Security Code Needed for O3/ABS channel IDE03493-Driver door status
TWs/VW
NW Florida
C?ID=369048
First, I'm trying to deactivate the automatic EPB when the driver's door is opened. I think the subject adaptation channel may do the trick, but I've not been able to find a security code that successfully works. I've tried all listed below without success; most are accepted initially, but not for this specific adaptation channel. There is a chance I made a miss-step along the way that caused one of these security codes, although correct, to fail - but I don't think so. So, if anyone can confirm what security code actually did work in changing O3/ABS channel IDE03493-Driver door status: from "activated" to "not activated", please post...
Thank you, everyone,
TW
10505
10815
11966
15081
18573
19249
20103
24435
24990
25004
25757
28183
31857
37202
40168
40304
44595
Wednesday,15,January,2020,12:04:16:27651
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN:    License Plate:
Mileage: 14654km-9105mi   Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 69
          6C 6D 75 A5 CA D6 D7
VIN:    Mileage: 14654km-9105miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC)       Labels: None
   Part No SW: 03H 906 026 AA    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 6694
   Revision: 52H21000
   Coding: 012A003244740108B0000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM36FSI01103H906026AA 001005
   ROD: EV_ECM36FSI01103H906026AA.rod
   VCID: 6491AD249EDD7F174DF-8030
   CAN Converter 01:
   Part No SW: 09G 927 158 DR    HW: 09G 927 158
   Component: AISIN AQ8     206 3536
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 065597AC48A1ED07F3B-8052
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 53468000000124
   Coding: 44FC6B8D84231A6DC57F0203A2C66922D62158A34045967038415058C2A2420B0023641C12141A1D8DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: 77ABEA683F4B848FF8D-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0497749765
   Coding: 1F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43D34EB83B13182F945-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11358006
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CN 907 044 L    HW: 3CN 907 044 L
   Component: Climatronic   H04 2009
   Revision: 00001K03
   Coding: 1602002620001C001104210C5210142C
   ASAM Dataset: EV_ACClimaBHBVW416 002012
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 48C9599402353B77417-801C
   Fresh Air Blower Back:
   Part No SW: 5Q0 937 085 BT    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H38 0273
   Serial number: 8335010201ÿÿÿÿ
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0C41A58456CD9757A5F-8058
   Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  052 0122
   Serial number: S7Y18M10D30H02M31S58
   Coding: 00382D
   Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z01QP02
   Coding: 150000
   Garage Door Opener Operating Unit:
   Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
   Component: GTO BF  H06 0007
   Serial number: 8MW00130091800010032
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0300091220180C205828
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R18341
   Coding: 0471155111
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC16584164DD75765F-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3200074959FFC728949C810530401600000000000000000004
   VCID: 44D14DA43E1D1F17ADF-8010
   Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
   Component: Airbag VW21   006 0713
   Revision: --------    Serial number: 003SUMKVWKQe
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B43A69853C3906FAC5-805E
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J18000ARK0B0D
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 002 910 18
   Serial number: 35700000000424496236
   Subsystem 3 - Part No SW: -----------    HW: 454 001 110 18
   Serial number: 35800000000D0A78623M
   Subsystem 4 - Part No SW: -----------    HW: 454 801 212 18
   Serial number: 3510097AC3F17000000U
   Subsystem 5 - Part No SW: -----------    HW: 454 802 711 18
   Serial number: 35200E3FA1F17000000X
   Subsystem 6 - Part No SW: -----------    HW: 454 802 111 18
   Serial number: 35500096FEC16000000X
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 111 18
   Component: FrontSensor_P  304 0149
   Serial number: 356009120BA16000000B
   Part No SW: 3CN 920 891 B    HW: 3CN 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BA40F1D6F88CF0502886B0B50010000A0000000
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 26111800842619
   Coding: 0B0100347F087300FA0002581C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D2738405DF76EDFE21-8068
   Component: 1-01-0e-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 33180001692630031439
