VW Polo 2014 1.4 diesel .Resetting calculated soot values
HOWIE
Ireland
C?ID=62065
Wednesday,15,January,2020,08:35:22:15783
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: Ballinlough Motors
VIN: WVWZZZ6RZFY169624   License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZFY169624   Mileage: 169138km-105097miles
Address 01: Engine (J000-CUSA)       Labels:. 04B-907-445-V1.clb
   Part No SW: 04B 906 027     HW: 04B 907 445
   Component: R3 1.4l TDI   H07 9151
   Revision: 21003001
   Coding: 01114032432501080000
   Shop #: WSC 09550 758 180955
   ASAM Dataset: EV_ECM14TDI03004B906027 003028
   ROD: EV_ECM14TDI03004B906027_003_VW26.rod
   VCID: 5EB85FFA410A32BFF5-800A
23902 - Diesel Particle Filter
          P2463 00 [163] - Excessive Soot Accumulation
                    Mileage: 169138 km
                    Date: 2020.01.13
                    Time: 20:25:30
                    Coolant temperature: 10 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 12.648 V
                    Counter for regeneration time of diesel particle filter: 10801 s
                    Particle filter: kilometers since last regeneration: 6183.3 km
                    Particle filter: soot mass measured: 1.30 g
                    Particle filter: soot mass calculated: 59.99 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -2.8 mbar
                    Particle filter: field regeneration lock status: 8
23967 - Diesel Particulate Filter
          P2458 00 [163] - Regeneration Duration
                    Mileage: 169138 km
                    Date: 2020.01.13
                    Time: 20:25:30
                    Voltage terminal 30: 12.664 V
                    Particle filter: field regeneration lock status: 235
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08501446140717
   Coding: 23DD2485892933C9091A106B0055C42491CC90080007C9098F00
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   VCID: 336EDE4E9A08CFD76A-8066
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0105
   Serial number:  1409111B-0793
   Coding: 201000001000000200
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D3A18F60C8C69A7AC-8048
262914 - Refrigerant Pressure
          B10AB F0 [013] - Too Low
                    Reset counter: 139
                    Mileage: 168729 km
                    Date: 2020.01.08
                    Time: 22:06:57
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 A    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0047
   Serial number: 009458012504
   Coding: 030008404253005B0BA44080B10703C800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_MQBA0.rod
   VCID: 2E58CF3A712AE23F05-807A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 801 BB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU016071441976394
   Coding: 1400A0
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 802 AT  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU016071441970449
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1421109M5
   Serial number: 00000000000029923859
   Subsystem 5 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU029091442726634
   Coding: 1400A0
   Subsystem 6 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU030091442736997
   Coding: 0400A0
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331426300487
   Coding: 0031051001
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3D7AF876AC4C09A78C-8068
1079089 - Center Rear Left Parking Aid Sensor
          B1077 31 [008] - No Signal
                    Fault Frequency: 8
                    Reset counter: 188
                    Mileage: 168808 km
                    Date: 2020.01.09
                    Time: 01:23:11
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag011 001 0330
   Revision: --------    Serial number: 003LM005CM76
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3162D4466014FDC718-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 820 309 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H009915DADB2A3A4
   Subsystem 2 - Part No SW: -----------    HW: 410 820 309 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00AD15FEE41C1A9
   Subsystem 3 - Part No SW: -----------    HW: 442 152 809 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C9176F5E3D11R
   Subsystem 4 - Part No SW: -----------    HW: 442 152 809 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C9176F5E6915V
   Part No SW: 6C0 920 941 A    HW: 6C0 920 941 A
   Component: KOMBI         211 0290
   Coding: 272409002180260001082A001000000000000000
   VCID: 234E2E0E2AE85F579A-8076
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0047
   Revision: --------    Serial number: 009458012504
   Coding: 030100044F0A590071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 65CA7016645C616734-8030
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2691416525301579AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61269I31472821829990
8782086 - Multi-Function Switches in Steering Wheel; Left
