Audi A1 1.6 tdi spport
AshB
Cumbria, UK
C?ID=309332
Audi A1 1.6 tdi sport
Its the wifes car and she doesn't do many miles in it but tonight on her way to work it started to loose power first thought was its gone into Regen mode as its a real pain in the ass for doing that but after a scan it shows some kind of injector fault .
The dash has the heater coil light flashing and a message of engine control module fault please take to nearest dealer .
If anyone has an idea of where to look to solve this please add a reply
thanks in advance :D
aturday,11,January,2020,22:10:57:56460
VIN: WAUZZZ8X1Bxxxxxxx   License Plate:
Chassis Type: 8X-AU21 (8X0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X1Bxxxxxxx   Mileage: 97970km-60875miles
   Part No SW: 03L 906 023 KN    HW: 03L 906 023 KM
   Component: 1,6L R4 CR td H53 9056
   Revision: --H53---    Serial number:
   Coding: 00114016030501080000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM16TDI02103L906023KN 003010
   ROD: EV_ECM16TDI02103L906023KM_003.rod
   VCID: 7CA2FCDE5666AF2795F-8028
9840 - Injector: Cylinder 4 (N33)
          P0204 00 [167] - Circuit Malfunction
                    Mileage: 97799 km
                    Date: 2020.01.11
                    Time: 22:04:49
                    Engine speed: 1347.00 /min
                    Normed load value: 49.0 %
                    Coolant temperature: 68 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 14.005 V
                    Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
                    Injector valve 3: capacity-CAPA_INJ_MAIN[2]: 23.7212 µF
                    Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]: 1428.9 µAs
                    Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]: 43.036 mJ
                    Supply voltage of analog output 1-VCC_1: 4.98 V
                    Supply voltage of analog output 2-VCC_2: 4.99 V
                    Injection valve 3: voltage-V_INJ_MAIN[2]: 60.23 V
Readiness: 1110 1000
Address 03: ABS Brakes        Labels:
   VCID: 55F4897A9C0C9E6FCA1-FFFE
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030004268934
   Shop #: WSC 00046 000 00000
   VCID: 343214FE3236A7671DF-8060
   Part No SW: 8X0 907 063 D    HW: 8X0 907 063 D
   Component: BCM PQ35  M   108 0621
   Revision: 00108 AC
   Coding: 0E000A2FA005F100201841E000000154430B6C0A00CF4122DC0087830041
   VCID: 3D2431DA0D7C662FE21-8068
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0010
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ001N8YL
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 48CA500E523E3387417-801C
   Serial number: 3554VRB405J0ESC6HHPI
   Serial number: 3575HRB405705NLMDGP1
   Serial number: 3585HRB40690CE323OS9
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB40690D6ISJO98
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20110407300278
   Coding: 1184004000
   VCID: 392C25CA19D45A0FCE9-806C
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
   Part No SW: 8X0 920 980 A    HW: 8X0 920 980 A
   Component: KOMBI         H07 0124
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
   VCID: 3D2431DA0DFC662FE21-8068
   Part No SW: 8X0 907 468 A    HW: 8X0 907 468 A
   Component: GAT 4CAN 1L M H04 0083
   Revision: 1C060023    Serial number: 2341C1131000BD
   Coding: FBCF005A000100010153
   VCID: 43D047226B9810DF945-8016
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Serial number: 00000000007100751331
   Serial number: 11097001034011200181
   Component: IMMO          H07 0124
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 B    HW: 8X0 959 793 B
   Component: TSG FA        H09 0409
   Coding: 011802200101000100
   VCID: 4CC26C1E46C6DFA765F-8018
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F381B92DE5084BF60D-807A
   Part No SW: 8X0 959 792 B    HW: 8X0 959 792 B
   Component: TSG BF        H09 0409
   VCID: 4BC06F0243C8D89F6C5-801E
   Part No SW: 8X0 035 183 B    HW: 8X0 035 183 B
   Component: RMC Cnct      H50 0647
   Coding: 01010000000051070023000103010000010000
   VCID: 36362EF6284AB57723B-8062
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462CY0B0098169
End----------(Elapsed Time: 01:18, VBatt start/end: 14.2V/14.3V)-----------
NostraJackAss
Did you check wiring to number 4 injector from controller using RTFB and WD and or swap injectors to isolate or see if fault moves?
Did you JPPSG yet?
AshB
Cumbria, UK
C?ID=309332
Did you JPPSG yet?
I did check the wiring the best i could with no tools to hand and just the flash light on my phone no loose connections or wires that looked bad other than that until i can get it home tomorrow at some point swapping injectors around and testing with a multi meter will have to wait :(
AshB
Cumbria, UK
C?ID=309332
Tried to use 08 measuring blocks i on vcds but the option is locked out so i had to use the advanced version . No what i cant work out is it seems injector 3 is the problem ( 2 from the scan as its numbered 0-3) IT seems as if their is no voltage at the injector so am i right in thinking that the injector has to send the information back to the control module for vcds to report the info ?????
