HELP! Recalibrate Ride Height sensors in 2017 SQ5 (FY) / 2017 S5 (B9)
manzp
Australia
C?ID=274140
Hi Guys,
I have the above 2 cars, both of which had suspension repairs done after accidents (by previous owners!).
Both give errors for the ride height sensors being out of the allowable tolerance.
It is only a small amount like 15mm, but enough to make the car beep after a few minutes of driving each time.
I have searched and searched on the forums and internet in general and cannot find anything much on re-calibration of these.
My cars DO NOT have air suspension, but using the guides for air suspension as a base, I still can't make progress after fiddling for hours.
I think the problem may be I need a securing code for module 74: Chassis control before it will allow me to delete calibration and start the process. Try as I might to find the security code online I cannot find it either.
I have tried a bunch of different security codes without success.
Can anyone shed any light on this?
I think the calibration procedure will be similar to the below -
https://forums.ross-tech.com/showth...adapt-Adaptive-Suspension-to-default-position
I also have access to ODIS, but this wasn't any more useful than the VCDS for what I was trying to do.
Thanks in advance.
Without an Auto-Scan of both vehicles it will be difficult to offer suggestions :popcorn:
manzp
Australia
C?ID=274140
Autoscan for the SQ5
Here is the autoscan for the SQ5. Let me know if you can help further.
Thanks
Chassis Type: FY-AU49 (4M2)
Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
          6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
VIN: WAUZZZFY8H2031590   Mileage: 23266km-14456miles
74-Chassis Control -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD)       Labels: Redir Fail!
   Part No SW: 80A 907 559 B    HW: 06M 907 309 D
   Component: 3.0l V6 TFSI  H21 0003
   Revision: B2H21000
   Coding: 2A2A00322566050B34380000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS01180A907559B 001003
   ROD: EV_ECM30TFS01180A907559B.rod
   VCID: 2E050ECBA0907D176BB-807A
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H05 1002
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 698FBDD759FEDA2F7E9-803C
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 80A 907 379 F    HW: 80A 907 379 A
   Component: ESP9 Premium  H09 0657
   Coding: 1CAA14BE30A50A9791A3589A087D52A2E6A5DA38280C50891A104A4567A55B
   ASAM Dataset: EV_ESP9BOSCHAU426K 011013
   ROD: EV_ESP9BOSCHAU426K.rod
   VCID: 323D1ABBB4A859F70F3-8066
   Part No SW: 80A 820 043 G    HW: 80A 820 043 G
   Component: Klima Zone 3  H32 0090
   Coding: 6608098C5544050D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 211FE5F7E14ED26FE69-8074
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001288422
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 47898A8880PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143C13900CD050D51199F2F0CF9130B31090000000000000000600016810A4502AA22B70A
   ASAM Dataset: EV_BCM1BOSCHAU736 018006
   ROD: EV_BCM1BOSCHAU736_018_AU49.rod
   VCID: 025D8A7B44882977DF3-8056
   Subsystem 1 - Part No SW: 80C 955 119     HW: 80C 955 119
   Component: 426 RL 170202  040 0570
   Serial number: 00000001701312105735
   Coding: 5FC7F7
   Serial number: 20247025X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 07 04 2017  70970038
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE120031723611804
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 AB    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00000940
   Coding: 010101
   Electrically Adjustable Steering Column:
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA125812000027109744
   Coding: 0A0700
   Subsystem 7 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000058352002
262165 - Lamp 1 for Contour Lighting of Dashboard
          U117E 00 [009] - No Communications
          [Instrument panel contour illumination lamp 1: No communication]
                    Reset counter: 162
                    Mileage: 23147 km
                    Date: 2019.12.27
                    Time: 14:58:43
                    average_Voltage_terminals: 11.90 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 26.50 °C
                    interior_temperature: 27.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
262167 - Lamp 2 for Contour Lighting of Dashboard
          U1180 00 [009] - No Communications
          [Instrument panel contour illumination lamp 2: No communication]
                    Reset counter: 162
                    Mileage: 23147 km
                    Date: 2019.12.27
                    Time: 14:58:43
262169 - Lamp 3 for Contour Lighting of Dashboard
          U1182 00 [009] - No Communications
                    Reset counter: 162
                    Mileage: 23147 km
                    Date: 2019.12.27
                    Time: 14:58:43
   Part No SW: 80A 907 561     HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3464E75358FFEC06747860A4
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 6597B1E7B5E6FE4F5A1-8030
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM00ZFA%
   Coding: AAFCF0C00C8000009854003FF08C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3E253E8B70F08D97FBB-806A
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 80A857705A0111R01502
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 80A857706A0111R00813
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 480 000 802 17
   Serial number: 357000000007B5F4212J
   Subsystem 4 - Part No SW: -----------    HW: 480 000 802 17
   Serial number: 3580000000003D8DF02R
   Subsystem 5 - Part No SW: -----------    HW: 480 030 501 17
   Serial number: 351000C1C8BAF9A148D.
