2015 Golf Sportwagen TDI SE Manual
candypanda
Maryland, USA
C?ID=380507
Here is a scan for my 2015 Golf Sportwagen TDI SE Manual Transmission with Fender Audio and Lighting Package.
Sunday,17,November,2019,16:36:02:15331
VIN: 3VWFA7AU5FM504175   License Plate:
Mileage: 44888km-27892mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75
VIN: 3VWFA7AU5FM504175   Mileage: 44888km-27892miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 M    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9458
   Revision: 85H23---
   Coding: 01190012032410081000
   Shop #: WSC 09460 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997022M 004002
   ROD: EV_ECM20TDI01104L997022M.rod
   VCID: 3A2D322F6CDC27E7C73-806E
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 50115000000059
   Coding: 04FA6AA1242009700078020781C82520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 47CB5BDB2F2E4A0F48D-8012
   Revision: 00021000    Serial number: 0357621208
   Coding: 030C0C
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104200100000000000000000000
   VCID: 46D556DF28245307B3B-8012
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
329220 - Motor for Air Distribution Flap
          B109D 71 [008] - Actuator stuck
                    Reset counter: 217
                    Mileage: 43711 km
                    Date: 2019.10.31
                    Time: 12:20:57
                    Voltage terminal 30: 13.2 V
                    Outside air temperature: 20.5 ∞C
                    Air distribution flap: actual value: 212
                    Air distribution flap: actual value: 69.0 %
                    Air distribution flap: specified value: 26
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Revision: --------    Serial number: 86581601150534
   Coding: 00510A464041A26969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACD62EF3C3CB767573-801E
   Component: WWS    140824  043 0581
   Serial number:         150223110311
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y14M11D24H04M55S07
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H02 0003
   Serial number: 0000FST00033UEE00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H02 0003
   Serial number: 0000FST00033UJJ00000
   Coding: 191800
919560 - Light Switch
          B126A 29 [136] - Signal Implausible
                    Reset counter: 245
                    Mileage: 44663 km
                    Date: 2019.11.15
                    Time: 09:53:00
                    Fault Frequency: 55
                    Reset counter: 247
                    Mileage: 38913 km
                    Date: 2019.09.18
                    Time: 17:55:40
   Serial number: 003GCR016KBA
   ROD: EV_AirbaVW20SMEVW37X.rod
   Occupant Detection:
   Serial number: IBH0000J150002EU5B04
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 001 501 15
   Serial number: 35700000000F8459821O
   Subsystem 3 - Part No SW: -----------    HW: 480 001 312 14
   Serial number: 358000000009886D321N
   Subsystem 4 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 3510002A1196FF433282
   Subsystem 5 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 3520002C3196FF4561EH
   Subsystem 6 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 3550002AD196FF4183BP
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 3560002B3196FF4350CE
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150120400290
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04518CD75E98A117EDF-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA412122980CF0502086A001000000000000000
   Shop #: WSC 00066 790 00149
   VCID: 6597B153B5E2781F5A1-8030
   Revision: --------    Serial number: 10021510000407
   Coding: 0901000800087300EF00000A080F00000001050000000000000000000000
   Shop #: WSC 00066 790 00226
   ROD: EV_GatewConti_011.rod
   VCID: 72BDDA0F742C9FA7CF3-8026
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 27150000328030015083
   Coding: 30FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0022723
   Revision: 00000000    Serial number: 15000006479003
   Coding: 5500000000000000
   Shop #: WSC 00066 790 00123
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311C174EB8D1971DF-8060
   Serial number: 260115060502S3
   Coding: 003A13200000040000000000
   VCID: 40D940C70A007D37897-8014
   Serial number: 00000000000000596399
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D34FCB1B16662F945-8016
   Serial number: 100215060504U5
   VCID: 3FDB433B77FE02CFF0D-806A
   Serial number: 00000000000000725672
   Coding: 091000
   Coding: 060A00010B000400
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B01401152296
   Coding: 027302000000000021220002001800001F0100340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6491AC57BED801174DF-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS50199H
          B11CF 53 [009] - Deactivated
                    Reset counter: 59
                    Mileage: 38828 km
                    Date: 2019.09.17
                    Time: 09:30:48
                    Voltage terminal 30: 13.5 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 12.3V/12.3V)-----------