  Address 01: Engine  (03L 906 023 KN)
07:01:09
  IDE00437-ENG99390   Injector valve 1: capacity-CAPA_INJ_MAIN[0] 6.5566 µF
  IDE00438-ENG103101   Injector valve 2: capacity-CAPA_INJ_MAIN[1] 6.5301 µF
  IDE00439-ENG102776   Injector valve 3: capacity-CAPA_INJ_MAIN[2] 0.0000 µF
  IDE00440-ENG104221   Injector valve 4: capacity-CAPA_INJ_MAIN[3] 6.5301 µF
  IDE03893-ENG101196   Injection valve 1: voltage-V_INJ_MAIN[0] 114.88 V
  IDE03894-ENG104143   Injection valve 2: voltage-V_INJ_MAIN[1] 114.14 V
  IDE03895-ENG101536   Injection valve 3: voltage-V_INJ_MAIN[2] 0.00 V
  IDE03896-ENG102925   Injection valve 4: voltage-V_INJ_MAIN[3] 113.91 V
  IDE05634-ENG103637   Voltage load of main injection cylinder 1-CHR_INJ_MAIN[0] 748.6 µAs
  IDE05635-ENG99789   Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1] 739.1 µAs
  IDE05636-ENG103475   Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2] 0.0 µAs
  IDE05637-ENG101402   Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3] 742.2 µAs
NostraJackAss
Maybe the stack is labeled wrong in controller, did you unplug each injector to corelate a block value?
AshB
Cumbria, UK
C?ID=309332
So just to add to the problems im having with the car i got my local garage to change injector 4 all fault codes gone and cleared (snap-on computer used) injector coded to the car and checked that the car has taken the coding but car now has a missfire at low revs and also you get diesel knock . My thinking here is either another injectors on its way out but not bad enough to throw a code yet or is there something that im missing .
HMC
C?ID=28246
Hi AshB
Was it a brand new injector? What does the garage that fitted it have to say?
Regards HMC
AshB
Cumbria, UK
C?ID=309332
Hi AshB
Regards HMC
Yes the injector was new the garage are struggling to understand it and have said see how the car runs over the weekend
What are balance tests as observed in blocks compared to other cylinders?
@Jack@European_Parts hopefully i have the right data for you
Scan after the injectors been fitted
Friday,17,January,2020,17:00:55:56460
VIN: WAUZZZ8X1BBxxxxxx   License Plate:
VIN: WAUZZZ8X1BBxxxxxxx   Mileage: 98000km-60894miles
Readiness: 0100 0000
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9437600B2CC2812E4C2DA00920C00
   VCID: 7F580BD247B0B43FB0D-802A
   Revision: 00108 AC
   Coding: 1184004000
   Coding: 41DE00
   Coding: 000002
   Coding: 11251
   Shop #: WSC 00046
End----------(Elapsed Time: 00:55, VBatt start/end: 14.7V/14.8V)-----------
16:48:31
  IDE00357-ENG99842   Fuel temperature-TFU 32 °C
  IDE00365-ENG99400   Injection amount deviation cylinder 1-FAC_CYL_BAL1 0.3895 mg/stroke
  IDE00366-ENG101187   Injection amount deviation cylinder 2-FAC_CYL_BAL2 0.2514 mg/stroke
  IDE00367-ENG101684   Injection amount deviation cylinder 3-FAC_CYL_BAL3 0.5125 mg/stroke
  IDE00368-ENG103465   Injection amount deviation cylinder 4-FAC_CYL_BAL4 -1.1629 mg/stroke  (the minus figure could this cause a problems ??? this is the new injector )
  IDE00437-ENG99390   Injector valve 1: capacity-CAPA_INJ_MAIN[0] 7.0498 µF
  IDE00438-ENG103101   Injector valve 2: capacity-CAPA_INJ_MAIN[1] 6.7848 µF
  IDE00439-ENG102776   Injector valve 3: capacity-CAPA_INJ_MAIN[2] 7.2316 µF
  IDE00440-ENG104221   Injector valve 4: capacity-CAPA_INJ_MAIN[3] 6.8705 µF
^^^^ I would defer my comments to Jack's more experienced response, but are you sure that the new injector is sealed properly?
A healthy capacitance value has been re-established for the new injector (see the new micro farad value -uF), which suggests that the electrical side is OK .
So, logic tends to point to a fuel side problem - perhaps the mating surface between the injector and the cylinder head is not properly sealed - or less likely, a dodgy internal seal in the new injector?
