Audi A4 abs coding...
Kristian Hasa
Albania
C?ID=309376
Hello.
I was about to code the abs module but i noticed that the Pr code sticker was ripped off. Can somebody give me the code please.
Thanks!
Here a Autoscan
Saturday,04,January,2020,15:50:32:50280
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ8E35A008061   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E35A008061   Mileage: 201620km-125280miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 LJ
   Component: 1,9l R4 EDC 0000SG  5934
   Coding: 00002
   Shop #: WSC 63251
   VCID: EA989AF794BB011F99-4B1E
   WAUZZZ8E35A008061     AUZ6Z0D0183503
No Faults Found
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       4529
   Coding: 00000
   VCID: E582E9CB7DA52E67B4-51A8
            35-00 - -
            66-10 - Not Matched - Intermittent
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1424
   Coding: 00000
   Shop #: WSC 63251
   VCID: E08CF8DF62874B4F47-5160
            41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0706
   Coding: 00001
   Shop #: WSC 63251
   VCID: B22842977CEB89DFE1-4B00
01326 - Control Module for Multi-Function Steering Wheel (J453)
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 J
   Component: Airbag 8.4EP        1002
   Coding: 0010602
   Shop #: WSC 63251 000 00000
   VCID: BE3066A7E8B35DBF15-5184
   Part No: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00002
   Shop #: WSC 63351
   VCID: B6207E87908395FFCD-4B00
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 900 M
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 00001
   Shop #: WSC 00186
   VCID: AE1056E768D3AD3F85-5160
   Part No: 8E0 959 433 AS
   Component: Komfortgerát T01    1412
   Coding: 06976
   Shop #: WSC 63251
   VCID: 8248D2578CCBF95F31-4B00
   Subsystem 1 - Part No: 8E1959801B
   Component: Tõrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 1204
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 1204
7 Faults Found:
00956 - Key 2
            35-10 - - - Intermittent
   Part No: 8E0 035 186 D
   Component: concert II  GRO    0004
   Coding: 01001
   Shop #: WSC 63251
   VCID: A81CA0FF4937F30F4F-4B1E
End----------(Elapsed Time: 05:54, VBatt start/end: 12.9V/12.9V)-----------
Somnus
SLC, USA
C?ID=215931
If I were to hazard a guess based on the relevant PR codes for your VIN
Brake type, front	1LB	Disc brakes in front
Base engine	T9J	4-cylinder diesel engine 1.9 l unit 038.K
Transmission specifications	G0K	6-speed manual transmission
Login: 09555
Coding: 04255
However, If you would like to verify, here is the link to the Ross-Tech Wiki page for the Bosch 5.7 system http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Brake_Electronics_(Bosch_5.7)
Kristian Hasa
Albania
C?ID=309376
I forgot to add, i changed the steering wheel control module. After a bit of searching that is the reason the abs coding went to 00000. Tomorrow i will change some adapting and coding in the steering wheel module. Thanks for the coding!
