Passat 3B and replacing the ECU problem
V3lmu
Oulu, Finland
C?ID=229426
Hey!
The problem car at the moment is the Volkswagen Passat model 2001.
The original Ecu will have to be replaced because the engine is fitted with more powerful nozzles than the original one, which has been disassembled from a crashed car. The same crashed car takes an ECU optimized for these most powerful nozzles.
We followed the instructions for this link http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_ECU_Swapping#Engine_Control_Unit_.28ECU.29_Swapping_.28USED_ECU.29, but right from the start it will stop the error message. "SKC code incorrect"
I was looking at the SKC code before switching to VagTacho and we know the code, but VagTacho claims that the old and new used ECUs would have the same code. Can this be true? and what should we try next to get the new used ecu to work on that car?
Preheat and immobilizer lights on instrument cluster blink when engine ecu is replaced with new used
These codes are read from the new used ECU.
Friday,17,January,2020,19:03:16:00464
Dealer/Shop Name: J.P - V3lmu
VIN: WVWZZZ3BZ2E152041   License Plate: VW PASSAT
Mileage: 448790km-278865mi   Repair Order: ecu homma
VIN: WVWZZZ3BZ2E152041   Mileage: 448790km-278865miles
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Shop #: BB 24334
   VCID: 1C61D4672FBBDAE735F-51CE
   Part No: 3B1 907 044 H
   Component: CLIMATRONIC B5GP    0006
   Coding: 17000
   Shop #: WSC 05311
   VCID: 2615F68F61F7103793B-5184
00787 - Temperature Sensor in Fresh Air intake duct (G89)
            30-00 - Open or Short to Plus
   Part No: 1C0 909 605 B
   Component: 0A AIRBAG VW51 04     02
   Coding: 12353
   Shop #: WSC 05311
   VCID: 2313EF9B12C5E51FF45-513C
   Part No: 3B0 920 826 A
   Component: KOMBI+WEGFAHRSP VDO V01
   Coding: 05115
   Shop #: WSC 00050
   VCID: 211FE59308D9F70FE69-513C
   WVWZZZ3BZ2E152041     VWZ7Z0A4036000
01177 - Engine Control Unit
            65-10 - Unauthorized - Intermittent
   Part No: 6N0 909 901
   Coding: 00004
   Shop #: WSC 05314
   VCID: 70B9D0D793B30E87397-513C
   Part No: 1C0 959 799 B
   Component: 16 Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 05311
   VCID: 363526CFB15760B723B-4B1E
   Subsystem 1 - Part No: 1C1959801
   Component: 16 Tõrsteuer.FS KLO 0003
   Subsystem 2 - Part No: 1C1959802
   Component: 16 Tõrsteuer.BF KLO 0003
   Subsystem 3 - Part No: 1C0959811
   Component: 16 Tõrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812
   Component: 16 Tõrsteuer.HR KLO 0002
01134 - Alarm Horn (H12)
            49-00 - No Communications
01141 - Luggage Compartment Unlocking Switch (E165)
            36-00 - Open Circuit
            27-00 - Implausible Signal
End----(Elapsed Time: 04:34, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
That seems highly unlikely. As in the chances of that are something on the order of 1 in 10,000. ;)
Your scan doesn't show any ECU at all.
V3lmu
Oulu, Finland
C?ID=229426
Does this mean that this car is not immo 3 but immo 2?
I only noticed this now. Is this because of that DTC (1 Fault Found: 01177 - Engine Control Unit 65-10 - Unauthorized - Intermittent)
No, since the instrument cluster knows the car's VIN, I think it's pretty safe to conclude that this car is Immo-3.
I would expect this fault code is there due to you having swapped ECUs at some point.
Need to establish communication issue with ECU in scan first?
Does check engine illuminate?
Does car crank, start and die after 2 seconds?
Why not just defeat Immobilizer?
Is Tune code running FOD interference maybe bad xsum?
V3lmu
Oulu, Finland
C?ID=229426
If you think the ECU is broken, you're wrong. The ecu has been dismantled from a crashed car, but here the engine worked with these nozzles and the ecu.
Yes and immo light too.
Yes, Exactly.
The owner would like the immobilizer to be a last resort.
I am researching the subject to remove the immobilizer, but I have not found any program / help how to do this.
I don't understand this question, sorry :(
No it is you who are wrong, that is why you are here!
Bad Math...........
V3lmu
Oulu, Finland
C?ID=229426
The owner said that before disassembling the parts, he had started the car and let it idle and gasified the engine. The engine had run smoothly at all revs.
The problems started when the crash car parts were put in the current car.
Bad Math...........
Is this somehow related to the ecu/tuning program?
Ja Ja Ah huh!
Depends but It can be............ :rolleyes:
Tuners protect their shit with MATH or sometimes HASH!
https://www.theatlantic.com/technol...e-streets-count-von-count--cant-count/466242/
Hash function
https://en.wikipedia.org/wiki/Hash_function
V3lmu
Oulu, Finland
C?ID=229426
This amazes me and even a little pissed off.. :mad:
How do parts in a crash car rotate the engine nicely but not rotate another same engine? :banghead:
Don't be mad at me I'm just the messenger, okay?
Hot sauce for taco?
V3lmu
Oulu, Finland
C?ID=229426
Problem solved
The owner had taken a car with a power engine control unit, instrument cluster and keys. Now the car is operating normally.
Now all you have to do is adjust the central locking system so that all the doors open and close with one click, including the tailgate.
