VCDS Help
Hbuk24
Spain
C?ID=306940
have been trying to activate high beam assist today and traffic signs. In doing so I have unfortunately created an error saying “Audi adaptive light fault - see owners manual.
I have changed back all the settings that I can remember but am really stuck, can anyone help?
I have an Audi TT 8S 2015 2.0 TFSI, as far as I’m aware I do not have cornering lights.
Thanks in advanced.
Moving to New User Forum from General VW/Audi Repair.
Please post an Auto-Scan so people can see how your car is equipped and configured.
Hbuk24
Spain
C?ID=306940
Friday,17,January,2020,21:43:09:30289
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: TRUZZZFV3F1009952   License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
VIN: TRUZZZFV3F1009952   Mileage: 94444km-58684miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
  Part No SW: 8S0 906 259     HW: 06K 907 425 B
  Component: 2.0l R4 TFSI  H13 0004
  Revision: --H13---
  Coding: 0A1900322424050B3002
  Shop #: WSC 06385 790 00016
  ASAM Dataset: EV_ECM20TFS0208S0906259 001005
  ROD: EV_ECM20TFS0208S0906259.rod
  VCID: 7AAEFB5F1C583CC7873-802F
16452 - Implausible Data Received from ESP Control Module
         U0416 00 [032] - -
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 11:18:47
                   Engine speed: 0.00 /min
                   Coolant temperature: 77 °C
                   Intake air temperature: 52 °C
                   Voltage terminal 30: 14.296 V
                   Unlearning counter according OBD: 32
                   PV: 0.00 %
                   Engine: operating status: ES
                   T_IGK: 2.90 s
                   Drivetrain coordinator: brake fault status-ESP system error: No
17178 - Databus
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 11:18:45
                   Intake air temperature: 51 °C
                   Voltage terminal 30: 14.257 V
                   Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                   Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                   Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                   Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                   Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                   Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                   Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                   Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                   Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                   Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
21322 - Implausible Data Received from ABS Control Module
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   Engine speed: 3028.75 /min
                   Normed load value: 22.4 %
                   Vehicle speed: 53 km/h
                   Coolant temperature: 82 °C
                   Intake air temperature: 42 °C
                   Voltage terminal 30: 12.792 V
                   Engine: operating status: PL
                   ECU_STATE: SYN_ENG_IGK_ON
                   Engine oil temperature: 75.0 °C
                   Time since engine start: 71.6 s
                   T_ES: 0 min
                   Cruise control switch actuation-Main switch: not activated
                   Cruise control switch actuation-Setting: not activated
                   Cruise control switch actuation-Activation: not activated
                   Cruise control switch actuation-Accelerate: not activated
                   Cruise control switch actuation-Decelerate: not activated
                   Cruise control switch actuation-Cancel: not activated
                   Cruise control switch actuation-Main switch hardware: operated
                   Cruise control switch actuation-Limit button: not activated
                   Cruise control switch actuation-Main switch CAN: operated
                   Cruise control switch actuation-Large increment: not activated
                   STATE_ERR_ABC_PRED: 0
21323 - Implausible Data Received from ABS Control Module
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   T_ES: 0 min
23130 - Implausible Data Received from ABS Control Module
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   Engine speed: 3002.00 /min
                   Voltage terminal 30: 12.578 V
                   T_ES: 0 min
23131 - Implausible Data Received from ABS Control Module
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   T_ES: 0 min
Readiness: 0010 0001
  Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
  Component: ESC           H31 0504
  Revision: 00000000    Serial number: 63474000000378
  Coding: 32AA108D1A9915B2409A0069C2939306444C0858A8020043C96022
  ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
  ROD: EV_Brake1UDSContiMK100IPB_052.rod
  VCID: 40DA49B73A04A617897-8015
18 Faults Found:
0070 - Rear Left Wheel Speed Sensor
         C101C 29 [008] - Signal Implausible
                   Reset counter: 193
                   Mileage: 92354 km
                   Date: 2020.01.14
                   Time: 11:41:46
