Fabia 2 FL Longcoding ESP8.2i help please
toele1410
Berlin, Germany
C?ID=390117
SOLVED: Fabia 2 FL Longcoding ESP8.2i help please
hi everyone
after testing another speedometer in my fabia my esp is now completely zero.
I don't have a scan of this before.
i tried to calculate the esp coding with espcalculator but with every result the error 22.
I don't know what to do, can someone help me here?
thank you danny
 Friday,17,January,2020,15:30:30:39104
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: TMBEA25J2C3024139   License Plate:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: TMBEA25J2C3024139   Mileage: 108940km-67692miles
Address 01: Engine (CHF)       Labels: Redir Fail!
   Part No SW: 03D 906 023 M    HW: 03D 906 023 M
   Component: SIMOS91 1.2l 2V     1718
   Revision: --H05---    Serial number:
   Coding: 0000071
   Shop #: WSC 13765 790 00051
   VCID: 280802755EEA9747A17-5185
Readiness: 0010 0001
   Part No SW: 6R0 907 379 AA    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0003
   Revision: --------
   Coding: 000000000000000000000000000000000000
   VCID: 7DA60321EDB8E2EFA21-8029
03306 - Coding Not Valid
                    Fault Frequency: 27
                    Reset counter: 130
                    Mileage: 108873 km
                    Date: 2014.06.06
                    Time: 17:46:31
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x3209
                    Hex Value: 0x1494
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Frequency: 83
                    Reset counter: 130
                    Mileage: 108738 km
                    Date: 2014.05.27
                    Time: 20:43:39
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3211
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 5J0 820 045 C    HW: 5J0 820 045 C
   Component: Man AC         02 0101
   Revision: 0003S 02
   VCID: 25160B4125E88A2F9A1-8071
   Part No SW: 6R7 937 086 H    HW: 6R7 937 086 H
   Component: PQ25 BCM      H12 0022
   Revision: -3------    Serial number: 1002480501
   Coding: 64980B380801000000200EC03E6B18840000400F600000000000
   VCID: 48C8A2F5F2BA7747417-801D
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3211
   Coding: 020000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3211
   Coding: 020000
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagT23 H09 0020
   Revision: --------    Serial number: 003GX00PPFC0
   Coding: 003233
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACC98FDEC368557573-801F
   Serial number: 3495RRB405T0KEOINHB-
   Serial number: 3505RRB404V0KSEG3P7F
   Part No SW: 5J0 920 801 H    HW: 5J0 920 801 H
   Component: KOMBI         H04 0206
   Serial number: 00000007146755
   Coding: 110800
   Shop #: WSC 13765 031 00051
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
   ROD: EV_DashBoardUDSJCIPQ25_A01.rod
   VCID: 2B02FD79438CBC5F4C5-807F
   Part No SW: 6N0 909 901     HW: 6R7 937 086 H
   Component: GW-K-CAN TP20 0022
   Revision: -3------
   Coding: 032200
   VCID: 70B82A15AAAA9F87397-8025
Address 25: Immobilizer (J285)       Labels: 5J0-920-xxx-25.clb
   Component: IMMO          H04 0014
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25.rod
   Part No: 6R0 423 156 B
   Coding: 11240
   Shop #: WSC 13765
   VCID: 2F3AE9697E54C07F60D-807B
Address 56: Radio
End----------(Elapsed Time: 00:55, VBatt start/end: 13.4V/13.4V)-----------
toele1410
Berlin, Germany
C?ID=390117
good morning
nobody can help me by coding?
vin: TMBEA25J2C3024139
1.2 engine chf
LHD
front disk: 256 mm
back drums: 200 mm
no tmp, no hill hold, no xds
toele1410
Berlin, Germany
C?ID=390117
nobody wants or can help me to code the abs new here?
NEtech
Denmark
C?ID=56995
To few Autoscan with this engine.
Maybe try this:
410124DB216F00B6822624E584DA00401000
toele1410
Berlin, Germany
C?ID=390117
thank you, thank you, thank you very much.
you coding is perfect working.
