VW Transporter T6.1 ROD data
exploria
C?ID=293062
Hi i am trying to access some coding information for the new 2020 VW Transporter T6.1
in some of the modules VCDS is saying it could not find the ROD data for the UDS controller and to contact ross tech for assistance
i have attached a copy of an auto scan from this vehicle but have checked 2 new 6.1s both with the same result.
Monday,13,January,2020,13:58:45:64124
Dealer/Shop Name: Exploria Ltd
VIN: WV1ZZZ7HZLH023411   License Plate:
Mileage: 1   Repair Order: democamper
Chassis Type: 7H-VN75 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 20 44 55 5F 69 6D 75 D6 D7
20-High Beam Assist. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CXEC)       Labels: None
   Part No SW: 04L 906 056 RQ    HW: 04L 907 445 N
   Component: R4 2.0l BTD   H01 9970
   Revision: 23401001
   Coding: 002540144374050800000000000000000000000000000000
   Shop #: WSC 00012 790 00059
   ASAM Dataset: EV_ECM20BTD03004L906056RQ 004005
   ROD: EV_ECM20BTD03004L906056AG.rod
   VCID: 0D465F3EDDDEF9AFB21-8058
Readiness: N/A
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0BT 300 046 N    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3108
   Revision: 00H06V09
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 41DEB30ED1066DCF869-8014
   Part No SW: 7LA 614 517 A    HW: 7LA 614 517
   Component: ESC_high      H01 0700
   Serial number: 08512631191113
   Coding: 11552452C849E688885824A513676706393720B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X.rod
   VCID: 3D26CFFEADFE092FE21-8068
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 7LA 907 426 A    HW: 7LA 907 426 A
   Component: AC Manuell    H01 0502
   Coding: B03110000810000001000800504001050000000000011000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: N/A
No ASAM data for: "EV_AirCondiBHTCT6PA" (VN75)
459025 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:09
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01101932400713
   Shop #: WSC 00012 790 00040
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_204.rod
   VCID: 74B02ADADE348867DDF-8020
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000033022289
   Coding: 1F0007
   Subsystem 2 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000035231763
   Coding: 050007
   Serial number: 00000000000047853084
9 Faults Found:
10506 - Bulb for Left Tail Light
          B12BE 15 [009] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 10:54:30
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: not activated
                    Zusaetzliche Umgebungsdaten-OFF: not activated
                    Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                    Zusaetzliche Umgebungsdaten-Parking light: not activated
                    Zusaetzliche Umgebungsdaten-Parking light left: not activated
                    Zusaetzliche Umgebungsdaten-Parking light right: not activated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 0
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
10762 - Bulb for Right Tail Light
          B12BF 15 [009] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 10:54:30
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [009] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:46:37
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.3 V
331786 - Relay Output for Heated Exterior Mirror(s)
          B1730 15 [009] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 11:20:44
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.4 V
527872 - Transport Mode Active
          U1105 00 [008] - -
                    Reset counter: 41
                    Mileage: 5 km
                    Date: 2019.12.14
                    Time: 01:47:48
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
534549 - Databus
          [FLA_01 Datenbus fehlende Botschaft]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:12
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.0 V
592652 - Dimmer Switch; Driver Side
          B1752 01 [009] - Electrical Failure
                    Fault Frequency: 35
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 10:47:04
609292 - Unknown Error Code
          B1A75 F0 [008] - Unknown Error Elaboration
                    Reset counter: 42
                    Mileage: 8 km
                    Date: 2020.01.09
                    Time: 16:42:54
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.0 V
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [009] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:06
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419322
   Coding: 0459051911
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_003.rod
   VCID: 50F8864A0A6C9447197-8004
1113875 - Parking Aid Indicator Lamp
          B10FF 13 [009] - Open Circuit
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:06
Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3200670A01FF8748949C815580508700000000000000000004
   VCID: 43D2B906CB1A7FDF945-8016
0110 - Transport Mode Active
          U1105 00 [008] - -
          [FAULT_SYC_TRANSPORTMODE_ACTIVE]
                    Fault Frequency: 15
                    Reset counter: 41
                    Mileage: 5 km
                    Date: 2019.12.14
                    Time: 01:47:46
                    Voltage terminal 15: 12.3 V
                    Control Module temperature: 27 °C
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    013 0506
   Revision: --------
   Coding: 8800C00000000000800000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F5AF5F6E772DB3FB0D-802A
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:06
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 11:05:09
9446675 - Redundant signal path for airbag shut-off; passenger side
          B1025 13 [137] - Open Circuit
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 11:05:09
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [137] - Open or Short to Ground
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:06
Address 17: Instruments (J285)       Labels: None
   Part No SW: 7LA 920 941     HW: 7LA 920 941
   Component: KOMBI         204 6750
   Coding: 27A40A0A2580260001882A011401000000200000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: N/A
   VCID: 7DA60FFEED7EC92FA21-8028
No ASAM data for: "EV_DashBoardVDDMQBAB" (VN75)
16777018 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:15
16777020 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:15
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 20111910801907
   Coding: 030100344F05730401100018100F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 70B826CAAA2CB447397-8024
   Component: 4-00-11-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036336191125
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 773433010019111703D4
131632 - High Beam Assistant Control Module
          U1070 00 [009] - No Communication
          [Timeout Knoten 0x30 / 20 - Steuergerät für Fernlichtassistent]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:07
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [009] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Fault Frequency: 15
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 11:35:25
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
Address 20: High Beam Assist.