0075 - Rear Left Wheel Speed Sensor
         C101C 07 [008] - Mechanical Failure
                   Reset counter: 193
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
0091 - Rear Right Wheel Speed Sensor
         C101D 07 [008] - Mechanical Failure
                   Reset counter: 193
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
8246 - Databus
         [FCAN: Motor_Code_01 message is not received]
                   Reset counter: 198
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:45
8250 - Databus
         [FCAN: Motor_07 message is not received]
                   Fault Frequency: 143
                   Reset counter: 201
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:45
8252 - Databus
         [FCAN: Motor_11 message is not received]
                   Fault Frequency: 201
                   Reset counter: 201
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
8254 - Databus
         [FCAN: Motor_12 message is not received]
                   Reset counter: 201
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
8256 - Databus
         [FCAN: Motor_14 message is not received]
                   Fault Frequency: 196
                   Reset counter: 201
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
8258 - Databus
         [FCAN: Motor_20 message is not received]
                   Fault Frequency: 200
                   Reset counter: 201
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
8264 - Databus
         [FCAN: Tsk_06 message is not received]
                   Reset counter: 201
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
8351 - Databus
         [FCAN: Motor_17_alt veraltet bit is set]
                   Reset counter: 198
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:42
         C1146 02 [008] - Signal Failure
                   Reset counter: 193
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
32865 - Databus
         [IPB_BUS: Motor_12 / MO_Drehzahl_01]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
32866 - Databus
         [IPB-BUS: Motor_20 / MO_Solldrehz_Leerlauf invalid]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
32867 - Databus
         [IPB-BUS: Motor_11 / MO_Mom_ist_Summe invalid]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
32872 - Databus
         [IPB-BUS: Motor_20 / MO_Fahrpedalrohwert_01invalid]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
32992 - Control Module for Electric Parking Brake
         C10E2 F0 [008] - RPM Sensor Implausble Signal
                   Reset counter: 193
                   Date: 2015.01.22
                   Time: 22:57:48
32994 - Control Module for Electric Parking Brake
                   Reset counter: 193
                   Date: 2015.01.22
                   Time: 22:57:48
  Part No SW: 3Q0 959 435     HW: 3Q0 959 435
  Component: VWKESSYMQB    023 0522
  Revision: 00023000    Serial number: 0356563904
  Coding: 000F0F1620
  ASAM Dataset: EV_KessyHellaMQBAB 004027
  VCID: 77A8E26B2F4A21AFF8D-8023
12716804 - Databus
         [Message Motor_14 missing]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
12718343 - Databus
         [Message Motor_07 missing]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:44
12718344 - Databus
         [Message Motor_09 missing]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:44
  Part No SW: 8S0 820 047     HW: 8S0 820 047
  Component: AC Manuell el H05 0030
  Revision: 20009000    Serial number: 14190000009000
  Coding: 410040000011100100
  ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
  ROD: EV_AirCondiMAPrehAU33x.rod
  VCID: 70BAD9774A247697397-8025
  Operating and display unit 1 for air conditioning:
  Subsystem 1 - Part No SW: 8S0 820 374 A    HW: 8S0 820 374 A
  Component: E774 BuA_1  H06 0010
  Serial number: 00000000000000000916
  Operating and display unit 2 for air conditioning:
  Subsystem 2 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
  Component: E775 BuA_2  H06 0010
  Operating and display unit 3 for air conditioning:
  Subsystem 3 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
  Component: E776 BuA_3  H06 0010
  Operating and display unit 4 for air conditioning:
  Subsystem 4 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
  Component: E777 BuA_4  H06 0010
  Operating and display unit 5 for air conditioning:
  Subsystem 5 - Part No SW: 8S0 820 374 B    HW: 8S0 820 374 B
  Component: E778 BuA_5  H06 0010
459023 - Databus
         [Motor_12_Alt - Motorsteuergerät - Datenbus fehlende Botschaft]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
  Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
  Component: BCM MQBAB H   H18 0136
  Serial number: 01011500600635
  Coding: 07054C46C201067D03044004B31807A80080000000000000000000000000
  ROD: EV_BCMBOSCH_013.rod
  VCID: 094C949349BE275F9E9-805D
  Subsystem 1 - Part No SW: 8S2 955 119 A    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
  Component: 43x RL 140703  032 0371
  Serial number: 00000001407010600651
  Coding: 1BC7F7
  Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
  Component: G397_RLS  H06 0002
  Serial number: 20170017
  Coding: 00005D