          B114B 96 [008] - Component internal failure
                    Reset counter: 182
                    Mileage: 168941 km
                    Date: 2020.01.10
                    Time: 12:50:17
                    Supply voltage: Terminal 30: 13.8 V
                    Terminal 15: On
8782087 - Multi-Function Switches in Steering Wheel; Right
          B114C 96 [008] - Component internal failure
                    Reset counter: 182
                    Mileage: 168941 km
                    Date: 2020.01.10
                    Time: 12:50:17
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CEA90447
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   Part No SW: 3Q0 035 820     HW: 3Q0 035 820
   Component: MU-S-D-ER     H11 0133
   Serial number: VWZAZ2P4582561
   Coding: 02620000BE00000011111201000808001F0100C60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 66C8771A995A6A7F3D-8032
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H43 1017
   Serial number: VWZ8Z9RH001QGH
          B201A 00 [009] - -
                    Reset counter: 137
                    Mileage: 168722 km
                    Date: 2020.01.07
                    Time: 01:57:05
                    Voltage terminal 30: 12.3 V
0522 - Front Left Bass Speaker
          B105F 13 [008] - Open Circuit
                    Reset counter: 188
                    Mileage: 169138 km
                    Date: 2020.01.13
                    Time: 02:46:12
                    Voltage terminal 30: 12.9 V
End-------------------------(Elapsed Time: 02:30)--------------------------
Hi I am having trouble with this Polo 1.4 d and the resetting of the calculated soot content. There is no facility in Vag com to tell the Ecu that the car has got a new Dpf.
The customer is not a regular and I never saw this car previously so I dont know its previous history.
I have tried resetting the ash content which is 4.98g to 1 in Adaption -10 IDE07903 -Adaption of ash mass section but the following window appears "This workshop identification WSC 09550 importer 758 equipment 180955 was rejected by the control module.The command will probably fail .Please change your values." I have tried a few oth er options in this Adaption -10 section and the same responce appears on the screen.
In Basic setting 04 and " service regeneration of particulate filter while driving" is activated the fault "Error :Service not supported in active session" appears.
In Security -16 ,when i try and access it and enter code 27971 the following "Controller refused to send a seed , error 7F: Service not supported in active session"
I have attached an external pressure gauge to the Dpf to make sure its clear and its ok. I rang the local dealer who are generally very helpful and their master tec said he never came across it and cant recall a TSB regarding that fault. Iam just wondering does anyone know a fix for this or is there a way to see if this car has been chipped.
Thanks.
Try setting some other values on the Options screen.
Once you set and save them there, you'll have to close VCDS and re-start it before those settings will take effect.
But you're right, I don't see an obvious "There's a new DPF installed" Adaptation or Basic Setting available in the data for that ECU.
You may want to check if there are any software updates available for that ECU. For "04B 906 027", 9151 (that you've got) does seem to be the latest, but it's also possible that an update will change the SW part number.
stylers
Ireland
C?ID=330936
In regards to the error "Service not supported in active session" doing adaptations I have found that you need to disconnect the session (go back to main VCDS screen) and turn off ignition and wait until the ECU powers down (wait until you hear the main Engine management relay click) and then go back in again.. with one of these polo's I found that doing the regeneration while driving it was difficult to tell when it had actually started - it wasn't obvious it was running and we had to drive the bag out of it on the motorway and keep watching the accumulated soot mass values slowly go down.. Then the faults cleared..
Owen.
HOWIE
Ireland
C?ID=62065
Just an update and a conclusion . I tried all the options suggested above but to no avail. I got on to another dealer near by and a very helpful mechanic ,I explained everything that I tried and he said at the present VW are not updating any Polo ecus on that particular model .if theres a problem- its a new Ecu. He did say if I booked it in to the dealers that he would look at it . After dropping it in to the dealers he rang me later and explained it was just a matter of telling the ecu that a new Dpf had been fitted. On my invoice it did say that I replaced a Dpf prior to going to dealers so maybe they are not supposed to reset unless they are told a new Dpf was replaced .
Everything good now and soot calculated value now reset . Thanks for yer help.