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: N/A
   VCID: 45D6A71EC52E41EFBA1-8010
No ASAM data for: "EV_SteerAssisMNB" (VN75)
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 0C8E020009200003
   ROD: N/A
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VN75)
13705478 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 2
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:08
Address 69: Trailer (J345)       Labels: None
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0039
   Serial number: 000000000005344
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: N/A
   VCID: 6B8231A6830A579F0C5-803E
No ASAM data for: "EV_TrailFunctGener3Hella" (VN75)
336920 - ROD - Unknown Error Code
          - 00 [040]
                    Mileage: 5 km
                    Date: 2019.12.16
                    Time: 01:29:24
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 7LA 959 107     HW: 4M0 959 107 C
   Component: HDSG-Modul    H14 0672
   Revision: --------    Serial number: A2-C769-9790-2
   Coding: 4180
   ASAM Dataset: EV_DeckLidCONTIVN46T 001017
   ROD: EV_DeckLidCONTIVN46T.rod
   VCID: 035279068B9ABFDFD45-8056
Address 75: Telematics (J949)       Labels: None
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000908NVHJ3
   Coding: 06462000196818208005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: N/A
   VCID: 015E730E9186ADCFC69-8054
No ASAM data for: "EV_OCUGen3Low" (VN75)
7 Faults Found:
9455892 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:51:06
1572115 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:46:39
9458195 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:19:40
9455635 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 14:17:41
9457171 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 11:33:16
12866049 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 11:05:10
2566 - ROD - Unknown Error Code
          - 00 [009]
                    Mileage: 19 km
                    Date: 2020.01.13
                    Time: 10:38:13
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X.rod
   VCID: 619E538E71C60DCFA69-8034
   Component: LED1R         H08 9002
End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.0V)-----------
any help would be appreciated thanks
Hi Greame,
Thanks for posting the scan. We have a (pre-release) Beta version that should resolve all of the ROD issues. I'll send you a link to it via e-mail so you can test it on
the T6.1s.
Best,
TBAx
C?ID=287144
Is this the 19.10 beta?
Hi Daniel,
Close, Beta 19.11 is the version we sent him. The RODs loaded as expected (which is great) and he's going to experiment with 17 coding tomorrow.
I don't know when the Beta will be available for customers so let us know if you are having any issues with the latest 2020 MY cars and we can get a link sent to you. To date, I've sent that to a handful of users with HEX-Net's or V2's so they could scan the latest Caddy and T6.1 models.
TBAx
C?ID=287144
When the MY2020 Caddy is included I would love to get a link by mail. :)
I just read somewhere, that there was a 19.10 beta with updated RODs for the T6.1, which wouldn’t help me, but if it contains stuff for the Caddy, I‘m hooked.
Do we have a scan from this Caddy to see what's missing in the existing release?
Uwe,
That's still the Mk6 based (Chassis Type: 2K-VN35 (7N0) | VIN: WV1ZZZ2K_L) but I know Release failed to load a 01-Engine ROD in at least one scan. I don't have a link handy to a broken scan but something like: EV_ECM20TDI01104L906016PA_VW36
I added a few redirects recently for labels but I'm confident some didn't make the latest DV that Seb sent you.