  Serial number: 31 10 2014  00001298
  Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
  Serial number: 000000000ZY143210P5Q
  Serial number: 00000000000031477725
7 Faults Found:
534549 - Databus
         [FLA_01 Datenbus fehlende Botschaft]
                   Reset counter: 201
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 18:49:13
541973 - Databus
         [Motor_04 Datenbus fehlende Botschaft]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
542229 - Databus
         [Motor_14 Datenbus fehlende Botschaft]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
542485 - Databus
         [Motor_18 Datenbus fehlende Botschaft]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
555541 - Databus
         [Motor_12_alt aktiv]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
559125 - Databus
         [Motor_07 Datenbus fehlende Botschaft]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
565764 - LED Light Bar
         B1664 31 [008] - No Signal
                   Reset counter: 201
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 18:39:58
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
  Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
  Component: PARKHILFE 4K  H10 0051
  Revision: --------    Serial number: 39291435205285
  Coding: 0000050001
  ASAM Dataset: EV_EPHVA14AU3700000 002022
  VCID: 3B203E5B53E2C5CFDC5-806F
13637426 - Databus
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
  Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
  Component: AirbagVW20    009 0870
  Serial number: 003M7R008LLN
  Coding: 88CCF0C00C8000005C5000CFC0C800000065
  ROD: EV_AirbaVW20SMEVW37X.rod
  VCID: 4DC46083FD567B7F721-8019
  Subsystem 1 - Part No SW: -----------    HW: 480 000 701 15
  Serial number: 35700000000B4079621C
  Subsystem 2 - Part No SW: -----------    HW: 480 000 701 15
  Serial number: 358000000007D539621J
  Subsystem 3 - Part No SW: -----------    HW: 480 010 712 14
  Component: SideSensor_Dr  004 0108
  Serial number: 351001A014A5F5C2CECQ
  Subsystem 4 - Part No SW: -----------    HW: 480 400 910 14
  Serial number: 3550002A7175A922917%
  Front Sensor Passenger:
  Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
  Serial number: 3560002A5175A924114W
  Pedestrian Protection Center:
  Subsystem 6 - Part No SW: -----------    HW: 480 400 812 14
  Component: PedP_Sensor_C  001 6149
  Serial number: 23000029F1811B91607X
  Subsystem 7 - Part No SW: -----------    HW: 480 000 612 14
  Serial number: I0M000000007C0CC1211
  Subsystem 8 - Part No SW: -----------    HW: 480 000 612 14
  Serial number: I0N00000000C94CC1218
  Part No SW: 8S0 907 129 AL    HW: 8S0 907 129 AL
  Component: Lenks. Modul  H07 0140
  Revision: --------    Serial number: 91335OA800762
  Coding: 280C
  ASAM Dataset: EV_SMLSKLOMQB 019002
  ROD: EV_SMLSKLOMQB_010_VW37.rod
  VCID: 045285A76E9C7A37EDF-8051
  Part No SW: 8S0 920 790     HW: 8S0 920 790
  Component: FBenRDW       H32 0221
  Coding: 24250110698406000120F8809000800000000000
  ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
  ROD: EV_DashBoardBOSCHAU33X.rod
  VCID: 76B6EF6F284058A7E3B-8023
16776971 - Databus
         [Motor_04 communication error can_error_timeout]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
  Part No SW: 8S0 907 468 A    HW: 8S0 907 468
  Component: GW MQB TT3    012 0203
  Revision: --------    Serial number: 10121410802670
  Coding: 030100042F025A004B000268080000000000000000000000000000000001
  ASAM Dataset: EV_GatewContiAU33X 011002
  ROD: EV_GatewContiAU33X_011.rod
  VCID: 3E26374F40F0D0E7FBB-806B
  Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
  Component: J453 MFL  H06 0001
  Serial number: 20141127192416 RD508
  Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
  Serial number: 1322795203
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
         U0100 00 [008] - -
         [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:43
                   Supply voltage: Terminal 30: 14.1 V
                   Terminal 15: On
  Serial number: 14000306508006
  Coding: 0100000000000000
  ROD: EV_ELVMarquMQBB.rod
  VCID: 71BCDC73412E7F9F369-8025
12666369 - Databus
         [Timeout Message Motor_14]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
                   Result lock conditions: invalid
                   ESCL locked: No
                   ESCL unlocked: Yes
                   Lock sensor: not activated
                   Unlock sensor: operated
                   Error mode 1: not active
                   Error mode 2: not active
                   Clamp S: On
                   Clamp 15: On
                   Clamp 15 Status: valid
                   Remote Start: not active
                   Driver door: Open
                   Central locking locked external: unlocked
                   Central locking safed external: Vehicle not secured
                   Clamp Request: No
                   Request highside lock: No
                   HW highside lock: OFF
                   Highside unlock: No
                   Motor break: not active
                   Activation lowside unlock: OFF
