Injector calibration query
NitrousOxide
Jamaica
C?ID=269481
I have replaced my injectors with new ones. The new ones idle rough anywhere below 850 RPM. Any RPM above that is OEM smooth.
How can I do the injector coding, or the calibration myself using VCDS?
Tuesday,14,January,2020,20:37:24:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078   License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078   Mileage: 189770km-117917miles
77-Telephone -- Status: Sporadic communication error 1000
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070160
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5EE744-8060
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 189756 km
                    Time: 08:06:36
                    RPM: 835 /min
                    Load: 25.9 %
                    Temperature: 91.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.462 V
Readiness: 0110 0001
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 05108020    Serial number: 00001009061622
   Shop #: WSC 04940 001 00001
   VCID: 1C192DFCDF37EFAF5B-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900D7AA-8026
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000014002
   Shop #: WSC 12345 123 61029
   VCID: 0021798C9B9F2B4FA7-8054
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 207
                    Mileage: 189756 km
                    Time: 08:06:28
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
                    Reset counter: 207
                    Mileage: 189756 km
                    Time: 08:06:28
   Revision: 00H54000    Serial number: 01000007456322
   Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
   VCID: 71C72C48683532C758-8024
   Component: Wischer 300807 021  0501
   Coding: 00039861
   Shop #: WSC 12345
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 12345
01502 - Bulb for Rear Fog; Left (L46)
                    Fault Status: 01101100
                    Reset counter: 207
                    Mileage: 189766 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.25 V
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86A78C-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012122
   VCID: 01277C8858952247A8-8054
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0006103
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 030312F2002329
   Coding: 350001
   VCID: 3A55CB64B5C3B19FA9-806E
                    Reset counter: 247
                    Mileage: 189767 km
                    Time: 08:50:27
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000564
   Shop #: WSC 11111 111 45799
   VCID: 3851D16C4BCFA38F5F-806C
00912 - Window Regulator Switch; Front Left (E40)
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 207    3305
   Revision: 00H22000
   Shop #: WSC 00028 028 00001
   VCID: 3753D25046D1ACF756-8062
   Coding: 98900A085103007F42040F0FF00A5A0690BC00
   VCID: 032B768042893057BA-8056
                    Reset counter: 206
                    Mileage: 189756 km
                    Time: 08:06:37
   Coding: 0000564
   VCID: 3957D46870C5BA87A0-806C
   Part No: 1T0 907 357
   Coding: 0000003
   Shop #: WSC 00000 785 00200
   VCID: 74C9255C172707EFB3-8020
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3180243
   Coding: 01000401000005
   VCID: 63EB560062C99057DA-8036
                    Reset counter: 206
                    Mileage: 189756 km
                    Time: 08:06:39
02633 - Antenna for Satellite Tuner
                    Reset counter: 206
                    Mileage: 189756 km
                    Time: 08:06:39
                    Reset counter: 206
                    Mileage: 189756 km
                    Time: 08:06:39
Address 77: Telephone
End-------------------------(Elapsed Time: 01:21)--------------------------
NEtech
Denmark
C?ID=56995
There is no coding for these Gasoline fuel injectors.
You can erase error code and save Adaptation channel 000
NitrousOxide
Jamaica
C?ID=269481
Thanks, I'll try it at operating temperature
Gone But Not Forgotten
Be careful the heater circuit isn't disrupting lambda crystal too from corrosion bridge, did you isolate it?
Are injectors genuine or knock offs, lots of problems with knock off injectors now?
NitrousOxide
Jamaica
C?ID=269481
This is what I'm trying to determine. I had bought them from the dealer, but the packaging appeared abused in storage. These were ordered by part number.
My symptoms are what appears to be misfires below 850 RPM, but they do not misfire on cold-starts when the idle is higher. I'm hesitant to remove them once again (until I buy a replacement set). My fear is breaking those brittle plastic clips that the injectors sit in before going into the head. I'm going to replace the cam position sensor as well (since they are cheap). My MVB for block 91 isn't showing the 28kW requested for the intake camshaft. However, I'm 95% sure that the timing belt and camshaft chain has been set properly.
This car had a broken timing belt at 108 KM/h resulting in 12 bent valves, so I replaced all 16.
Did you know a leaky injector can hide during cold start & since can be so rich for choke effect but so can a small air multiplicative leak?
Any trim codes?
