2014 VW Touran steering angle sensor not calibrating, reading 0° all time
VW_FI
Finland
C?ID=21939
Steering wheel clockspring unit has been renewd and coded with the original coding but
now having trouble with Touran not letting to do basic settings for the G85. Tried many times in 03, 44 & 16 (sensor zeroing), all with login 40168.
Also checked graph of abs wheel sensor and they looked all good, sometimes there is fault code under 10 (Park/Steer Assist) of a front radar.
The angle reading keeps 0 in most places, the rate (acceleration) reading works. Under 16 - Steering wheel (J527) I can see some hexadecimals changing while turning the wheel and under 44: Steering Assist there's a reading from 0-360 that goes over and over about 10 times with just one full turn of the steering wheel, don't know what that is.
Any suggestions?
Thursday,16,January,2020,17:16:03:34924
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
VIN: WVGZZZ1TZFW012144   License Plate: TOURAN_3
Mileage: 162580km-101022mi   Repair Order:
Chassis Type: 1T (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 37 42 44 46 4F 52 55
          56 61 62 69 72
VIN: WVGZZZ1TZFW012144   Mileage: 162580km-101022miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 NR    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254036032401080000
   ASAM Dataset: EV_ECM16TDI02103L906023NR 003011
   ROD: EV_ECM16TDI02103L906023NR.rod
   VCID: 830E26B30A9DF4597E-80D6
   Part No SW: 0AM 300 064 B    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5201
   Revision: 00043014    Serial number: CU501406135401
   VCID: AD5AA00B3499D229F8-80F8
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 323B401609230EFC4C0C02E8901D7051A1015021
   VCID: FEF85747697F99B111-80AA
                    Reset counter: 180
                    Mileage: 162584 km
                    Date: 2020.01.16
                    Time: 15:53:29
                    Count: 16387
                    Count: 12800
                    Count: 16390
                    Count: 48384
                    Count: 9728
                    Reset counter: 180
                    Mileage: 162584 km
                    Date: 2020.01.16
                    Time: 15:53:29
   Part No SW: 3AA 907 044 BS    HW: 3AA 907 044 BS
   Component: Climatronic   H05 0607
   Revision: 00001K02
   Coding: 001000C003
   VCID: 820023B71587FD5175-80D6
   Part No SW: 5K0 937 087 AB    HW: 5K0 937 087 AB
   Component: BCM PQ35 H    122 0174
   Revision: BE122001
   Coding: 60180A3B80251AE4408800C0540011604BD59008626DA520E480C7000049
   VCID: F5EA486B5C49DAE940-80A0
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 18061  26  0512
   Coding: 009795
   Component: RLS 020714 05  54  0403
   Coding: 0230ED
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0043
   Revision: --------    Serial number: 56201416701018
   Coding: 148301
   ASAM Dataset: EV_EPHVA2C000000000 002014
   ROD: EV_EPHVA2C000000000_VW41.rod
   VCID: CB9ECE93624DFC19C6-809E
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Component: 02 AIRBAG VW8   022 0100
   Revision: 02022000    Serial number: 003K4D0CVW8.
   Coding: 0012338
   VCID: B7768263C6C568F992-80E2
   Subsystem 1 - Serial number: 6332QSME6E463E72V
   Subsystem 2 - Serial number: 6342QSME6E463252I
   Subsystem 3 - Serial number: 6352QSME36453E40G
   Subsystem 4 - Serial number: 6362QSME34451F60G
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20191029100200
   Coding: 1982140000
   Shop #: WSC 01286 386 08256
   Serial number: 0571575
   Coding: 820000
1140738 - Steering angle sensor
                    Reset counter: 180
                    Mileage: 162584 km
                    Date: 2020.01.16
                    Time: 15:50:58
                    UBat: 12.40 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 1T0 920 885 N    HW: 1T0 920 885 N
   Component: KOMBI         H03 0705
   Coding: 180F01
   VCID: C38EE6B34A1D34593E-8096
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 C
   Component: Standheizer     044 4840
   Revision: 00044000    Serial number: 09024302000000
   Coding: 0031012
   Shop #: WSC 35110 377 00163
   VCID: B56A886BDCC99AE980-80E0
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 230614F1001106
   Coding: 358002
   VCID: 800429BF138BEF4163-80D4
   Component: IMMO          H03 0705
   VCID: EAD06B170DF70511DD-80BE
   Revision: A1001003    Serial number: 7666349754
   Coding: 020100
   VCID: AB5EAE13CA8DDC19E6-80FE
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C8 035 279 R    HW: 3C8 035 279 R
   Component: RNS315-EU   H80 0500
   Serial number: VWZAZ2P0357542
   Coding: 040004110400090000029002
   ROD: EV_RNS315EUV2UDS.rod
   VCID: BA709B573DD775916D-80EE
   Component: EUR_W_V6  0062
   Part No SW: 1T0 959 701 AE    HW: 1T0 959 701 AE
   Component: Tuer-SG         009 2121
   Coding: 0165045
   VCID: FAF05B57B557B5912D-80AE
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.294 1401
   Revision: 1BH04739    Serial number: 00141780051501
   Coding: 0000258
   VCID: C182ECBB980126492C-8094
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 180
                    (no units): 4.0
                    Voltage: 12.70 V
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Reset counter: 180
                    Reset counter: 180
                    Mileage: 162584 km
                    Date: 2020.01.16
                    Time: 15:56:15
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 5
   Component: EZE_2         H55 1653
   Coding: 050B0500
   VCID: EFE67A033E15E0398A-80BA
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0165045
   VCID: C796F2A3B6251879E2-8092
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 038200000B000200
   VCID: B77682630EC568F992-80E2
   Subsystem 1 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 320000
   Subsystem 2 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 320000
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1653
   Coding: 030F1859
   VCID: F1E27C7B2821F6C99C-80A4
   Component: J367-BDM  H07 0180
   Serial number: 31171523261491440508
   Part No SW: 5K0 959 703 B    HW: 5K0 959 703 B
   Component: Tuer-SG         007 2102
   Coding: 0165008
   Shop #: WSC 01357 011 1012552
   VCID: B36EB673D2BD84D9AE-80E6
00937 - Switch for Electric Window; Rear Left (E52)
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Towbar module H10 0110
   Revision: 3A001001    Serial number: ÀÁ006789XXXXXX
   Coding: 0100000100000000
   VCID: B162BC7BE8A1B6C9DC-80E4
   Part No SW: 5K0 959 704 B    HW: 5K0 959 704 B
   Coding: 0165008
   VCID: B46CB56FD7B383E1B7-80E0
End-------------------------(Elapsed Time: 03:12)--------------------------
Gone But Not Forgotten
Is the TPMS fault running interference?
Are all correct parts installed?
Are all mechanical operations correct & set to neutral basic setting center-line?
