Soft coding for 2005 Allroad
808allroad
C?ID=381173
Hello everyone,
Ive converted my 2005 Allroad air suspension to coils after being left stranded due to air suspension issues too many times. Blau has instructions on their coil conversion to change the soft code from xxxx5 to xxxx2 to get rid of the CEL after disconnecting the j197 module, but when i try this, the soft code does not change. Any pointers?
Im still fairly new to vagcom, so if there is any information about the vehicle that may help, let me know and ill try to get it.
Thanks!
Hi and welcome.
Soft coding in what module?
Please post a complete Auto-Scan for context. My recollection is there's no way to get a C5 Allroad free of faults after removing the air suspension without swapping out some other modules as well, because those modules were specific to the Allroad and will forever be unhappy without data from the suspension module.
808allroad
C?ID=381173
engine module, i'm following the instructions provided by Blau and their coil conversion kit.
To recode the Audi Allroad ECU proceed as follows:
Tools Needed - Ross Tech Diagnostic Software
Plug Ross Tech PC into Audi Allroad OBD com-port.
Cycle the ignition key to the accessory position.
Access Ross Tech software from PC desktop.
Select control module.
(01-Engine) control module (Allow several seconds to pass and allow the Ross Tech to communicate with the engine control module).
(07-Coding) engine recode module
(Software Coding) change the last digit from 5 to 2 and save the software coding by clicking (DO IT!) (Allow several seconds to pass and allow the Ross Tech to communicate with the engine control module).
Cycle the ignition key to the off position.
If necessary remove all stored codes from control modules. Cycle the ignition key to the accessory position, re-access the vehicles control modules and remove all stored codes from the control modules. Cycle the ignition key to the off position when done.
Unplug OBD com-port from vehicle.
After all stored codes have been removed from the control modules start the vehicle to confirm there is no check engine light and leveling light.
I'll post the auto-scan when i get home. And thank you btw for the quick replies!
808allroad
C?ID=381173
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
VIN: WA1YD64B75N008073
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 T
   Component: 2.7L V6/5VT     G   0010
   Coding: 07755
   Shop #: WSC 02334
   VCID: 54F17CB7B7E50CD73DF-5160
   WA1YD64B75N008073     AUZ7Z0D2635649
18005 - Powertrain Databus
            P1597 - 35-00 - Missing Message from Level Control System (J197)
Readiness: 0000 1001
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4Z7 927 156 T
   Component: AG5 01V 2.7l5VT USA 0404
   Coding: 0001002
   Shop #: WSC 02334 785 00200
   VCID: 57EB8BBBA31327CFD8D-5160
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D66
   Coding: 06497
   Shop #: WSC 02334
   VCID: 4ACD62CF65A14A27573-5160
01310 - Level Control System Control Module (J197)
            49-00 - No Communications
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AQ
   Component: A6-Klimavollautomat 0208
   Coding: 00010
   Shop #: WSC 02335
   VCID: 698FBD430057A13F7E9-2586
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 N
   Component: Airbag 8.4EP        1000
   Coding: 0000607
   VCID: 5AED928FD0013AA7E73-5184
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01002
   Shop #: WSC 02334
   VCID: 2F3B135BFE330F0F60D-5184
00926 - Terminal 30
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 983 F
   Component: KOMBI+WEGFAHRS. VDO D16
   Coding: 20264
   Shop #: WSC 08986
   VCID: 2B03074BCA1B732F4C5-5160
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D38
   Coding: 15885
   Shop #: WSC 02334
   VCID: 33331F2B121B2BEF045-4EEA
01561 - Rear left door
            59-00 - Can't Unlock
01562 - Rear right door
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 - -
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0204
   Coding: 00001
   VCID: 2C010457CF25741745F-4B1E
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00030
   Shop #: WSC 02334
   VCID: 04518CF707355C57EDF-4B00
   Part No: 4B0 035 195 N
   Component: symphony II PM6    0410
   Coding: 02005
   Shop #: WSC 21248
   VCID: 2B03074BCA2B732F4C5-5066
End----------(Elapsed Time: 05:03, VBatt start/end: 12.2V/12.2V)-----------
I'll note that the last digit of your ECU's coding isn't '5' to begin with.
But I'll also note that your ECU, your TCU, your ABS, your Airbag module, and your headlight range controller all have part numbers that start with '4Z'. This indicates that they have Allroad-specific software in them and quite likely won't accept coding values that would be used on a regular A6 (with steel suspension) of the same vintage.
You may want to talk to a tuner to see if they can install regular A6 software in some of these modules.