                   Activation lowside lock: OFF
                   I2C overflow: No
                   I2C error pathflags: No
                   I2C resetinfo: No
                   I2C error cpu: No
                   I2C error rom: No
                   I2C error ram: No
                   I2C length failure: No
                   I2C error sda: No
                   I2C communication failure: i2c no comm failure
                   I2C state esp 10: i2c cnd true
                   I2C cnd haco message: valid
                   Coco reset: No
                   Coco supply: On
                   Password IMS OK: Yes
                   Signature IMS OK: Yes
                   IMS responded: Yes
                   Positive authentification in current KL15 cycle: No
                   Lifestate: Immobilizer download obtained
                   Authentication valid (T1): No
                   State of authentication state machine: WFS_AUTH_INIT_e
                   Vehicle speed: 0.00 km/h
                   UBat internal: 13.6 V
                   UMotorBridge: 7.4 V
                   Lock condition engine speed: Condition met
                   Lock condition clamp S: Condition not met
                   Lock condition clamp 15: Condition not met
                   Lock condition E2E clamp status: Condition not met
                   Lock condition timeout clamp status: Condition met
                   Lock condition vehicle speed: Condition met
                   Lock condition E2E vehicle speed: Condition met
                   Lock condition timeout vehicle speed: Condition met
                   Lock condition Mode1: Condition met
                   Lock condition drive readiness: Condition met
                   Lock condition selector lever position parking: Condition met
                   Clamp enable ESCL: not enabled
                   Lock condition timeout distance pulse: Condition met
                   Lock condition E2E distance pulse: Condition met
                   Lock condition difference distance pulse: Condition met
13637378 - Databus
         [Errorvalue ESP_Wegimpulse]
                   Reset counter: 193
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:11
                   ESCL locked: No
                   ESCL unlocked: Yes
                   Clamp S: On
                   Clamp 15: On
                   Driver door: closed
                   Clamp Request: No
                   Highside unlock: No
                   I2C overflow: No
                   I2C resetinfo: No
                   I2C error cpu: No
                   I2C error rom: No
                   I2C error ram: No
                   I2C error sda: No
                   I2C state esp 10: i2c cnd false
                   Coco reset: No
                   Coco supply: On
                   IMS responded: Yes
                   Vehicle speed: 63.38 km/h
                   UBat internal: 12.3 V
                   UMotorBridge: 6.6 V
                   Lock condition engine speed: Condition not met
                   Lock condition vehicle speed: Condition not met
                   Lock condition E2E vehicle speed: Condition not met
                   Lock condition difference distance pulse: Condition not met
  Serial number: 060115BLN04479
  Coding: 001146225C01040100001402
  VCID: 42DE43BF3408B4079F3-8017
458803 - Databus
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
  Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
  Component: EPS_MQB_ZFLS  505 5061
  Coding: 9103
  VCID: 3728226B6FCAE1AF38D-8063
7 Faults Found:
20228 - Databus
         [ESP_19 Botschaft - SNA-Check]
                   Reset counter: 193
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   Motor status: 01
                   System status: Driving mode
                   Supply voltage: 12.75 V
                   Temperature: 31.0 °C
                   KFC: 4F
                   KFA: 00 04
                   Environmental conditions: 21
                   uioUdNotFilt_xdu16: 12.83 V
                   uAdSensI_SwitchedKl30_xdu16: 12.81 V
                   ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
23040 - Databus
         [MOTOR_20 Botschaft - CAN-Timeout]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
                   Motor status: 03
                   Supply voltage: 14.00 V
                   KFC: 5A
                   KFA: 00 00
                   Environmental conditions: 20
                   uioUdNotFilt_xdu16: 14.09 V
                   uAdSensI_SwitchedKl30_xdu16: 14.08 V
22784 - Databus
         [MOTOR_14-Botschaft - CAN-Timeout]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
                   Motor status: 03
                   Supply voltage: 14.25 V
                   KFC: 59
                   KFA: 00 00
                   uioUdNotFilt_xdu16: 14.36 V
                   uAdSensI_SwitchedKl30_xdu16: 14.36 V
19460 - Databus
         [ESP_05 Botschaft - SNA-Check]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:42
                   Motor status: 03
                   KFC: 4C
                   KFA: 00 04
