Passat B6 2007 retrofit ACC?
   #41
sers77
Norway
C?ID=26140
Ok, but 3C0614109L is supposed to be able to run ACC, but as you can see earlier in this thread, that is not possible.
So what do I need to flash it to?
If the HW25 ABS is supposed to work with ACC and PD, then I will swap back (it´s just the control-module)..
Thanks, but don´t need another ABS unit, got 3..
   #42
dieseltje
The Netherlands
C?ID=148044
Mine was hw 25
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 698 109 E HW: 3C0 614 109 AF
Component: J104 C4 440 V3 0017
Revision: --025--- Serial number: 00000104023403
Coding: 0024854
   #43
sers77
Norway
C?ID=26140
Thank you, but you have CR engine.
Have same ABS and it does not work with PD..
   #44
dieseltje
The Netherlands
C?ID=148044
I remeber that only specifick ACC radar type is suitable for your engine.
   #45
sers77
Norway
C?ID=26140
Hmm, found this:
"For ABS revision 020 and early revision do not need change the coding to activate ACC."
   #46
sers77
Norway
C?ID=26140
Is my gateway 3C0 907 530 Q ok?
Or do I have to use 3C0 907 530 B, 3C0 907 530 D, 3C0 907 530 G, 3C0 907 530 K, 3C0 907 530 P, 3C0 907 530 N?
   #47
sers77
Norway
C?ID=26140
Now I have fitted 3C0907530N gateway, but still not working!!!
Unable to activate ACC radar (in 13 adaption channel 5) from 0 (NOT OK) to 1 (OK)..
Is this because ACC only works with RED cluster?
I have B7 premium cluster now, not getting any "assist" menu!
dieseltje
The Netherlands
C?ID=148044
How did you connect your radar to the gateway?
   #49
dieseltje
The Netherlands
C?ID=148044
To enable coding of radar you must enter 201
   #50
sers77
Norway
C?ID=26140
Yes, 201 is used when coding and flashing.
   #51
dieseltje
The Netherlands
C?ID=148044
3C0 radar workes fine with 3AA cluster or the 3C0 upgrade clusters.
Are you able to connect with vcds to the radar?
Did you add the radar (13) to the installation list?
   #52
dieseltje
The Netherlands
C?ID=148044
Adaption channel 5 is allways not ok. That is normal.
   #53
sers77
Norway
C?ID=26140
Will do some more testing tomorrow.. Unable to find the fault on this ACC system..
   #54
dieseltje
The Netherlands
C?ID=148044
What is the lates scan?
Did you recode engine?
   #55
sers77
Norway
C?ID=26140
Only ECU activation code for ACC that is working, is 13377..
On 13 ACC 08 meas. block 22-1 i get ERROR 7.. What does that mean?
Wednesday,15,September,2021,14:07:54:21522
VCDS Version: 21.9.0.2 (x64)  HEX-NET CB: 0.4555.4
Workshop Code: 666 12345 045678
VIN: WVWZZZ3CZ7E096323   License Plate: PIPPIRULL
Mileage: 193540km-120260mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 2E 36 37 42 44 46 47 52
          53 56 62 69 6D 72 77 7D
VIN: WVWZZZ3CZ7E096323   Mileage: 193540km-120260miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 NK    HW: 03G 906 021 AB
   Component: R4 2,0L EDC A000AG  9972
   Revision: --H06---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: F5A244659C95A421E2-80A0
   VINID: 9E69EAAAA0D3A875402460C20CFC50146A
005717 - Please check DTC Memory of Auto. Distance Controller
               P1655 - 000 -
                    Mileage: 193543 km
                    Date: 2016.02.06
                    Time: 13:52:12
                    (no units): 0.00
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000011
Readiness: 0 0 0 0 X
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AD
   Component: GSG DSG         082 1404
   Revision: 05308020    Serial number: 00001105240204
   Shop #: WSC 04940 001 00001
   VCID: 93661AFDB2211A116C-80C6
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 L    HW: 3C0 614 109 D
   Component: J104    C4 440 V3   0005
   Revision: --020---    Serial number: 00000775811730
   Coding: 0002318
   Shop #: WSC 12345 666 45678
   VCID: A71E5E2D16B986B1A0-80F2
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AJ    HW: 3C0 907 044 AJ
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: E99A1815C02D70C176-80BC
   Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
   Revision: 00H54000    Serial number: 00000009463926
   Coding: ED888E2701061A00500A00000F000000841C1D435C80112C002000000000
   Shop #: WSC 05124 123 12345
   VCID: B424B961D76FFD2915-80E0
   Subsystem 1 - Part No: 3AB 955 419 A  Labels: 1KX-955-119.CLB
   Component: WWS471  160913 024  0654
   Coding: 00282045
   Shop #: WSC 05124
   Component: RLS     250414 054  0403
   Coding: 01977121
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08740933702375
   Coding: 110102
   VCID: B228BF79ED7BF31907-80E6
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 L    HW: 3C0 907 567 L
   Component: AC201  RDW 1    031 0120
   Revision: 00031000    Serial number: 00000000051681
   Coding: 0010000
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 0D AIRBAG VW8R  030 2522
   Revision: 11030000    Serial number: 003B2PJU4TMG
