding: 13FF6A9234260A6E0180020981C729C8562C5080408194B4024100548208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 79AF1016795DD17F8E9-802C
   Revision: 00021000    Serial number: 0386846065
   Coding: 030C0C
   VCID: 3A2DCF1A3CDB1A67C73-806E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000791174
   Coding: 03000014010000000000000000001400
   VCID: 323DE73AE4ABE2270F3-8066
   Serial number: 5248C9D7000000000001
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061530700821
   Coding: 04151A42C04122F541C04004511007000800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7F5BFE0E6779FF4FB0D-802A
   Component: WWS371 150808  042 0585
   Serial number:         151102185255
   Coding: 0A47F7
   Serial number: 60930759
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 07 09 2015  00000897
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064307183
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000NEEVA00000
   Coding: 101F00
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 252
                    Mileage: 89899 km
                    Date: 2020.01.17
                    Time: 12:28:55
   Revision: --------    Serial number: 39391531520154
   Coding: 0010150011
   VCID: 43D3B2FE4B115BAF945-8016
   Serial number: 003GCR03YLC%
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CBA6EE7F29778F48D-8012
   Belt Pretensioner left:
   Serial number: 34230167A13111551025
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A13111541210
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001ENJXN
   Coding: 303332
   Subsystem 4 - Part No SW: -----------    HW: 480 003 010 15
   Serial number: 35700000000809E4671L
   Subsystem 5 - Part No SW: -----------    HW: 480 003 010 15
   Serial number: 35800000000749E4671P
   Subsystem 6 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3510002C51D73C64412
   Subsystem 7 - Part No SW: -----------    HW: 480 400 911 15
   Serial number: 3520002A11DBD62241C2
   Subsystem 8 - Part No SW: -----------    HW: 480 401 708 15
   Serial number: 3550002A31CB0C0622D1
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 708 15
   Serial number: 3560002A31CB0C03335-
   Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 12111508490351
   Coding: A018
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 05576CE605A5A59FFA1-8050
   Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
   Component: KOMBI         H03 6423
   Coding: 0BE419192B80D7050200A8001800000000000000
   VCID: 45D7ACE64525659FBA1-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 08111510803777
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 06 11 2015  C0015703
   Revision: 00000000    Serial number: 15000244876007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E1221EBFEC171DF-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 031015BJ216644
   Coding: 00101B204000048000000002
   VCID: 41DFB8F6510D49BF869-8014
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0102
   VCID: 44D1B1E24E1F5C97ADF-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 300815BHT08779
   Coding: 001013204000048000000002
   VCID: 40D9BDF25A0740B7897-8014
   Coding: 011A000101000000
   VCID: 75B71C265545B51FEA1-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     014 0660
   Serial number: A7A01211151261
   Coding: 01730100FF0A000011220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 392FD01639DD117FCE9-806C
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30EBL2
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000026091500030025
          B11CF 53 [009] - Deactivated
                    Reset counter: 248
                    Mileage: 89845 km
                    Date: 2020.01.12
                    Time: 12:52:19
                    Voltage terminal 30: 14.2 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 3039ED32EAA7D037797-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 151015BJE1256B
   Coding: 000013204000048000000002
   Serial number: 151015BJE12574
End----------(Elapsed Time: 01:33, VBatt start/end: 12.2V/12.3V)-----------
maxium
Las Vegas, USA
C?ID=332130
No mil light.
I think the recall on water pump is only Audi A4. Audi co. Warranty only 50000 k miles or 4 years.
Thank you very much, for helping me
Mc
NostraJackAss
No mil light.
Mc
Did you know your car has much more warranty than you think, were you told otherwise?
Did you JPPSG yet?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Well if there is no MIL what's the reason to be concerned, unless of course you are worried about your engine or burning down a nice piece of property you reside your vehicle in or attach your bed too go to sleep at night?
What kind of a pillow do you use and does it block your ears on sides to muffle noise for a smoke detector, you do have a smoke detector right?
Is the coolant pump in this engine, the same part number & design type?
Was that pump also superseded to the same part number as a replacement in both the 1.8 & 2.0 engines, early type Bosch, late type Pierburg?
Was it the pump used in the recalled vehicles the same & was software already updated, you know like the other cars that caught fire shortly afterward or when the codes were dismissed in a similar fashion?
https://static.nhtsa.gov/odi/rcl/2018/RIONL-18V229-5195.pdf
https://www.carcomplaints.com/news/2018/audi-coolant-pump-class-action-lawsuit.shtml
All important questions no?
8V0 906 264 F 0003
Hey did you know another software update exists?
Hey according to Audi your car has this below as disseminated by them publicly, did you know that?
https://literature.vw.com/calibration_lookup.asp
ECM 8V0906264F 0004 AXAJ 890EA948 GVGAV02.0APA
Huh I wonder what the conformity application says?
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=43249&flag=1
Vehicle Identification No.WAUA7GFF8G1062994
ModelAudi A3 limousine 1.8
A3
Date of production26.11.2015
Model year2016
Sales type8VS57X
Engine CodeCNSB
Transmission CodeQYZ
Emission standard0GTEmission standard SULEV
Section 21 Pg. 7 Other Information Engine Code R.CH-No.: Revision Date Test Group GADXV02.0APA all 12-13-2016
Engine Control Module (ECM) Information 1.8T
Model Engine Code Software ID CVN CAL ID
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0001 EDFAED27 8V0264D 0001 AXAJ
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0002 C88FD0EA 8V0264D 0002 AXAJ
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0003 20791AD7 8V0264D 0003 AXAJ
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0004 EB8B8B0B 8V0264D 0004 AXAJ
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0001 A6F22067 8V0264F 0001 AXAJ
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0002 33442DB8 8V0264F 0002 AXAJ
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0003 C7D2465C 8V0264F 0003 AXAJ
Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0004 890EA948 8V0264F 0004 AXAJ
I just love asking questions don't you?
maxium
Las Vegas, USA
C?ID=332130
Thanks for help me
My car running about 30 minutes and over heat no acceleration.
Thank again I'll check with Audi about recall
NostraJackAss
Thanks for help me
Did I say there was a recall or did I ask if it was under recall or possible warranty?
Please post the requested scan data & do you have an MIL now, that like you said, could you do that please?
tclark18
C?ID=371550
NostraJackAss
Yeah that thread was a bunch of fun questions too & that brought relevant answers to light, huh?
:rolleyes:
Are not all these engines the same crap with a different shovel of EA888 fun?
