Hello.
I did retrofit Back-Up cam and a Pioneer head-unit to my Amarok. To do this I ordered a retrofit-kit for the camera similar to the one Kufatec sells (intended for the RCD-510). Then I ordered a conversion cable kit for the Pioneer head-unit. And another conversion-kit to connect "original" back-up camera to the Pioneer.
I then activated module 6C in CAN gateway list. Did the coding for the module, and I the camera works somehow as expected. My problem is that I can't get the calibration to register.
I go in to module 6C. Choose Security-Access and enter the pin as stated in the pop-up. It is accepted, so I go in to Adaptation, and follow the steps ending in changing value from 0 to 1 in the last step. All steps are accepted. I clear the fault-code, and go back in to fault-codes. The same error comes back.
Anyone able to help me? Any steps I missed?
Autoscan:
Autoscan:
[FONT=Verdana]Tuesday,14,January,2020,17:12:58:39202
www.Ross-Tech.com[/FONT]
[FONT=Verdana]
VIN: WV1ZZZ2HZCA064485 License Plate: RK77259
Mileage: 23120km-14366mi Repair Order: 03[/FONT]
[FONT=Verdana]--------------------------------------------------------------------------------
--------------------------------------------------------------------------------[/FONT]
[FONT=Verdana]
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 18 19 22 25 32 56 69 6C 77[/FONT]
[FONT=Verdana]VIN: WV1ZZZ2HZCA064485 Mileage: 23120km-14366miles[/FONT]
[FONT=Verdana]01-Engine -- Status: OK 0000
56-Radio -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0011
Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FA HW: 03L 907 309 K
Component: R4 2.0l BTD X43 9978
Revision: 26X43--- Serial number: 00000000000000
Coding: 01194012232600080000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
ROD: EV_ECM20BTD01103L906019FA_004.rod
VCID: 6FBBD41B57149E5F20D-803A[/FONT]
[FONT=Verdana]No fault code found.
Readiness: 0000 0000[/FONT]
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 G HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0106
Revision: 00H44001
Coding: B07324B6919A0D9924A689AB6F5510
Shop #: WSC 07456 790 49164
VCID: 34311B777E32FD871DF-8060[/FONT]
[FONT=Verdana]No fault code found.[/FONT]
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H0 907 047 C HW: 2H0 907 047 C
Component: Climatic-T5 H19 0404
Revision: 00001007
Coding: 0000000002
Shop #: WSC 07456 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 2809FF07B27A8967A17-807C[/FONT]
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 K HW: 6R7 937 087 K
Component: PQ25 BCM H27 0532
Revision: -1------ Serial number: 1009009900
Coding: 2C0000380C01000000280C103C4B94D50080410E60020000300000000000
VCID: 4CC1639706C2854765F-8018[/FONT]
[FONT=Verdana] Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Coding: 100000[/FONT]
[FONT=Verdana] Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
[FONT=Verdana] Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0061349
Coding: 020000[/FONT]
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00B H07 0013
Revision: -------- Serial number: 003HN007CSEI
Coding: 000000000000000000000000000000003042
Shop #: WSC 07446 790 50316
VCID: 3333186B7BBCFABF045-8066[/FONT]
[FONT=Verdana] Crash sensor for side airbag: driver side:
Serial number: 3495RRB40670VC0KO8TC[/FONT]
[FONT=Verdana] Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB404V0VC0KK9A4[/FONT]
[FONT=Verdana] Crash sensor for front airbag: driver side:
Serial number: 3555YRB405B134DQHGDV[/FONT]
[FONT=Verdana] Crash sensor for front airbag: front passenger side:
Serial number: 3565YRB40650V8BO7PA7[/FONT]
Part No SW: 2H0 920 861 B HW: 2H0 920 861 B
Component: KOMBI H02 0505
Coding: 150A00
VCID: 2615F13FB86E9F1793B-8072[/FONT]
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0010031
Shop #: WSC 07456 000 09999
VCID: 2411EB37C2D26D078DF-8070[/FONT]
Part No SW: 6N0 909 901 HW: 6R7 937 087 K
Component: GW-K-CAN TP20 H27 0532
Revision: -1------
Coding: 742000
Shop #: WSC 07462 790 50316
VCID: 70B9D7674AAA81A7397-8024[/FONT]
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IYC34413PZH3
Coding: 0000013
VCID: 2F3B141B9B14DE5F60D-807A[/FONT]
Component: IMMO H02 0505
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC50F6CF67B77773-803E[/FONT]
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 10.03.12 00
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C010317A682A54745F-8078[/FONT]
Address 56: Radio
Cannot be reached[/FONT]
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030021836
Coding: 0100000100000000
VCID: 303917678A2AC1A7797-8064[/FONT]
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 2H0 907 441 HW: 2H0 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525 PA8J2Z0169
Coding: 0010717
Shop #: WSC 98765 666 38384
VCID: 6393A82B875C2A3FB45-8036[/FONT]
[FONT=Verdana]1 Fault Found:
03006 - Back-up Camera System not calibrated
Reset counter: 25
Time Indication: 0[/FONT]
[FONT=Verdana]
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661841667
Coding: 0F00010000010101
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BFC3BBF64861FA8D-8072[/FONT]
[FONT=Verdana]2 Faults Found:
B104F 13 [009] - Short to GND
Reset counter: 25
Mileage: 23120 km
Date: 2020.01.14
Time: 17:07:44[/FONT]
[FONT=Verdana]9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 25
Mileage: 23120 km
Date: 2020.01.14
[FONT=Verdana]
End----------(Elapsed Time: 01:06, VBatt start/end: 14.3V/14.3V)-----------
[/FONT]