                   uioUdNotFilt_xdu16: 14.16 V
                   uAdSensI_SwitchedKl30_xdu16: 14.16 V
23296 - Databus
         [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:45
                   Motor status: 03
                   KFC: 5B
                   KFA: 00 00
                   uioUdNotFilt_xdu16: 14.25 V
                   uAdSensI_SwitchedKl30_xdu16: 14.26 V
21762 - Databus
         [HCA_01 Botschaft - MC-Check]
                   Fault Frequency: 8
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 11:09:11
                   Motor status: 03
                   Temperature: 33.0 °C
                   KFC: 55
                   KFA: 00 02
                   uioUdNotFilt_xdu16: 14.52 V
                   uAdSensI_SwitchedKl30_xdu16: 14.51 V
19716 - Databus
         [ESP_10 Botschaft - SNA-Check]
                   Reset counter: 193
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   Motor status: 01
                   KFC: 4D
                   KFA: 00 04
                   uioUdNotFilt_xdu16: 13.02 V
                   uAdSensI_SwitchedKl30_xdu16: 13.01 V
  Serial number: 100115BA91780A
  Coding: 001146225E01040100001402
  VCID: 41DC4CB3310EAF1F869-8015
65541 - Dimming for Switch Illumination
         B132B 01 [008] - Electrical Failure
                   Reset counter: 201
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 18:07:29
458803 - Databus
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
  Coding: 03DE00102B100200
  ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
  VCID: 343215677EBC0AB71DF-8061
  Coding: E01800
  Coding: E01800
  Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
  Component: LeiMo links  H02 S002
  Coding: E01800
  Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
  Component: LeiMo rechts  H02 S002
  Coding: E01800
  Matrix Headlamp Powermodule 1 Left:
  Component: MxB LeiMo li.
  Matrix Headlamp Powermodule 1 Right:
  Component: MxB LeiMo re.
13705479 - Databus
         U1121 00 [137] - Missing Message
         [Kamera_FDD_Obj01 Datenbus fehlende Botschaft]
                   Reset counter: 161
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 19:55:59
5334065 - Output Stage for Left Matrix Headlamp
         C1164 31 [137] - No Signal
                   Reset counter: 161
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 19:56:00
5334321 - Output Stage for Right Matrix Headlamp
         C1165 31 [137] - No Signal
                   Reset counter: 161
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 19:56:00
5275220 - Headlight
         C107E 54 [137] - Missing Calibration / Basic Setting
                   Reset counter: 161
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 19:56:00
5350720 - Left Matrix High Beam
         C1175 54 [137] - Missing Calibration / Basic Setting
                   Reset counter: 161
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 19:56:00
5350976 - Right Matrix High Beam
         C1176 54 [137] - Missing Calibration / Basic Setting
                   Reset counter: 161
                   Mileage: 94440 km
                   Date: 2020.01.17
                   Time: 19:56:00
  Part No SW: 8S0 035 072 A    HW: 8S0 035 072
  Component: MU-H-ND-ER    041 0139
  Serial number: A587A0FB000508
  Coding: 013304013C00000011111101000800002F0000E3000000001E
  ASAM Dataset: EV_MUHig4CGen2HBAS 001115
  ROD: EV_MUHig4CGen2HBAS_AU37.rod
  VCID: 2D0400039D965B7F521-8079
  Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
  Component: ECE 2015  --- 0105
  Multimedia Operating Unit:
  Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
  Component: ControlUnit_H  H21 0129
  Serial number: C1000015111400010114
  Compact Disc Database:
  Component: Gracenote2  --- 1008
6708 - Databus
         [Engine: no communication]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:40
                   Voltage terminal 30: 14.4 V
                   Network diagnosis-Status: Enabled
  Part No SW: 8S0 980 653     HW: 5Q0 980 653
  Component: MQB_MFK       H06 0002
  Serial number: 00000268359
  Coding: 0101000001010300000501000000010100
  ROD: EV_MFKBoschAU370.rod
0291 - Steering
         C10AC F3 [008] - Lane-Holding Assistance Not Available
         [suHcaBlockedSteeringErrorFailure]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 11:19:01
                   Control Module temperature: 40 °C
                   Outside air temperature: 14.5 °C
                   Voltage terminal 15: 14.1 V
                   Terminal 15 on: 8.1 s
  Part No SW: 8S0 907 159     HW: 4H0 907 159 A
  Component: SAS-GEN 2     H07 0004
  Serial number: 141203200313
0010 - Databus
         [Keine Funktion durch CAN FehlerMotorsteuergerätebotschaft fehlt--> keine Klangerzeugung]
                   Reset counter: 193
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 10:53:41
End----------(Elapsed Time: 01:34, VBatt start/end: 14.6V/14.6V)-----------
Kind Regards
Glenn - HGB Motors
Glenn@hgbmotors.co.uk
On 17 Jan 2020, at 21:34, Andy Smith <support@ross-tech.com> wrote:
Please email a COMPLETE AutoScan, not just the faults in 01-Engine.
