When I try to open the 09 Central Electronics of my 2018 Atlas, I get the following message:
Coding is NOT Supported by this Control Module Variant. Replacement Control Modules must be parameterized by using the Factory Tool and Software-Version-Management (SVM)
Is this normal on the Atlas? I'm used to my Jetta so sorry if this is stupid.
Autoscan:
Autoscan:
Sunday,05,January,2020,01:42:42:41190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 1V2KR2CA8JC567568 License Plate:
Mileage: 88572km-55036mi Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 3C 42 44 4B 52 5F 6C 75
D6 D7
VIN: 1V2KR2CA8JC567568 Mileage: 88572km-55036miles
Address 01: Engine (0-32-CDVC) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 026 E HW: 03H 907 309 K
Component: VR6 3.6l FSI H21 6024
Revision: 52H21000
Coding: 012A00124424010870000000000000000000000000000000
Shop #: WSC 03302 444 00000
ASAM Dataset: EV_ECM36FSI01103H906026E 001005
ROD: EV_ECM36FSI01103H906026AG.rod
VCID: 2708F3CDDF671A5FA8D-8073
CAN Converter 01:
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 A HW: 09G 927 158
Component: AISIN AQ8 206 3387
Coding: 0000000100000000000000000000000000000000
Shop #: WSC 09003 957 00200
ROD: EV_TCMAQ450031_VW37.rod
VCID: 313C1D95E1A354EF769-8065
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 50958000000417
Coding: 44FC6B8D84261A73C57C0306A2CB6922D62158A3C045967E00415058C28A4200002F641C12141A118DDB45506CC8CF
ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
VCID: 76B6EE89484D33D7E3B-8023
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 208
Mileage: 88230 km
Date: 2019.12.11
Time: 14:01:41
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0467740447
Coding: 1F20000723
VCID: 3E2636A920FDBB97FBB-806B
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Fault Frequency: 8
Reset counter: 211
Mileage: 88230 km
Date: 2019.12.14
Time: 14:12:49
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition met
Control Module Voltage: 7.486 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Driver door: Open
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID sensor 1 authentication: status: No response
ID sensor 2 authentication: status: No response
ID sensor 3 authentication: status: No response
ID sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 3CN 907 426 E HW: 3CN 907 426 E
Component: AC Manuell H04 2002
Revision: 00001K00
Coding: 1602000620001800100020404200000C
ASAM Dataset: EV_ACManueBHBVW416 001002
ROD: EV_ACManueBHBVW416.rod
VCID: 45D45945452BE84FBA1-8011
Fresh Air Blower Back:
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 8015015902ˇˇˇˇ
ROD: EV_BCMBOSCH_018.rod
VCID: 06569E4938AD2357F3B-8053
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S7Y18M02D13H15M04S13
Coding: 00382D
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 168
Mileage: 88230 km
Date: 2019.12.11
Time: 14:06:11
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Reset counter: 168
Mileage: 88230 km
Date: 2019.12.11
Time: 14:05:25
Part No SW: 3Q0 959 655 BN HW: 3Q0 959 655 BN
Component: Airbag VW21 006 0713
Revision: -------- Serial number: 003SUM5CHKEM
Coding: 8CCCDC00000000005000001A420800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0B40AF7D23CF5E3FAC5-805F
Occupant Detection:
Component: Occ.Detection H13 0022
Serial number: IBH0000J180008X3TO0%
Coding: 303030
Subsystem 2 - Part No SW: ----------- HW: 454 001 212 17
Serial number: 35700000000EDC286B2/
Subsystem 3 - Part No SW: ----------- HW: 454 001 401 18
Serial number: 358000000002D6ECCB22
Subsystem 4 - Part No SW: ----------- HW: 454 801 001 18
Serial number: 351002768FD12000000K
Subsystem 5 - Part No SW: ----------- HW: 454 801 401 18
Serial number: 3520068E401130000004
Subsystem 6 - Part No SW: ----------- HW: 454 800 201 18
Serial number: 35500DAC97612000000U
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 454 800 201 18
Component: FrontSensor_P 304 0149
Serial number: 35600A7E17112000000E
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 18021820241001
Coding: 0410
VCID: 0748934D3FA73A5F88D-8053
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 3CN 920 850 A HW: 3CN 920 850 A
Component: KOMBI 380 0310
Coding: 0BA4171DAB88CF0502086B0850000000A0000000
VCID: 3D2431A52DFBA08FE21-8069
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 26011800840079
Coding: 030500347F087300FB0320481E0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 382A20B102D985A7317-806D
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 28180000051590091439
Coding: 30FFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 3047705600
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00007.12.17
Coding: 0301
VCID: 4CC26C616641190765F-8019
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000012734010
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW41.rod
VCID: 3330179D1BBF66FF045-8067
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0468858943
Coding: 01011103
ROD: EV_HREntryHella_VW27.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0468952901
Coding: 010111
Component: TSG FS 020 0041
Serial number: 170218A0080489
Coding: 003013200000020000000000
VCID: 43D0475D4B1FD67F945-8017
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000228640
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002358811
Coding: 01000310004001
ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
VCID: 40DA48515A09CD67897-8015
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 03031800841812
Coding: 000000070100135200010000000000000000000000000000000000000000
VCID: 72BED29924252FF7CF3-8027
Component: TSG BFS 020 0041
Serial number: 060318A00801Q9
VCID: 42DE42595405DF779F3-8017
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000226286
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Coding: 02140600FF00000051220001001808001F0500C40120050002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2E0606E9F09D4B176BB-807B
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJV0245693
B11CF 53 [009] - Deactivated
Reset counter: 168
Mileage: 88230 km
Date: 2019.12.11
Time: 14:02:04
Voltage terminal 30: 14.8 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 102 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Component: RVC Compact H12 0231
Coding: 01150602A0002017300040
VCID: 392C25B539D39CAFCE9-806D
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02140602C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AA HW: 7P5 941 591 A
Component: LED1L H06 0003
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 7BA0FFBD736F6EBF9C5-802F
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:36, VBatt start/end: 12.2V/12.2V)-----------