Daniel,
If you have access to a new Caddy please feel free to send a scan from it to Support. That will allow us to see what is, and isn't, covered in Release and we can get you a Beta link sent in reply.
NEtech
Denmark
C?ID=56995
I send (e-mail) one just after Christmas, but to late for customer to test with VCDS test version.
Styreenhed  01: Motor (J623-DFSD)     Forklaringsfil: Ingen
   Styreenhedsnr: SW: 04L 906 016 PM    HW: 04L 907 309 AB
   Komponent    : R4 2.0l TDI   H20 7038
   Revision    : 8EH20---
   Kodning    : 011D001A04240D090000
   Forhandler    : WSC 35110 790 50316
   ASAM datasæt    : EV_ECM20TDI01104L906016PM 004001
   ROD: Ikke tilgængelig
   VCID: 035388A36B997BDFD7B-8056
Ingen ASAM data tilgængelig for: "EV_ECM20TDI01104L906016PM" (VN35)
TBAx
C?ID=287144
Daniel,
Does the VCDS language matter for this? Or is it acceptable to sent you a scan from a german 19.6.x?
The language does not matter. The German one is perfectly fine.
TBAx
C?ID=287144
^Dana: Thank you for your kind E-Mail which slipped through until I found it today. ;/
Here is the Auto-Scan of the car in question:
Sonntag,24,November,2019,12:19:01:22059
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 8 x64
VCDS Version: DRV 19.6.2.1  HEX-NET CB: 0.4508.4
Datenstand: 20191020 DS308.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WV2ZZZ2KZLX014099   KFZ-Kennzeichen: B-XXXXXX
Kilometerstand: 330km   Reparaturauftrag: 1initial
Fahrzeugtyp: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 18 19 25 42 44 46 4C 52 5F 61 69
          A5
Fahrzeug-Ident.-Nr.: WV2ZZZ2KZLX014099   Kilometerstand: 330km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: Fehler 0010
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
4C-Reifendruck II -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: Fehler 0010
5F-Informationselek. I -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DJKD)       Labeldatei: Keine
   Teilenummer SW: 04E 906 025 AC    HW: 04E 907 309 EF
   Bauteil: R4 1.4l TFS   H20 9526
   Revision: DOH20000
   Codierung: 0019003A245415080000
   Betriebsnr.: WSC 35110 790 50316
   ASAM Datensatz: EV_ECM14TFS01104E906025AC 001003
   ROD: n.v.
   VCID: E386E13EEA0313575B-80B6
Keine ASAM Daten verfügbar: "EV_ECM14TFS01104E906025AC" (VN35)
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik (J104)       Labeldatei: DRV\7E0-907-37x-MK100ESC.clb
   Teilenummer SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Bauteil: ESC           H06 0133
   Revision: 00000000    Seriennummer: 62119000000978
   Codierung: 1079419BB363B4820875827FCD8B2DD378F5F0
   ASAM Datensatz: EV_Brake1ESCCONTIVN75XGP2 011001
   VCID: BFCE0D4E262B17B71F-80EA
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:| DRV\5K0-907-044.clb
   Teilenummer SW: 1K8 907 044 CG    HW: 1K8 907 044 CG
   Bauteil: Climatronic   H08 0405
   Revision: 00001K05
   Codierung: 0510004003
   ASAM Datensatz: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: F6A0A86A499196FF0C-80A2
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\1K0-937-08x-09.clb
   Teilenummer SW: 5K0 937 086 AD    HW: 5K0 937 086 AD
   Bauteil: BCM PQ35 M+   122 0193
   Revision: BD122001
   Codierung: 611A583A8025086F088800809440896C03550008626DAD60E484C7000045
   Betriebsnr.: WSC 35110 377 00146
   VCID: F6A0A86A419196FF0C-80A2
   Subsystem 1 - Teilenummer: 2K1 955 119 F  Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: Wischer 18071  61  0715
   Codierung: 009795
   Subsystem 2 - Teilenummer: 5K7 955 559 C  Labeldatei: DRV\5K7-955-559.CLB
   Bauteil: RLS 290719 05  50  0106
   Codierung: 0228DD
Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\5Q0-919-298.clb