Regards,
Andy
On 1/17/2020 3:16 PM, Glenn - HGB Motors wrote:
Hi Andy, thanks for your quick response.
Please see the error codes below, look forward to hearing from you;
Friday,17,January,2020,20:09:47:30289
VCDS Version Release 19.6.2 (x64) Running on Windows 7 x64(Parallels)
[url]www.Ross-Tech.com[/url] <http://www.ross-tech.com/>
               Address 01: Engine       Labels: 06K-907-425-V1.clb
Control Module Part Number: 8S0 906 259     HW: 06K 907 425 B
 Component and/or Version: 2.0l R4 TFSI  H13 0004
          Software Coding: 0A1900322424050B3002
           Work Shop Code: WSC 06385 790 00016 <tel:06385%20790%2000016>
             ASAM Dataset: EV_ECM20TFS0208S0906259 001005 (AU37)
         U0416 00 [032] - -
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 11:18:47
                   PV: 0.00 %
                   T_IGK: 2.90 s
17178 - Databus
                   Mileage: 92339 km
                   Date: 2020.01.14
                   Time: 11:18:45
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   T_ES: 0 min
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   T_ES: 0 min
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   T_ES: 0 min
         U0415 00 [040] - -
                   Mileage: 92340 km
                   Date: 2020.01.14
                   Time: 11:24:09
                   T_ES: 0 min
Good lord, that car is so full of fault codes that the signal-to-noise ratio is just about nil.
What exactly did you do to make such a mess?
Please look at your CodingLog and AdpLog files and put everything back to stock, then clear all fault codes and post a new scan.
Hbuk24
Spain
C?ID=306940
I was trying to activate high beam assist and traffic sign recognition. Traffic signs were successful and I have reverted the changes I made for high beam assist unless I have missed anything.
I am new to this how can I go back to standard?
I have had sat nav activated as a retrofit and also a remap so I am worried about wiping these.
Thanks for your help.
United States
We received the e-mail sent to support but it contains the same Auto-Scan. I would recommend posting a handful of logs so we can try to help you get this resolved as a group:
1) Open the CodingLog and AdpLog files using Notepad and paste the contents within code tags here.
2) The VCDS Auto-Scan prior to any modifications would be extremely helpful. You may want to look in both C:\Ross-Tech\VCDS\Logs -and- C:\Ross-Tech\VCDS\Scans to locate the oldest one you have from this VIN.
3) The scan you posted includes 59 fault codes which are flagged Intermittent. Many of those should clear so please do so and include another scan in that condition. That will make it significantly to determine what's what.
Hbuk24
Spain
C?ID=306940
I have had some help with this from someone using team viewer and he manages to sort everything out apart from the headlights which was great, I have attached the latest autoscan. Please ignore the door warning as I had the door card off at the time to install puddle lights. Any help regarding this would be really appreciated as I can't seem to find any information on how to fix the lights. It looks like they need to be calibrated? The message that comes up on the dash is "Audi adaptive light: fault. See owners manual. Thanks
Wednesday,22,January,2020,17:38:50:30289
VIN: TRUZZZFV3F1009952   Mileage: 94535km-58741miles
   Revision: --H13---
   Coding: 000F0F1620
   Coding: 1BC7F7
   Coding: 00005D
   Coding: 0000050001
   Coding: 280C
   Coding: 9103
65592 - Interior Switch for Central Locking
          B1230 29 [008] - Signal Implausible
                    Reset counter: 214
                    Mileage: 94535 km
                    Date: 2020.01.22
                    Time: 17:32:26
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: E01800
13705479 - Databus
                    Reset counter: 172
                    Mileage: 94509 km
                    Date: 2020.01.21
                    Time: 23:27:26
                    Reset counter: 172
                    Mileage: 94509 km
                    Date: 2020.01.21
                    Time: 23:27:26
                    Reset counter: 172
                    Mileage: 94509 km
                    Date: 2020.01.21
                    Time: 23:27:26
5275220 - Headlight
                    Reset counter: 172
                    Mileage: 94509 km
                    Date: 2020.01.21
                    Time: 23:27:26
                    Reset counter: 172
                    Mileage: 94509 km
                    Date: 2020.01.21
                    Time: 23:27:26
                    Reset counter: 172
                    Mileage: 94509 km
                    Date: 2020.01.21
                    Time: 23:27:26
End----------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.2V)-----------
It looks like it thinks i have Matrix headlights when I don't think i do.
