I'm original owner of this car and everything worked perfectly until this keyless issue. Looking for guidance to resolve.
Beetle is exercised regularly but had sat resting in garage for a few weeks over the holidays.
When tried to start it after long rest discovered the 5 year old DieHard battery had died.
Replaced the battery and everything works _except_ keyless entry!?
Have original key fobs and car does not respond to either remote.
Tried re-programing keyless procedure in owners manual few times but no work.
Got out the trusty VCDS and tried reprogramming keyless using VCDS video: https://www.youtube.com/watch?v=qiYPmebh0fg
still no work!
found fault 01179 - Incorrect Key Programming and cleared it then retried VCDS method again but no response from car to remote.
and fault 01179 came back!
clear fault, retry VCDS method, no response 01179 is back
repeat a few more times carefully checking the steps, still no response 01179 comes back
is there some different VCDS procedure that works for these older cars after replacing a dead car battery?
here's my scan
still no work!
here's my scan
Friday,10,January,2020,18:07:52:24453
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: 3VWCK21Y53M3xxxxx License Plate:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCK21Y53M3xxxxx Mileage: 250120km-155417miles
Address 01: Engine Labels: None
Part No: 06A 906 032 KC
Component: 2l ULEV NB-C A6 G 4795
Coding: 00003
Shop #: WSC 00066
VCID: 698CB718106C1A1F7E9-513C
3VWCK21Y53M301580 VWZ5Z0B9228194
Part No: 09G 927 750 N
Component: AQ 250 6F 0302
Coding: 0000008
VCID: 3C223E4C2A7E5FB7D5F-513C
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 33301570072090CF045-513C
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 E
Component: 08 AIRBAG VW7 0418
Coding: 0012344
VCID: 392C2758254C6A9FCE9-513C
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 941 L
Component: KOMBI+WEGFAHRS. M73 V03
Coding: 03234
VCID: 290CF718D0ECDA1FBE9-4B00
Part No: 6N0 909 901
Component: Gateway K<->CAN V032
Coding: 00006
Shop #: WSC 00066
VCID: 70BADA7C33B6EBD7397-4B00
Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
Part No: 1Y0 959 255
Component: VSG NBC ?
VCID: 7DA4F34871E496BFA21-513C
Part No: 1C0 959 799 G
Component: 6J Komfortger?t HLO 0004
Coding: 00256
Shop #: WSC 00066
VCID: 3B203D502A70588FDC5-4B00
Subsystem 1 - Part No: 1Y1959801
Component: 6J T?rsteuer.FS KLO 0001
Subsystem 2 - Part No: 1Y1959802A
Component: 6J T?rsteuer.BF KLO 0001
Subsystem 3 - Part No: 1Y0959811
Component: 6J T?rsteuer.HL KLO 0001
Subsystem 4 - Part No: 1Y0959812
Component: 6J T?rsteuer.HR KLO 0001
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 180 E
Component: RADIO 3CP 0002
Coding: 06401
Shop #: WSC 00066
VCID: 1A6ED8D4858A4187273-4B00
End----------(Elapsed Time: 03:51, VBatt start/end: 12.5V/12.4V)-----------
