- Aug 18, 2016
- 64
- 32
- Newry, NI, UK
- C?ID=86928
Can anyone help me with the error codes on the ABS?
There is low tyre pressure warning light on the dash display but I can't seem to reset it.
Thursday,16,January,2020,14:44:26:46973
VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
Workshop Code: 000 18261 018261
VIN: WAUZZZ4GXCN154910 License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ4GXCN154910 Mileage: 181076km-112515miles
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2.0l TDI H24 9977
Revision: 45H24---
Coding: 0A194012242401080000
Shop #: WSC 41215 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LA 003011
ROD: EV_ECM20TDI01103L906018GT.rod
VCID: F4A4958D5F0CD2EF33-80A0
U1113 00 [039] - -
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:36
Engine speed: 830.50 /min
Normed load value: 27.5 %
Coolant temperature: 53 °C
Intake air temperature: 21 °C
Voltage terminal 30: 14.660 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 40
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [039] - -
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:36
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 00000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: B6206F8509F080FFCD-80E2
0058 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_01_Timeout]
Reset counter: 99
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:33
VzRef: 00
Bit Info 1: 00
Bit Info 2: 43
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: BE
Uz: BC
0060 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_03_Timeout]
Reset counter: 99
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:33
VzRef: 00
Bit Info 1: 00
Bit Info 2: 43
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: C1
Uz: BC
0061 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_04_Timeout]
Reset counter: 99
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:34
VzRef: 00
Bit Info 1: 00
Bit Info 2: 43
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: CB
Uz: BC
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Coding: 03B83006000000000000
VCID: F6A0AF854170C0FF0D-80A2
Serial number: 2312000054271013
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0064
Serial number: 21031200040666
Coding: 34210008A0
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS_002.rod
VCID: A306A6D1AA6205571A-80F6
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Reset counter: 99
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:34
Compressor current: actual value: 0 mA
Outside air temperature: 11.5 °C
Temperature after evaporator: 14.61 °C
Engine speed: 829 /min
Part No SW: 4H0 907 063 BM HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0111
Revision: 19012002 Serial number: 00000001249799
Coding: 2600201040349F600481008000001D0C0F9D830827090101000004602100
VCID: F4A4958D570CD2EF33-80A0
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120214 H35 0080
Serial number: 120305184049
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 20112220
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 16 03 2012 00001561
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 21180E16000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901207903874
Coding: 080206
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: BD3270A92CC653A70C-80E8
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG007PJDG
Coding: 30323436313230303235554A305234473053
Serial number: 3575HRB406317UE4AP4B
Serial number: 3585HRB405D177543GT+
Serial number: 3515JRB40184UHGCA1AC
Serial number: 3525JRB401I4UHGCEQ32
Serial number: 3554VRB40084UH6IP91-
Serial number: 3564VRB40084UH6INA7%
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120324000386
Coding: 000014
VCID: B02C599DE394AECF97-80E4
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Part No SW: 4G8 920 950 K HW: 4G8 920 950 K
Component: MDieGb H34 0209
Revision: 26450208 Serial number: 658060312592041
Coding: 33A408000B012600010000
ASAM Dataset: EV_RBC7KMID 004045
ROD: EV_RBC7KMID.rod
VCID: B73E62810EFA79F7D6-80E2
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung / Adaption]
Reset counter: 99
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:34
Part No SW: 4G5 907 468 F HW: 4G0 907 468 AC
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002372128
Coding: 00CD074410
Shop #: WSC 54484 001 1048576
ASAM Dataset: EV_GatewPkoUDS 001028
VCID: B83C61BD03E4768FDF-80EC
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790556910
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 16121100000000000044
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0009
Revision: -------- Serial number: EJ1BPA3201TNCL0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: EB968EF102320D17E2-80BE
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16204001620002080002
VCID: C2C803555D382C5F71-8096
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0026403518
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B2285395E5989CDFE1-80E6
Revision: 00002001 Serial number: 0173462617
Coding: 011B062200B9044083200804000103000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: C1CA0C59583E374768-8094
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000289125
ROD: EV_ParkiBrake_VW51.rod
VCID: AA184BF5CD48D41F59-80FE
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 120322-0002-107
Coding: 112196101000A300
ROD: EV_HeadlRegulBasic.rod
VCID: AC144DEDC7BCCA2FAB-80F8
Part No SW: 4G0 035 193 E HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0775
Coding: 0101000101415B47002B060301010000010000
VCID: A502B8C9AC56FB6774-80F0
Subsystem 1 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464C-0C2517377
Subsystem 2 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
Component: E380 BDT C7 H11 0204
Serial number: 90349LCJ00039
Reset counter: 99
Mileage: 181076 km
Date: 2020.01.16
Time: 14:42:38
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: C4C4054D472C226F43-8090
Component: TSG HR H04 0212
End----------(Elapsed Time: 01:33, VBatt start/end: 14.7V/14.7V)-----------