United States
I agree, it is looking for Matrix lights and a camera ([Kamera_FDD_Obj01 Datenbus fehlende Botschaft]) that isn't on the databus. The CodingLog and AdpLog in addition to any prior VCDS Auto-Scans may allow us to determine the cause.
In the meanwhile, it might not hurt to see if 55 will accept: 03DE00102B200200 If that's accepted I would clear faults so see how many return. With any luck you will be down to one for Basic Settings rather than 6.
Edit, I can move this to the Car Repair Support section now that you are Verified. It will receive more views there.
Hbuk24
Spain
C?ID=306940
Yes, I have just read the original scan file from when i bought the car and it has them down as normal LED headlamps. I do hoverer have a camera in the can as is currently active for picking up the traffic signs. I have attached the original log file below;
Sunday,12,January,2020,16:42:30:30289
VIN: TRUZZZFV3F1009952   Mileage: 91851km-57073miles
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   ASAM Dataset: EV_ECM20TFS0208S0906259 001004
20277 - Terminal 15 Voltage
          P151B 00 [036] - Implausible
                    Mileage: 91851 km
                    Date: 2020.01.12
                    Time: 15:43:43
                    Engine speed: 798.00 /min
                    Normed load value: 3.1 %
                    Coolant temperature: 90 ∞C
                    Intake air temperature: 34 ∞C
                    Voltage terminal 30: 12.050 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 27 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
                    FAC_TPS_1_SAE: 11.718750 %
                    FUP_H_SAE: 11000.0 kPa
15057 - Fuel Rail/System Pressure
          P0088 00 [096] - Too High
   Coding: 000F0F1620
   Coding: 1BC7F7
   Coding: 00005D
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 144
                    Mileage: 91818 km
                    Date: 2019.12.17
                    Time: 09:38:45
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [008] - Alert Emergency Activation Stage 1
                    Reset counter: 184
                    Mileage: 91818 km
                    Date: 2019.12.17
                    Time: 09:38:46
   Coding: 0000050001
   Coding: 280C
   Coding: 24250110698006000120A8809000800000000000
   Coding: 9103
Address 52: Door Elect, Pass.
   Coding: 03DE00102B200200
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: 013304013C00000011111101000800002F0000E3000000001A
   Subsystem 1 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Coding: 0100000001010300000501000000010100
End----------(Elapsed Time: 01:24, VBatt start/end: 13.2V/13.2V)-----------
United States
OK, that original scan sheds a lot of light and confirms 55 was coded to 03DE00102B200200. Providing there weren't any ADP function modifications the modules with remaining modifications are:
* Including a new 5F slave
Serial number: C1000015111400010114​
The scan snippets above, with the exception of the new slave, are your old/original values. Due to the extremely high number of fault codes in your initial scan I would code 55 back to 03DE00102B200200 for now and run Basic settings (Basic headlamp setting followed by Acknowledge basic setting) to get this vehicle back to a relativity fully functional/DTC free condition.
After doing so you can start a new thread containing the factory condition scan and the newest cleaned up post-camera retrofit scan in the Retrofits section. Someone there may be able to help you work out the needed modifications without causing so many codes.
Hbuk24
Spain
C?ID=306940
Great, I have just followed your steps and it looks like the error has gone. Thank you very much for all your help and advice!
United States
Excellent! I know we didn't achieve activation of high beam assist and traffic signs but the newest scan probably looks great. If you do create a new thread here please include that new scan with the oldest in addition to the part number(s) of any retrofitted parts. Doing so should result in configuration suggestions.
Hbuk24
Spain
C?ID=306940
Thanks, I have created a couple of new posts for help on installation of the other features. I will add the latest scan to these also.