   Coding: 0012356
   Shop #: WSC 05311 000 00000
   VCID: B12AB075287DC8017E-80E4
   Subsystem 1 - Serial number: 6332MSME12431421W
   Subsystem 2 - Serial number: 6342MSME124569414
   Subsystem 3 - Serial number: 6351HTS6K5QADO63U
   Subsystem 4 - Serial number: 6361HTS6K5QE5KN2$
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20120209100177
   Coding: 1992A50002
   VCID: F5A244655495A421E2-80A0
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Coding: 830000
   Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
   Component: KOMBI         H03 0407
   Coding: 161C00
   VCID: B326BA7D1A61FA110C-80E6
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G102240078
   Coding: FDA4FF56520612002002
   VCID: AC14A1010F5FA5E94D-80F8
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         042 0383
   Shop #: WSC 06402 785 00200
   VCID: FAB85759B58BCB598F-80AE
Address 2E: Media Player 3
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2601
   Revision: 00H05000
   Coding: 000039
   Shop #: WSC 12445 123 12345
   VCID: B326BA7D1261FA110C-80E6
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 C
   Component: RNS-MID       H06 4020
   Revision: AB001001    Serial number: VWZ6Z7K9061156
   Coding: 00050400010000A20011
   Shop #: WSC 01324 020 00200
   VCID: AF2EB60DFE49DEF168-80FA
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1517
   Revision: 71009005    Serial number: 00000643489028
   Coding: 0004599
   VCID: F1AA7075E8FD88013E-80A4
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.136 H07 1806
   Component:    KSG PQ46 ELV 042 0612
   Coding: 189109005103483F7F02171FF0C88F06705900
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
   Component: DSP 10 Kanal        0013
   Revision: 00010000    Serial number: 00000000004663
   VCID: A3064A3D62816A91FC-80F6
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1517
   Revision: 71009005    Serial number: 00000501889105
   Coding: 0004598
   VCID: F2A87F79EDFBB319C7-80A6
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000161442
   Coding: 0000057
   Shop #: WSC 05311 123 12345
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000763596
   Coding: 0000208
   VCID: F0AC7571E3F7810931-80A4
   Component: Anhaenger     H07 0100
   Revision: 3A001001    Serial number: 00000131398946
   Coding: 410D000101000000
   Shop #: WSC 05314 123 12345
   VCID: B02CB571E377C10971-80E4
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 G    HW: 3C9 827 383 G
   Component: J605  HECKDECKEL    0730
   Revision: 00H27001
   Shop #: WSC 05314 000 00000
   VCID: B5228465DC15E42122-80E0
   Subsystem 1 - Part No: 3C9 827 384 G
   Component: J756  HECKDECKEL    0730
   Subsystem 2 - Serial number: 0900H27001001A0206ÿ
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000773163
   Coding: 0000208
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007666071836
   Coding: 0910000000010101
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: BC349141373F3569DD-80E8
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00900000    Serial number:
   VCID: AD12AC053445ACE15A-80F8
End----------(Elapsed Time: 02:20, VBatt start/end: 12.3V/13.0V)-----------
dieseltje
The Netherlands
C?ID=148044
Doe you have also a flashing glow spiral in the cluster?
You engine is coded as adaptive cruise only, not with front assist. So all adaptions in your ACC controler must be whitout front assist. That is the conflict in your system.
Or you must recode your engine with front assist. For common rail engine is that 30903.
dieseltje
The Netherlands
C?ID=148044
13647 - For older ECU-s like PD and PPD. Also for AXZ before 2008 without Front Assist
13377 - Newer ECU-s with manual gearbox and without Follow to Stop
30903 - Newer ECU-s with automatic gearbox and with Follow to Stop+Front Assist
   #58
dieseltje
The Netherlands
C?ID=148044
The A shows that engine is coded with ACC.
If you decode ACC and recode it to normal cruise it should have shown a G.
Check older logs whitout ACC.
   #59
sers77
Norway
C?ID=26140
No flashing spiral in the cluster..
Everything seems normal, except cruise control not working anymore, lever does nothing..
MFA says "acc starting", but that's not going to happen :banghead:
Flashed radar to M to check if Follow to Stop+Front Assist where turned off.. and they were..
Installed the OEM relay yesterday (instead of the double universal relay I put in), that did nothing..
The very expensive Gateway that ends with N, did nothing as well.. Same error in ACC 08 meas. block 22-1 i get ERROR 7.
I don't think my car has the hydraulic brake assistance sensor G483..
   #60
sers77
Norway
C?ID=26140
Maybe flashing ECU back to 03G906021NK_9354.sgo will make activation "13647 - For older ECU-s like PD and PPD. Also for AXZ before 2008 without Front Assist" possible?