   Coding: 2EFFFF
   Serial number: 1795406200
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0890
   Serial number: B007541
   Serial number: 18000331561015
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 33331E786BB3A8AF045-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RJG33148
   Coding: 0010000000000500018280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   Serial number: 0500310573
   Coding: 02012103
   ROD: EV_HREntryHella_VW27.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0501777184
   Coding: 020121
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YA008RKM004U2
   Coding: 00341B200200020000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001319046
   Coding: 011000
   Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
   Component: EPS_MQB_ZFLS  570 1582
   Coding: 191F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 47CB5AA80F2B340F48D-8012
   Component: FCM MQB Low   002 0345
   Serial number: 03121800841225
   Coding: 000000070900134A00010000000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 3537206065C7B69F2A1-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YA008RK500QUA
   Coding: 003413200E00020000000000
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001321896
   Coding: 091000
   Part No SW: 3QF 035 876 A    HW: 3QF 035 876 A
   Component: MU-S-NS-US    853 0890
   Coding: 02140602FF00000051220001001808001F0506E401200405CE
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV2910251
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0497745983
   Coding: 0200000200000000
   VCID: 40D941B42A050337897-8014
   Component: RVC Compact   H15 0231
   Coding: 01140602A3002017300040
   VCID: 392F2C5049DF52FFCE9-806C
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: A2-C758-8680-2
   Coding: 0988
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 45D750A03527261FBA1-8010
   Component: OCULowMQBUS   009 0570
   Coding: 02140602C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 1272
   Serial number: 21011941K22283
   Coding: 0004010600010201002213558150490084000E200100
   Shop #: WSC 56641 001 104857
   ROD: EV_MFKBoschMQBB_001_VW27.rod
   VCID: 0849999442B5FB77817-805C
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 00804074160C
   ROD: EV_SunRoofCONTIAU736_006.rod
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7BA3F6580363A0EF9C5-802E
   Component: LED1R         H06 0003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:58, VBatt start/end: 12.9V/12.9V)-----------
TBAx
C?ID=287144
Did you also try switching the diagnostic session?
TWs/VW
NW Florida
C?ID=369048
I apologize for my ignorance, but I'm not sure exactly what that means...
TBAx
C?ID=287144
VCDS offers the possibility to change the diagnostic session. You can change from standard diagnostics to engineering/development or end-of-line session for example.
This is a somewhat hidden feature and I was asked not to post a "how to" publicly, but you can send an E-Mail to Support@Ross-Tech.com and ask for the steps (possibly referencing this thread).
TWs/VW
NW Florida
C?ID=369048
Thank you TBAx, I really appreciate the experts help here. I love the Ross-Tech product - it's made car ownership exciting again!
TW
<< THIS MESSAGE WILL SELF DESTRUCT IN 5 SECONDS >>
Although this is unlikely the problem do make sure Adv measuring value IDE00323 -- Security Access: Number of invalid keys wasn't 3 or more. If it is over 2, perfectly valid SA codes may be rejected.
Also, Don't got a nice list here: https://forums.ross-tech.com/showthread.php?19270-MQB-platform-Security-Codes-work-in-progress
Edit, I didn't cross check these (many will be duplicates) but some of these may help: https://forums.ross-tech.com/showthread.php?6848-Security-Code-to-access-ABS-unit
TWs/VW
NW Florida
C?ID=369048
Thank you for the guidance Dana. I started with Don's list - none worked. The second list is new to me, I'll give them a try - would a difference in ABS Modules be relevant?
I should have added that the Number of invalid keys was never more than 1 and than returned to 0 with a new valid entry each time.
TW
... would a difference in ABS Modules be relevant?
Yes, that is entirely possible. Ideally you look for feedback specific to ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009 (the ASAM dataset followed by the version) however I'd keep it simple and just use as many generalized MQB ABS SA codes you can.
TWs/VW
NW Florida
C?ID=369048
Will do.
TW
TWs/VW
NW Florida
C?ID=369048
Security Access (SA) O3/ABS Brakes - channel IDE03493-Driver door status
SA 37203
03-ABS Brakes >channel IDE03493-Driver door status >activated/not activated
TW
quattro90
C?ID=402759
SA 37203
TW
Thank you. This information was helpful for my application.
