Readiness script error 1Y 2005 New Beetle BEV secondary air
Shzeps
C?ID=11561
Hi Group,
I needed to complete readiness on this 1Y 2005 New Beetle BEV.
I used the VCDS readiness script to complete this. I have a problem when it tries to run the monitor for secondary air. VCDS script goes to BS 211 and all values are blank. After doing some research I found that BS 221 is the correct BS. Hopefully this can be changed in the future. Please let me know if I need to supply more info like mapping the control unit, etc. to help fix it.
Now, I can run the secondary air test with BS 221 but the monitor never completes (xxxxx100) and it doesn't set a trouble code either. I have let the car cool down and run thru the complete monitor cycle 3x, Any ideas?
Thanks for any help or info, Shep
Wednesday,15,January,2020,13:19:58:57829
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4513.4
VIN: 3VWCM31Y55M316812   License Plate:
Mileage: 296270km-184093mi   Repair Order:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCM31Y55M316812   Mileage: 296270km-184093miles
Address 01: Engine        Labels: 06A-906-032-BEV2.clb
   Part No: 06A 906 032 RL
   Component: 2L NB-C AT6     G   6377
   Coding: 00003
   Shop #: WSC 00066
   VCID: F9BAB78DE13837821A-513C
   3VWCM31Y55M316812     VWZ5Z0D8232068
16804 - Catalyst System; Bank 1
            P0420 - 35-00 - Efficiency Below Threshold
16384 - SAE - Reserved by Document ISO 15031-6
            P0000 - 35-10 - 2005 - Intermittent
   Part No: 09G 927 750 AP
   Component: AQ 250 6F           0610
   Coding: 0000008
   VCID: FF4E5995AF1C19B224-513C
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   Shop #: WSC 00066 000 00000
   VCID: B32645A5D3D40DD290-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AF
   Component: 01 AIRBAG VW71      0609
   Coding: 0012337
   VCID: FBB6AD85BB04059208-5160
   Subsystem 1 - Part No: 1C0 959 339 B
   Component: BF-Gewichtsens. 006 0006
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 951 L
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11234
   Shop #: WSC 46311
   VCID: AA1858C1541E4C1A23-4B1E
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 26062
   VCID: F0AC8AA9B24276CAAD-4B1E
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255
   Component:  VSG  NBC       †
   VCID: FDB2A39DA5100BA236-513C
   Part No: 1C0 959 799 G
   Component: 6J Komfortgerбt HLO 0004
   Coding: 00257
   Shop #: WSC 26062
   VCID: BB366D85AB84C59248-4B00
   Subsystem 1 - Part No: 1Y1959801C
   Component: 6J Tхrsteuer.FS KLO 0005
   Subsystem 2 - Part No: 1Y1959802D
   Component: 6J Tхrsteuer.BF KLO 0005
   Subsystem 3 - Part No: 1Y0959811
   Component: 6J Tхrsteuer.HL KLO 0001
   Subsystem 4 - Part No: 1Y0959812
   Component: 6J Tхrsteuer.HR KLO 0001
01359 - Internal Central Locking Switch; Passenger Side (E198)
   Part No: 1C0 035 196 M
   Component:  RADIO DE2         0003
   Coding: 06031
   Shop #: WSC 00066
   VCID: A91AA7CD511847022A-51CE
End----------(Elapsed Time: 03:55, VBatt start/end: 14.0V/14.0V)-----------
Thanks for the feedback with scan!
Santos (who created those scripts back in the day) will be back on Monday. I'm off Monday so feel free to bump this back up however my dealer days 2005 2.0L Engine Code BEV document lists the Readiness Recipe in this exact order:
202
204
209 *see note
206
207
217
210
212
216
220
208
221
Based on my fuzzy recollection I believe 209 was the fussy one and it had to complete before SAI would run.
That wasn't just a Beetle thing; rather all 2.5L engines could be particular about SAI. Hopefully running them in that exact order helps. If not, I would take it for a quick drive and let it run when you return to the garage so they can be repeated.
