2017 Jetta GLi CECM Byte18
Leomk6gli
Philadelphia, USA
C?ID=391002
In need of some help, I was scrolling through 09 Cecm - Coding going past byte 18 I mightve accidentally changed the setting, not knowing I clicked do it, now my Led drls only work with the headlights off and my outer brake lights are completely inop, Im geting a open or short to power code. I've tried changing the long coding manually and coping and pasting the original l long coding. any help would be great, fairy new to vcds
Monday,13,January,2020,19:01:36:16162
VIN: 3VW5T7AJ1HM319085 License Plate:
Gateway Installation List: 7N0 907 530 BL
NostraJackAss
Retrofits....?
Welcome to the VCDS forum OP!
Did you archive an old auto-scan and JPPSG?
Is your VCDS system setup & configured for WSC, tester # & importer number?
Please post the entire auto-scan not just the installed list.
Leomk6gli
Philadelphia, USA
C?ID=391002
Thank you, nope not retrofit & no I didn't archive an old auto scan or "jppsg?"
Sorry not familiar with these term I'm a noob to vcds
Wednesday,15,January,2020,16:24:28:16162
Mileage: 54540km-33889mi   Repair Order: CECM
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
  Component and/or Version: BCM PQ35 H+   122 0184
           Software Coding: EF200A3A902F06D4018800812400854C0070000845A08DB2E4802000A040
            Work Shop Code: WSC 00066 123 12345
                      VCID: 7DA7FE14FDF29CCFA21-8028
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101010
                    Fault Frequency: 77
                    Reset counter: 254
                    Mileage: 54473 km
                    Date: 2020.01.13
                    Time: 23:08:33
                        Term 15 Off
                    Voltage: 12.95 V
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                    Fault Frequency: 133
                    Reset counter: 254
                    Mileage: 54473 km
                    Date: 2020.01.13
                    Time: 23:05:55
                    Voltage: 13.75 V
03545 - Right Brake Light Lamp 2
                    Fault Status: 01101010
                    Reset counter: 211
                    Mileage: 54473 km
                    Date: 2020.01.14
                    Time: 10:19:35
                    Voltage: 14.15 V
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 5F
          62 72 75
VIN: 3VW5T7AJ1HM319085   Mileage: 54540km-33889miles
Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BL    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 3686
   Revision: --H13---
   Coding: 00190012242400171000
   Shop #: WSC 00066 790 00187
   ASAM Dataset: EV_ECM20TFS02006K906071BL 001005
   ROD: EV_ECM20TFS02006K906071BL.rod
   VCID: 76B5E138D844CF97E3B-8022
Readiness: 0010 0101
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B600C49230003850B06EC921E00412118F02A
   Shop #: WSC 00066 000 00000
   VCID: 75B7E634C5C2C48FEA1-8020
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0424987935
   Coding: 032C0C
   Shop #: WSC 00066 000 00295
   VCID: 392F2A04A9DA60EFCE9-806C
   Part No SW: 1K8 907 044 CN    HW: 1K8 907 044 CN
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 0050019002
   Shop #: WSC 00066 000 00318
   VCID: 7DA7FE14FD729CCFA21-8028
   Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
   Component: BCM PQ35 H+   122 0184
   Revision: BL122001
   Shop #: WSC 00066 123 12345
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 231116 04  42  0106
   Coding: 0228DD
                    Fault Frequency: 77
                    Reset counter: 254
                    Mileage: 54473 km
                    Date: 2020.01.13
                    Time: 23:08:33
                        Term 15 Off
                    Voltage: 12.95 V
                    Reset counter: 254
                    Mileage: 54473 km
                    Date: 2020.01.13
                    Time: 23:05:55
                    Voltage: 13.75 V
                    Reset counter: 211
                    Mileage: 54473 km
                    Date: 2020.01.14
                    Time: 10:19:35
                    Voltage: 14.15 V
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331633106718
   Coding: 0071155001
   Shop #: WSC 00066 790 00318
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372B2C3C9FCE769F38D-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0A2S73
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW32.rod
   VCID: 6393A86C7BD64A3FB45-8036
   Serial number: IBH000000000006DG2C9
   Coding: 30314C
   Subsystem 2 - Part No SW: -----------    HW: 480 000 712 16
   Serial number: 35700000000722A86029
   Subsystem 3 - Part No SW: -----------    HW: 480 000 712 16
   Serial number: 35800000000032A86024
   Subsystem 4 - Part No SW: -----------    HW: 480 020 711 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B7232EA26155Z
   Subsystem 5 - Part No SW: -----------    HW: 480 020 112 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001AF231F2C4021Z
   Subsystem 6 - Part No SW: -----------    HW: 480 020 401 17
   Component: FrontSensor_D  000 0189
   Serial number: 3550001992393D62F48B
   Subsystem 7 - Part No SW: -----------    HW: 480 020 401 17
   Component: FrontSensor_P  000 0189
   Serial number: 3560001992393D639353
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20161228300594
   Coding: 0002440008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F5B041CF77E8EDFB0D-802A
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160001607970076346
   Coding: B0FFFF
   Part No SW: 5C6 920 986 C    HW: 5C6 920 986 C
   Component: KOMBI         H02 1104
   Coding: 221C010000
   Shop #: WSC 00066 123 00318
   VCID: 3333182C8BB69ABF045-8066
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 11121603010320
   Coding: 351032
   VCID: 7BA3F00CE3E692FF9C5-802E
   Component: IMMO          H02 1104
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC5489CFC1B77773-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000221600008
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 313F122471AAA8AF769-8064
   Serial number: 0422642838
   Coding: 02011102
   Shop #: WSC 00066 790 00295
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C213310A6E855C7D5F-8068
   Lane Change Assistant 2:
   Serial number: 0423358633
   Coding: 020111
   Part No SW: 561 959 701 B    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0631
   Revision: 13100010    Serial number: 0010792419
   Coding: 0404BD
   Shop #: WSC 00066 790 00082
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 1D67DE941D323CCFC21-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14202745170103064149
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F2A04A55A60EFCE9-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0115940
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 2809FF404270E967A17-807C
9637138 - Loudspeaker 2 in Double-Subwoofer
          B130D 12 [009] - Short to Plus
                    Reset counter: 211
                    Mileage: 54473 km
                    Date: 2020.01.13
                    Time: 23:00:49
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 01030100
   VCID: 6FBBD45CA79EFE5F20D-803A
   Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST001BG5JG00000
   Coding: 180000
   Part No SW: 561 959 702 B    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0631
   Revision: 15100010    Serial number: 0010799857
   Coding: 0404BC
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 1E65D998103427D7DBB-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744161219123347
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H31 0359
   Serial number: VWZAZ2S0693614
   Coding: 02630102AA00000051220003001808009F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2411EB703E580D078DF-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
          B11CF 53 [009] - Deactivated
                    Reset counter: 211
                    Mileage: 54473 km
                    Date: 2020.01.13
                    Time: 23:09:24
                    Voltage terminal 30: 12.6 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140559
   Coding: 02630102C24232107F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1471BBB0EEF87D877DF-8040
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
If you did an Auto-Scan prior to this, VCDS archived it for you in your Scans sub-folder.
Also look in the Debug sub-folder for the CodingLog and AdpLog files as described here.
Just for info, and not terribly applicable in this case, you can read about JPPSG here.
