This is coming up when trying to put the nav on the virtual cockpit display.
I'm worried that maybe the unit (MIB2) is not compatible.
Sunday,05,January,2020,10:40:53:18214
VIN: TMBKK7NE2J0139287 License Plate: VRS
Mileage: 35204km-21874mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 4B 52 5F A5 A9 D6
D7
VIN: TMBKK7NE2J0139287 Mileage: 35204km-21874miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BS HW: 04L 907 309 R
Component: R4 2,0L EDC H24 1541
Revision: B5H24---
Coding: 011D0012032501081000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
ROD: EV_ECM20TDI01104L906026BS_002.rod
VCID: 7CA1F71AB66F158795F-8028
17158 - Databus
Part No SW: 0D9 300 043 C HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5202
Revision: 06454104 Serial number: TFK01707130789
ROD: EV_TCMDQ250021.rod
VCID: 1A6DD1825C1BCBB7273-804E
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 62057000004246
Coding: 250793913423097540790608C0CA29A4C92C9002600394742061F070C029430000000012121212B8586C384E4484EE
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 005983EADA877167C97-8054
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0450339169
Coding: 032C0C
Shop #: WSC 73430 790 00063
VCID: 3C21371AF6EFD587D5F-8068
Part No SW: 5E0 907 044 AQ HW: 5E0 907 044 AQ
Component: Climatronic H04 2001
Revision: 00001K00
Coding: 0211010400211001100500080010102A
Shop #: WSC 73430 031 00063
VCID: 74B1DF3A9E3F5DC7DDF-8020
Air quality sensor:
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[PTC-Reduzierung durch BCM]
Reset counter: 6
Mileage: 34730 km
Date: 2019.12.30
Time: 18:49:29
Voltage terminal 30: 13.9 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
Auxiliary heater: in stages-Act.val.: 0
Auxiliary heater: in stages-Specified value: 3
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
[PTC-Reduzierung durch MSG]
Fault Frequency: 63
Reset counter: 21
Mileage: 32430 km
Date: 2019.12.03
Time: 12:36:11
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865822071700A4
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_018.rod
VCID: 065595F2F8A35F57F3B-8052
Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 170601 051 0915
Serial number: 887253F0401715200329
Coding: 164DDD
Component: RLHS 042 0105
Serial number: S5Y17M08D14H12M19S47
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY17117077M
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Serial number: 00002856223971374909
262936 - Sensor for anti-theft alarm system
B1330 29 [008] - Signal Implausible
395521 - Function Limitation due to Active Protection Function
B2023 00 [008] - -
[Störschutzzählerüberlauf]
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 B HW: 5QA 919 283
Component: PDC 4 KanalH07 0044
Serial number: 000308419617216
Coding: 0601050011
ASAM Dataset: EV_EPHVA14AU3700000 009033
ROD: EV_EPHVA14AU3700000_009.rod
VCID: 49CF5ECEA93D702F5E9-801C
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W4PF0MYMS
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 055792FEC5A5544FFA1-8050
Subsystem 1 - Part No SW: ----------- HW: 454 002 407 17
Serial number: 357000000001D659972O
Subsystem 2 - Part No SW: ----------- HW: 454 002 507 17
Serial number: 3580000000080079972F
Subsystem 3 - Part No SW: ----------- HW: 454 802 507 17
Serial number: 3510001EEDC10000000L
Subsystem 4 - Part No SW: ----------- HW: 454 802 307 17
Serial number: 35200FA6BDB10000000Y
Subsystem 5 - Part No SW: ----------- HW: 454 802 506 17
Serial number: 35500066A5D10000000B
Part No SW: 5Q0 953 507 HQ HW: 5Q0 953 549 E
Revision: -------- Serial number: 09081704220317
Coding: 1410
VCID: 0C41A7DAE6CF2507A5F-8058
Part No SW: 5E0 920 957 E HW: 5E0 920 957 E
Component: KOMBI 303 0310
Coding: 27A5091869808600010A6B021001000000000000
VCID: 2F3B105637993E1F60D-807A
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 433 4303
Revision: -------- Serial number: 0006648492
