- Jun 13, 2019
- 42
- 20
- Birmingham, UK
- C?ID=368132
helo all, my colleague changed the clutch on this vehicle, and the car starts for only about 2 seconds cuts off.
on the dash it says ''SAFE''
cleared all codes, comes back with same on immo
anyone come across this before?
any thought please, thanks again
Saturday,18,January,2020,16:38:59:58999
VIN: VSSZZZ5PZ9R010587 License Plate:
Mileage: 279310km-173555mi Repair Order:
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ5PZ9R010587 Mileage: 279310km-173555miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 SK HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1444
Revision: --H08--- Serial number: SEX7Z0H631M0EF
Coding: 0050071
Shop #: WSC 06402 785 00200
VCID: 7AADF37370D13EA7873-802E
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - MIL ON
Fault Status: 11110000
Mileage: 279315 km
Time: 00:03:05
RPM: 1071 /min
Voltage: 12.84 V
Bin. Bits: 00001100
Bin. Bits: 11000000
Bin. Bits: 00100001
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Mileage: 279315 km
Time: 00:00:48
Voltage: 12.31 V
Bin. Bits: 00001100
Temperature: 20.7°C
Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Mileage: 279315 km
Time: 00:00:48
Voltage: 12.31 V
Bin. Bits: 00001100
Temperature: 20.7°C
Bin. Bits: 00110000
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0016641
VCID: 76B5E74344C95AC7E3B-8022
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 K
Component: ClimatronicPQ35 011 0702
VCID: 3829297B0E5DECB7317-806C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000005852089
Coding: E1880F2F00041000431800000000000000007F075C400000000000000000
Shop #: WSC 00137 211 56823
VCID: 33331E57173B0FEF045-8066
Subsystem 1 - Part No: 5P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 160608 022 0601
Coding: 00056208
Shop #: WSC 00137
Subsystem 2 - Part No: 1P0 955 559 Labels: 1P0-955-559.CLB
Component: REGENLICHTSENSORH04 0090
Coding: 00152622
Shop #: WSC 00137
Fault Status: 01101100
Reset counter: 98
Mileage: 279315 km
Voltage: 12.40 V
Reset counter: 98
Mileage: 279315 km
Voltage: 12.40 V
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 E HW: 1K0 919 475 E
Component: PARKHILFE 005 1406
Revision: 00005000 Serial number: 0 263 004 292
Shop #: WSC 04941 000 00000
VCID: 34311D4B1E3508D71DF-8060
Component: S9 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD248KGD
Coding: 0021305
VCID: 3D27386F217FC99FE21-8068
Subsystem 1 - Serial number: 6332MSME290475389
Subsystem 2 - Serial number: 6342MSME2B560C22C
Subsystem 3 - Serial number: 6351HSME174957718
Subsystem 4 - Serial number: 6361HSME173E33548
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 752 0101
Coding: 0002042
VCID: 04518D8B02157857EDF-8050
Component: E0221 001 0010
01426 - Controls in Steering Wheel (E221)
Part No: 5P0 920 927 B
Component: KOMBIINSTRUMENT VO3 0450
Coding: 0002401
Shop #: WSC 00011 067 57207
VCID: 34311D4B123508D71DF-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0860482D3
Coding: E9A07F060002022203
VCID: 3537204F194F11DF2A1-8060
Component: IMMO VO3 0450
01176 - Key
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1520
Revision: 71009005 Serial number: 00000364288508
Coding: 0004784
VCID: 40D9419B568DA477897-8014
Fault Status: 01100101
Reset counter: 98
Mileage: 279315 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 77 2301
Revision: 00H15000
VCID: 2A0D0333C0F14E27B73-807E
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.4 V
PD
Temperature: 9.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005183CC7F0006850560085F86107C80
VCID: 03538E97071B7F6FD45-8056
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 06402
Subsystem 6 - Part No: 1K0 951 605 C
Subsystem 7 - Component: NGS n.mounted
Reset counter: 138
Mileage: 279315 km
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1520
Revision: 71009005 Serial number: 00000563688513
Coding: 0004784
VCID: 41DF449F5D87AD7F869-8014
Reset counter: 98
Mileage: 279315 km
Fault Status: 00101100
Reset counter: 138
Mileage: 279315 km
Part No: 5P2 035 186 A
Component: Radio BVX 0007
Coding: 0040464
VCID: 2F3B1227FB132B0F60D-807A
No Faults Found
Part No SW: 1K0 959 703 AE HW: 1K0 959 795 R
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003248988
Coding: 0000144
VCID: 73B3DE5757BB4FEFC45-8026
Part No SW: 1K0 959 704 AE HW: 1K0 959 794 R
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003305626
Coding: 0000144
VCID: 74B1DD4B52B548D7DDF-8020
End----(Elapsed Time: 01:30, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
