Car wont start after changing clutch, immobilizer key lost com, any help please
Shuhel
Birmingham, UK
C?ID=368132
helo all, my colleague changed the clutch on this vehicle, and the car starts for only about 2 seconds cuts off.
on the dash it says ''SAFE''
cleared all codes, comes back with same on immo
anyone come across this before?
any thought please, thanks again
 Saturday,18,January,2020,16:38:59:58999
VIN: VSSZZZ5PZ9R010587   License Plate:
Mileage: 279310km-173555mi   Repair Order:
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ5PZ9R010587   Mileage: 279310km-173555miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 SK    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  1444
   Revision: --H08---    Serial number: SEX7Z0H631M0EF
   Coding: 0050071
   Shop #: WSC 06402 785 00200
   VCID: 7AADF37370D13EA7873-802E
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - MIL ON
                    Fault Status: 11110000
                    Mileage: 279315 km
                    Time: 00:03:05
                    RPM: 1071 /min
                    Load: 0.0 %
                    Voltage: 12.84 V
                    Bin. Bits: 00001100
                    Bin. Bits: 11000000
                    Bin. Bits: 00100001
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 279315 km
                    Time: 00:00:48
                    Load: 0.0 %
                    Voltage: 12.31 V
                    Bin. Bits: 00001100
                    Temperature: 20.7°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 279315 km
                    Time: 00:00:48
                    Load: 0.0 %
                    Voltage: 12.31 V
                    Bin. Bits: 00001100
                    Temperature: 20.7°C
                    Bin. Bits: 00110000
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0016641
   VCID: 76B5E74344C95AC7E3B-8022
   Part No: 5P0 907 044 K
   Component: ClimatronicPQ35 011 0702
   VCID: 3829297B0E5DECB7317-806C
   Revision: 00H54000    Serial number: 00000005852089
   Coding: E1880F2F00041000431800000000000000007F075C400000000000000000
   Shop #: WSC 00137 211 56823
   VCID: 33331E57173B0FEF045-8066
   Subsystem 1 - Part No: 5P0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 160608 022  0601
   Coding: 00056208
   Shop #: WSC 00137
   Subsystem 2 - Part No: 1P0 955 559   Labels: 1P0-955-559.CLB
   Component: REGENLICHTSENSORH04 0090
   Coding: 00152622
   Shop #: WSC 00137
                    Fault Status: 01101100
                    Reset counter: 98
                    Mileage: 279315 km
                    Voltage: 12.40 V
                    Reset counter: 98
                    Mileage: 279315 km
                    Voltage: 12.40 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 E    HW: 1K0 919 475 E
   Component: PARKHILFE     005 1406
   Revision: 00005000    Serial number: 0 263 004 292
   Shop #: WSC 04941 000 00000
   VCID: 34311D4B1E3508D71DF-8060
   Component: S9 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD248KGD
   Coding: 0021305
   VCID: 3D27386F217FC99FE21-8068
   Subsystem 1 - Serial number: 6332MSME290475389
   Subsystem 2 - Serial number: 6342MSME2B560C22C
   Subsystem 3 - Serial number: 6351HSME174957718
   Subsystem 4 - Serial number: 6361HSME173E33548
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           752 0101
   Coding: 0002042
   VCID: 04518D8B02157857EDF-8050
   Component: E0221           001 0010
01426 - Controls in Steering Wheel (E221)
   Part No: 5P0 920 927 B
   Component: KOMBIINSTRUMENT VO3 0450
   Coding: 0002401
   Shop #: WSC 00011 067 57207
   VCID: 34311D4B123508D71DF-8060
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K0860482D3
   Coding: E9A07F060002022203
   VCID: 3537204F194F11DF2A1-8060
   Component: IMMO            VO3 0450
01176 - Key
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1520
   Revision: 71009005    Serial number: 00000364288508
   Coding: 0004784
   VCID: 40D9419B568DA477897-8014
                    Fault Status: 01100101
                    Reset counter: 98
                    Mileage: 279315 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 77     2301
   Revision: 00H15000
   VCID: 2A0D0333C0F14E27B73-807E
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.4 V
                        PD
                    Temperature: 9.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 988000005183CC7F0006850560085F86107C80
   VCID: 03538E97071B7F6FD45-8056
   Subsystem 5 - Part No: 5P0 951 171 C
   Component: Innenraumueberw.009 4865
   Coding: 00000000
   Shop #: WSC 06402
   Subsystem 7 - Component:       NGS n.mounted
                    Reset counter: 138
                    Mileage: 279315 km
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1520
   Revision: 71009005    Serial number: 00000563688513
   Coding: 0004784
   VCID: 41DF449F5D87AD7F869-8014
                    Reset counter: 98
                    Mileage: 279315 km
                    Fault Status: 00101100
                    Reset counter: 138
                    Mileage: 279315 km
   Part No: 5P2 035 186 A
   Component: Radio BVX           0007
   Coding: 0040464
   VCID: 2F3B1227FB132B0F60D-807A
No Faults Found
   Part No SW: 1K0 959 703 AE    HW: 1K0 959 795 R
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003248988
   Coding: 0000144
   VCID: 73B3DE5757BB4FEFC45-8026
   Part No SW: 1K0 959 704 AE    HW: 1K0 959 794 R
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003305626
   Coding: 0000144
   VCID: 74B1DD4B52B548D7DDF-8020
End----(Elapsed Time: 01:30, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
Did you check key is proper and D2 coil excites transponder to be seen in Immobilizer measured blocks in VCDS?
Fuses all good?
JPPSG
01176 - Key
I don't understand how a clutch job could have caused this, but I've seen stranger coincidences.
http://wiki.ross-tech.com/wiki/index.php/01176
Shuhel
Birmingham, UK
C?ID=368132
Now sorted
I read on a forum maybe here, hold positive and negative battery term together for 30secs and then connect battery, leave jump leads on for 5mins with ignition on if the batterys weak.
Car started, all working fine now.
I still dont get why it happened in the first place
Thanks guys
Now sorted
Nice. That's not the first time we've heard of a procedure we irreverently refer to as a "BJ" (short for "Battery Jesus") has exorcised immobilizer problems that came out of nowhere.
Did you leave the battery connected while trying to take a trans out and removing the chassis ground or half the hots or short it on body?
Ever notice how a loud fart for odor may go unnoticed but a small one could insult yourself or even the family dog?
siLc
Tallinn, Estonia
C?ID=330192
On a VW PQ platform vehicle, removing the battery is pretty much inevitable when the trans has to come out - the battery tray is sitting on the trans side mount.