Coding: 030100045F087300EB00026A1C0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 33331C26DBB11AFF045-8066
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000B2618130717
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75886000001707270781
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000199060007
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311F3ADEBF1DC71DF-8060
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 011 0032
Serial number: 0000270994982
Coding: 001C00208001040000001100
VCID: 45D752FE8525944FBA1-8010
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E
Component: FOND_FHSG_DRV 005 0007
Serial number: 00000000000015676666
Coding: 1D0200
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2D3102FCDBEBB7C73-806E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 08081710801764
Coding: 000000070100046E00003D01010000000000000000000000000000000000
VCID: 72BDD922E42B53F7CF3-8026
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 011 0032
Serial number: 0000270930000
VCID: 44D14FFA8E1FAD47ADF-8010
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E
Component: FOND_FHSG_PSG 005 0007
Serial number: 00000000000015630789
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 C HW: 5Q0 035 874 C
Component: MU-S-ND-ER H41 0456
Serial number: SKZAZ2T5308553
Coding: 03735201FF00000051111201008800002F0209C601200500CF
ROD: EV_MUStd4CTSAT_VW41.rod
Subsystem 1 - Part No SW: 5E0 919 605 M HW: 5E0 919 605 M
Component: ABT_Std-2_Nav H50 8130
Serial number: SKZ6ZHT2182839
Subsystem 2 - Part No SW: 5L0 051 236 T HW: -----------
Component: ECE1 2017/18 --- 0820
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 249
Mileage: 33603 km
Date: 2019.12.18
Time: 07:12:58
Voltage terminal 30: 10.1 V
Interface for external media: status-Status: Open circuit
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 07081712P13433
Coding: 0203070200000401000213408150A80084000E200000
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 170627201238
VCID: 698FBE4EC9FD902F7E9-803C
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 7EA5FD12A0730797BBB-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:42, VBatt start/end: 12.2V/12.0V)-----------
The auto-scan was from before I fitted cockpit.
below is current long coding (for module 17);
25AD091869808600010AF7020001000000000000
Also some adaptions and long coding that I try just gives me "out of range" error.
I even tried plugging in my MIB2 unit from MK7.5 Golf with virtual cockpit and the map display was still pink.
adaptions / long coding ive changed;
Go to Byte 12 and check the box for Bit 2 - Alternative Dimming Function active: - ERROR
Open module 5F and open Long Coding Helper; go to Byte 22 and uncheck Bit 0 - Instrument Cluster Graphics [STANDARD]: - WORKED
Go to Adaptations in Module 5F and change the following channels to the settings below:
Dashboard_Display_Configuration-ability_switch_nav_maps ---> On - WORKED
Dashboard_Display_Configuration-call_picture ---> On - WORKED
Dashboard_Display_Configuration-fastlist_most ---> On - ERROR
Dashboard_Display_Configuration-navigation_map_compression_mode ---> H264 - WORKED
Dashboard_Display_Configuration-navigation_map_transmission_mode ---> MOST_streaming - WORKED
Also tried this - Now go to Adaptations and choose the channel Display depiction and change it from Version 1 to Version 2 (this will enable NAV in the AID screen; Version 1 doesn't support it. I couldn't figure out why my navigation map would not show up on the AID after everything was enabled and it was all because of this setting)
doesnt make difference ^^
My thoughts on possibities;
MIB 2 Unit not compatible - unsure
Fibre optic cable not working - X - Tried unplugging and then contact / radio logos no longer transmit so that works.
Missing coding / adaptions - unsure
Would be perfect if someone here has facelift Skoda Octavia here who I could copy their long coding and adaption maps of 5F and 17 so i can compare
