Hi people!
The owner of a audi a3 changed the abs pump. Now i need the abs coding. I tried to code it and i got the following error: "Coding rejected Error 13: Incorrect message
length or invalid format"
Maybe the abs pump he changed doesn't match the car? or maybe there is someother problem im not seeing
Many Thanks.
Many Thanks.
Tuesday,31,December,2019,11:27:19:50280
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ8P29B004326 License Plate:
Mileage: 143490km-89160mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
VIN: WAUZZZ8P29B004326 Mileage: 143490km-89160miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 N HW: 03G 906 021 AB
Component: R4 1,9L EDC 000AG 3039
Revision: --H08--- Serial number: AUX7Z0H6FNA01T
Coding: 0000078
Shop #: WSC 00046 412 16384
VCID: B22842972DEB89DFE1-80E6
001138 - Exhaust Pressure Sensor 1
P0472 - 000 - Signal too Low
Fault Frequency: 27
Mileage: 143257 km
Date: 2018.12.25
Time: 22:51:04
RPM: 798 /min
Voltage: 14.14 V
Mileage: 70 km
Temperature: 120.0°C
Absolute Pres.: 887.4 mbar
Readiness: 1 1 0 0 0
Part No SW: 02E 300 050 R HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1702
Revision: 04843012 Serial number: 00000805310685
Shop #: WSC 04926 001 00001
VCID: A10ABDDB780D024708-80F4
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Shop #: WSC 00028 028 00001
VCID: FAB8AAB7751BB19F69-80AE
Fault Status: 00100101
Reset counter: 178
Mileage: 143256 km
Date: 2018.12.25
Time: 22:44:02
Count: 7
Count: 12
Count: 29184
Count: 212
Count: 41472
03306 - Coding Not Valid
Reset counter: 146
Mileage: 143495 km
Date: 2019.12.31
Time: 10:27:31
Count: 3
Count: 14
Count: 12288
Count: 4161
Count: 43008
Count: 256
Reset counter: 138
Date: 2018.12.25
Time: 22:40:23
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 44288
Fault Status: 01100101
Reset counter: 138
Mileage: 143256 km
Date: 2018.12.25
Time: 22:44:02
Count: 7
Count: 12
Count: 29184
Count: 279
Count: 41472
Reset counter: 138
Mileage: 143256 km
Date: 2018.12.25
Time: 22:44:02
Count: 7
Count: 12
Count: 29184
Count: 295
Count: 41472
Reset counter: 138
Mileage: 143256 km
Date: 2018.12.25
Time: 22:44:02
Count: 7
Count: 12
Count: 29184
Count: 270
Count: 41472
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000453 Serial number: 8P0820043BG
VCID: F2A88297ED6BC9DF21-80A6
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008590672
Coding: 10A82F8190141380EF00001C0000000000094A056401040100A800000000
Shop #: WSC 00046 412 08192
VCID: C8DC007FBB77130FAF-809C
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 00046
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 146
Mileage: 143444 km
Date: 2019.12.29
Time: 16:40:00
Voltage: 13.70 V
Fault Status: 01101100
Reset counter: 146
Mileage: 143256 km
Date: 2018.12.25
Time: 22:44:00
Voltage: 11.70 V
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030354A55304C38503053
Shop #: WSC 00046 412 00000
ROD: EV_Airba10AURB4.rod
VCID: C9DA057B687DEA07B0-809C
Serial number: 3572DRB40000779891E+
Serial number: 3582DRB40000764480DT
Serial number: 35128RB400003DDCF0F3
Serial number: 35228RB400003DBF1A7-
Serial number: 35547RB400003D5DE3C0
Serial number: 35647RB400003D5DDEA9
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0010002
Shop #: WSC 00046 412 565248
VCID: F8BCB0BF8B17A38F1F-80AC
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 S HW: 8P0 920 931 S
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2246H004014421
Coding: 0002028
Shop #: WSC 55521 002 1048576
VCID: C3C61753825130577A-8096
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K085228714
Coding: ED807F060002022102
Shop #: WSC 00046 412 24576
VCID: B522798BDC859EE7C4-80E0
Revision: D0H15004 Serial number: AUX7Z0H6FNA01T
Shop #: WSC 21150 133 94976
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000148
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 232 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: AA185AF7053BC11F59-80FE
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880202002186D0985054C8F0167
VCID: C5C2094B8C650E6754-8090
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000148
VCID: C4C4144F875F376F43-8090
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8J0 035 195 D HW: 8J0 035 195 D
Component: R Symphony2+ H15 0221
Revision: 00H15000 Serial number: AUZ1Z4G6060453
Coding: 0630101
Shop #: WSC 01236 785 00200
VCID: AD1251EB34D5D627BC-80F8
Time Indication: 15
Reset counter: 138
Mileage: 143256 km
Date: 2018.12.25
Time: 22:41:06
00857 - CD Changer Unit (R41)
Reset counter: 138
Mileage: 143256 km
Date: 2018.12.25
Time: 22:41:06
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: C1CA1D5B984D224768-8094
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: C2C812579D4B395F71-8096
End----(Elapsed Time: 01:22, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