   Teilenummer SW: 1K8 919 475 D    HW: 5Q0 919 298
   Bauteil: PARKHILFE PLA H12 0480
   Revision: --------    Seriennummer: 39431917501017
   Codierung: 0031061141
   ASAM Datensatz: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: BB36795E32330B9733-80EE
Adresse 13: Distanzregelung (J428)       Labeldatei:| DRV\7N0-907-572.clb
   Teilenummer SW: 7N0 907 572 C    HW: 7N0 907 572
   Bauteil: ACC Bosch PQx H03 0211
   Seriennummer: 0108190438A235
   Codierung: 00000800FE0339
   ASAM Datensatz: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: B620686A0911D6FFCC-80E2
1 Fehler gefunden:
0110 - Transportmodus aktiv
          U1105 00 [008] - -
          [FAULT_SCM_T_MODE_ACTIVE]
          Sporadisch - bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 18
                    Verlernzähler: 41
                    Kilometerstand: 2 km
                    Datum: 2019.08.27
                    Zeit: 06:24:25
                    Steuergerätetemperatur: 35 °C
                    Spannung Klemme 15: 12.6 V
                    Fahrzeuggeschwindigkeit: -0.01 m/s
                    Beschleunigung: -0.01 m/s²
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5K0-959-655.clb
   Teilenummer SW: 2K5 959 655 E    HW: 2K5 959 655 E
   Bauteil: VW10Airbag00G 010 0018
   Revision: --------    Seriennummer: 003EN003EJZP
   Codierung: 000000000000000000000000000000003047
   ASAM Datensatz: EV_AirbaVW10BPAVW12X 001028
   VCID: BE30704A21211EBF14-80EA
   Crashsensor für Seitenairbag Fahrerseite:
   Seriennummer: 3497ARB405T69P0GA84F
   Crashsensor für Seitenairbag Beifahrerseite:
   Seriennummer: 3507ARB40045I2JGVJ2B
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Seriennummer: 3517ARB405L6A87SMON7
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Seriennummer: 3527ARB405N6A87S99QS
Adresse 16: Lenkradelektronik (J527)       Labeldatei:| DRV\5K0-953-569.clb
   Teilenummer SW: 5K0 953 521 FJ    HW: 5K0 953 569 BC
   Bauteil: LENKS.MODUL   018 0230
   Revision: FF010042    Seriennummer: 20190708200226
   Codierung: 3082C60008
   ASAM Datensatz: EV_SMLSNGVOLWSR8C 001001
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: F9BAA356788FF98761-80AC
   Steuergerät für Multifunktionslenkrad:
   Subsystem 1 - Teilenummer SW: 2K0 959 442 A    HW: 2K0 959 442 A  Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-TAT  H06 0023
   Seriennummer: 1791918260900796BC1B
   Codierung: 2C0000
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
   Teilenummer SW: 2K5 920 886 D    HW: 2K5 920 886 D
   Bauteil: KOMBI         H03 2030
   Seriennummer: 00000000000000
   Codierung: 110E011300
   ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: B73E656E0E1B2FF7D7-80E2
Adresse 18: Standheizung        Labeldatei: DRV\1K0-815-007.clb
   Teilenummer: 7N0 963 272 B
   Bauteil: Standheizer     044 4942
   Revision: 00044000    Seriennummer: 09031870000000
   Codierung: 0031032
   VCID: B4245262D76DC4EFF2-80E0
Adresse 19: Diagnoseinterface (J533)       Labeldatei: Keine
   Teilenummer SW: 7N0 907 530 BR    HW: 7N0 907 530 AN
   Bauteil: J533  Gateway H56 1708
   Revision:   H56       Seriennummer: 130819F1000862
   Codierung: 357420
   VCID: 814ACBB6185FA14729-80D4
Adresse 25: Wegfahrsperre (J334)       Labeldatei:| DRV\5K0-920-xxx-25.clb
   Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
   Bauteil: IMMO          H03 2030
   Codierung: 000002
   ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EA988C1A0D29421F98-80BE
Adresse 42: Türelektr. Fahrer        Labeldatei:. DRV\1K0-959-701-MAX3.clb
   Teilenummer SW: 2K5 959 701 A    HW: 2K5 959 701 A
   Bauteil: Tuer-SG         009 2143
   Codierung: 0136242
   VCID: B228547A2D79CADFE0-80E6
1 Fehler gefunden:
00932 - Motor Fensterheber Fahrerseite (V147)
            005 - keine oder falsche Grundeinstellung/Adaption - Sporadisch
Adresse 44: Lenkhilfe        Labeldatei: DRV\1K0-909-14x-GEN3.clb
   Teilenummer: 1K0 909 144 R
   Bauteil: EPS_ZFLS Kl. 315    3501
   Revision: 00H22000
   VCID: B93A6356F00F398721-80EC
Adresse 52: Türelektr. Beifahr.        Labeldatei:. DRV\1K0-959-702-MAX3.clb
   Teilenummer SW: 2K5 959 702 A    HW: 2K5 959 702 A
   Codierung: 0136242
   VCID: B326517ED263C3D7EB-80E6
1 Fehler gefunden:
01035 - Fensterheber Thermoschutz aktiv; Beifahrer
            000 - - - Sporadisch
Adresse 5F: Informationselek. I (J794)       Labeldatei:| 5G0-035-MIB-STD2.clb
   Teilenummer SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Bauteil: MU-S-D-ER     H41 0475
   Seriennummer: VWZAZ2W0957251
   Codierung: 06330700BE00000011111101008808001F0100C40020010003
   ASAM Datensatz: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: AC144A02C75D9C2FAA-80F8
Adresse 61: Batterieregelung (J840)       Labeldatei:. DRV\1K0-907-534.clb
   Teilenummer SW: 7N0 907 534     HW: 7N0 907 530 AN
   Bauteil: Batt.regelung H56 1708
   Codierung: 332F1856
   VCID: F1AA9B7628FFB1C7D9-80A4
   Subsystem 1 - Teilenummer SW: 2K0 915 181     HW: 2K0 915 181
   Bauteil: J367-BDMConti  H03 1051
   Seriennummer: 75885803001908030B52
Adresse 69: Anhänger (J345)       Labeldatei:. DRV\1K0-907-383-V2.clb
   Teilenummer SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Bauteil: Anhaenger     H12 0130
   Revision: 3B001001    Seriennummer: 00000524009876
   Codierung: 010D000103000000
   VCID: B228547AED79CADFE0-80E6
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Bauteil: MQB_B_MFK     H12 0610
   Seriennummer: 25061915K20447
   Codierung: 010304020000040100220005C180490080000E10000000
   ASAM Datensatz: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002_VW36.rod
   VCID: C0CC0EB25BD5684F66-8094
Ende--------(Dauer: 01:13, Batt.-Spannung Start/Ende: 12.5V/12.3V)---------
I hope seeing this car again soon.
snfordonsinredning
Sweden
C?ID=338673
Same problem, ROD file missing.
Can i please try beta?
Best regards,
snfordonsinredning
Sweden
C?ID=338673
Hi,
Tryed to auto-scan, but sadly VCDS closed down wile scanning....
Is there a fix for that, so i can complete the Scan??
Hi,
It's almost unheard of for VCDS to "close down" while scanning without some kind of error message. Please try again, and if there is a message, please post a screen-shot.
snfordonsinredning
Sweden
C?ID=338673
I understand, but sad to say it happend, tryed 4-5 times with same result, of program shut down.
Thats Why ill come here, so i Can get your help ” to help others ” ofcourse.
Only this time we have had problem with VCDS, otherwise its a magic program for us.
Well, then you don't have "the same problem" that this thread started with.
Please start a new thread regarding your shut-downs. Please provide complete details regarding the computer you are using and the vehicle you are trying to scan.
snfordonsinredning
Sweden
C?ID=338673
Then ill have two problems, first one that program shut down wile auto-Scan, second one that ROD files are missing.
Yes, well, without seeing an Auto-Scan, we can't even begin to guess what might be causing a missing ROD problem, so we need to work on that first.
annsofie
VCDS.SE
Sweden
The customer has been in contact with Vagsmart regarding the two mentioned issues and I have had contact with the Ross-Tech support. I was however unaware of that there was a thread regarding the same issues. Joining out of curiosity. :)
I have just provided the customer with information from Ross-tech's support (D) on how to move forward.
/A
