i have a 2007 VW passat wolfs-berg edition 2.0t that wont start and wont crank. When I put the key in the ignition the yellow steering wheel light comes on and the screen says move steering wheel and i can here clicking then about 10 seconds worth of clicking the screen says is steering wheel locked.the seeing wheel controls do nothing the radio does not come on.no other lights in the dash. i can see the odometer and trip time and date but nothing else checked all the fuses with multi-meter. I need help figuring it out.
Wednesday,15,January,2020,15:56:02:34027
VIN: WVWAK73C47P165189
Chassis Type: 3C0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
72
Mileage: 327910km-203753miles
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Part No SW: 1K0 820 047 GG HW: 1K0 820 047 GG
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6FBBD5BAEB9542CF20D-803A
001 - Upper Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004901723
Coding: 15848F0340041A00470000000F00000000285D435C0001
Shop #: WSC 00028 028 00001
VCID: 6C81C2B6DA83B9D705F-FFFE
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 120407 003 0205
Coding: 00046997
Shop #: WSC 00028
No Faults Found
Address 0F: Digital Radio
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0007000 Serial number: 00000000000000
Coding: 0007205
VCID: 2313E98A77DDB6AFF45-8076
7 Faults Found:
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.09
Time: 20:41:18
00771 - Fuel Level Sensor (G)
Fault Status: 00101010
Fault Frequency: 9
Reset counter: 134
Mileage: 325930 km
Date: 2018.04.15
Time: 17:42:10
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.10
Time: 03:28:48
Fault Status: 00100001
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.18
Time: 09:44:45
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.18
Time: 09:45:07
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.18
Time: 09:45:07
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.10
Time: 03:28:48
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C074210CF3
Coding: 3FFD0E04D31002
VCID: 211FE3826DC1A4BFE69-8074
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.07
Time: 21:01:24
02638 - Enabling Steering Column Lock
Fault Status: 00101100
Reset counter: 134
Mileage: 327919 km
Date: 2018.12.07
Time: 21:12:23
Address 1C: Position Sensing
Address 25: Immobilizer
Address 44: Steering Assist
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 56: Radio
Address 62: Door, Rear Left
Address 65: Tire Pressure
Address 72: Door, Rear Right
End----(Elapsed Time: 05:18, VBatt start/end: 13.3V/12.8V. VIgn 0.0V)------
