- Jun 13, 2019
- 42
- 20
- Birmingham, UK
- C?ID=368132
hi guys, iv been on this car for 3 months now and cant seem to find a solution to it.
the car is driving in limp with no power, iv changed the fuel pressure sensor and clear codes, it comes back with the same code on engine.
any thoughts please
thanks
any thoughts please
thanks
Saturday,18,January,2020,18:25:05:58999
VIN: VSSZZZ1PZCR061000 License Plate:
Mileage: 207060km-128661mi Repair Order:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 72
VIN: VSSZZZ1PZCR061000 Mileage: 207060km-128661miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LG HW: 03L 906 023 KL
Component: 1,6l R4 CR td H43 8832
Revision: --H43--- Serial number:
Coding: 00114036032501080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023LG 003005
ROD: GV_ECM16TDI021PQ36_003_SK34.rod
VCID: 76B5E74348495AC7E3B-8022
10131 - Fuel Pressure Sensor (G247)
P0193 00 [165] - Short to Plus
Mileage: 208030 km
Date: 2020.01.18
Time: 01:36:28
Engine speed: 763.25 /min
Normed load value: 34.1 %
Coolant temperature: 70 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.682 V
Supply voltage of analog output 1-VCC_1: 5.00 V
Fuel high pressure sensor: unconditioned voltage-VP_PFU: 4.9936 V
Fuel pressure: 200000 kPa rel
Fuel high pressure: actual value-FUP_FIL: 199.997 MPa
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 0.000 kPa
ECM system status-Binary 16 Bit: 00000000 00000000
Readiness: 0110 1000
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 133B2012092800FBC80B04E490190091350800
Shop #: WSC 04941 000 00000
VCID: 7BA3F67773EB07AF9C5-802E
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 189
Mileage: 207057 km
Date: 2014.06.07
Time: 00:35:37
Count: 3
Count: 2
Count: 12800
Count: 397
Count: 53248
Part No SW: 5P0 907 044 R HW: 5P0 907 044 R
Component: Climatronic H18 0804
Revision: 00001001
Coding: 0000000003
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3FDB426727F3DB8FF0D-806A
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0064
Revision: BC021001
Coding: 46180A3E8025B0C04288008095008104425100A8427D81605C80C7000041
VCID: 3E253F632079D287FBB-806A
Subsystem 1 - Part No: 1P0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 12031 26 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Reset counter: 190
Mileage: 207057 km
Date: 2014.06.07
Time: 00:35:48
Voltage: 14.85 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 8P0 919 475 M
Component: PARKHILFE 4K H08 0008
Revision: -------- Serial number: 36861205603656
VCID: 3A2D33733C51FEA7C73-806E
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__A0E VW10 HI 2118
Revision: 24017000 Serial number: 003L7P2Q3YF7
Coding: 0012357
VCID: 7CA1F56B7AE5009795F-8028
Subsystem 1 - Serial number: 6332MTS603760442
Subsystem 2 - Serial number: 00000000000000000
Subsystem 3 - Serial number: 6351HTS653LJ0AKR
Subsystem 4 - Serial number: 6361HTS6914K0AKR
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
007 - Short to Ground - MIL ON
Fault Status: 11100111
Mileage: 207057 km
Date: 2014.06.07
Time: 00:35:51
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20120315200846
Coding: 108A140002
ROD: EV_SMLSNGVOLWS.rod
VCID: 79AFEC7F795735BF8E9-802C
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: E20000
Part No SW: 1P0 920 953 D HW: 1P0 920 953 D
Component: KOMBI H05 0607
Coding: 410B01
VCID: 313F145FE1A73DFF769-8064
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 270212F2000199
Coding: 350203
VCID: 3B233677336BC7AFDC5-806E
Component: IMMO H05 0607
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC3330CF18E27773-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662065057
VCID: 290FFC3FC9F7453FBE9-807C
Part No SW: 5P0 035 191 G HW: 5P0 035 191 G
Component: RNS315-EU H36 0263
Serial number: SEZAZ2M9168011
Coding: 040004010402000000000002
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 2F3B1227F7932B0F60D-807A
Component: EUR_W_0038 0038
1048629 - Aux IN Socket
B1104 13 [008] - Open Circuit
Reset counter: 230
Mileage: 207057 km
Date: 2020.01.15
Time: 00:22:07
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0508
Revision: 12110009 Serial number: 0004058472
Coding: 0212B0
VCID: 6D87C82F3D1F991F121-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 E HW: 3C0 959 794 E Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1501
Serial number: 00000006525934
Coding: 000290
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 230
Mileage: 207057 km
Date: 2020.01.15
Time: 00:35:56
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 65 3305
Revision: 00H22000
VCID: 372B2A470343E3CF38D-8062
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000550478217
Coding: 0000688
Shop #: WSC 04941 785 00200
VCID: 3C21356B3A65C097D5F-8068
Fault Status: 00100101
Reset counter: 230
Mileage: 207057 km
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: 030F185A
VCID: 71BFD45F21A77DFF369-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900311923
End----(Elapsed Time: 01:23, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