   Subsystem 6 - Part No SW: -----------    HW: 480 030 602 17
   Serial number: 352000C1CBCD79710FD.
   Subsystem 7 - Part No SW: -----------    HW: 480 030 602 17
   Component: FrontSensor_D  002 0149
   Serial number: 355000C1CBC97850F9A
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 030 602 17
   Component: FrontSensor_P  002 0149
   Serial number: 356000C1CBC9B2808A1P
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 030 403 17
   Component: PedP_Sensor_C  002 0149
   Serial number: 230000C206A2DAE0DDAO
   Subsystem 10 - Part No SW: -----------    HW: 480 000 302 17
   Serial number: I0M0000000094D0DAF9R
   Subsystem 11 - Part No SW: -----------    HW: 480 000 302 17
   Serial number: I0N00000000A4569EE9Q
   Central Sensor XY:
   Subsystem 12 - Part No SW: -----------    HW: 480 020 802 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C12465B54669S
9634901 - Control Module for Front Left Belt Tensioner
          B1304 55 [009] - Not configured
                    Mileage: 23147 km
                    Time: 00:00:00
9635157 - Control Module for Front Right Belt Tensioner
          B1305 55 [009] - Not configured
                    Mileage: 23147 km
                    Time: 00:00:00
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 80A 907 129 AD    HW: 80A 907 129 AD
   Component: Lenks.Modul   H02 0003
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 6A8DC2DB5CF8D137773-803E
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
   Component: FBenRDW       H17 0309
   Coding: 248D96C43C98000801A3E9601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 42DD4A7B0408E9779F3-8016
   Part No SW: 4M2 907 468 D    HW: 4M2 907 468 A
   Component: Gateway       H16 0107
   Revision: 4W010003    Serial number: 03G4W006817104
   Coding: 03010001000086405407000000590032FC920007100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: 392F2D9769DEAAAFCE9-806C
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20170328125738 00395
   Serial number: 7675565000
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H06 0017
   VCID: 303910B3BAA46BE7797-8064
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 512A1470771133
   Coding: 00781B000000B0010000010101010000000000000000000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
   VCID: 76B5E6AB184005D7E3B-8022
Address 39: Right Light (J1023)       Labels: None
   Component: LCM_MLBevo    H06 0016
   ASAM Dataset: EV_LCMRightCONTIAU426 001008
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 4E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 363526AB58C045D723B-8062
   Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
   Component: TSG FS006 0737
   Serial number: CLSM1QBO008AV
   Coding: 005D1B015E010480000110B0
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000665218
   Coding: B0112001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34311CA34EBC57C71DF-8060
   Part No SW: 8W0 907 064 CP    HW: 8W0 907 064 P
   Component: BCM2 MLBevo   018 0344
   Coding: 01350000000000C0630980006E00980033004010004F02502F0000000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 0C41A44376CC6F07A5F-8058
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58036241
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAGTK00C1E5
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 196FCD17C91E8AAF2E9-804C
   Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
   Component: TSG BFS006 0737
   Serial number: CLSM1QD7003HU
   VCID: 3D2739877DF6968FE21-8068
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 041     HW: 8W5 035 041
   Component: MU-P-LND-RW   033 0917
   Serial number: A802D0H9180570
   Coding: 012456080000000013511102000A00102F001AE601700104DE
   VCID: 71BFD5B7712E22EF369-8024
   Subsystem 1 - Part No SW: V03 959 801 FQ    HW: -----------
   Component: ROW 2017  --- 0062
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL00VCM
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 07021700000000000194
   Component: Gracenote2  --- 4011
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H12 0315
   Serial number: C854607JG002314
   Coding: 02240601BE0FA10008404080
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0730
   Shop #: WSC 50620 822 00000
   VCID: 48C958532234C327417-801C
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 80A 907 777 N    HW: 80A 907 777 D
   Component: Fahrwerk-SG   H35 1214
   Serial number: 2102170031
   Coding: 1050182A78
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 3C21348366EC9F87D5F-8068
32776 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Fault Frequency: 6
                    Reset counter: 207
                    Mileage: 23151 km
                    Date: 2019.12.27
                    Time: 17:01:13
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 80C 713 041 K    HW: 80C 713 041 K
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170309000333
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2615F6EB8860355793B-8072
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 80A 919 617 A    HW: 80A 919 617 A
   Component: HeadUpDisplay H11 1603
   Coding: 4A01C0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736.rod
   VCID: 2B0307DF9382083F4C5-807E
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541     HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 6393AFFFBBD2807FB45-8036
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217     HW: 80A 907 217
   Component: BVS           H14 0042
   Coding: 0404020600000404024023A6CD0000FE00F0C020C280
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 170124201106
   VCID: 6889B8D342F4E327617-803C
   Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
   Component: TSG HFS006 0737
   Serial number: CLSM1QD500BAH
   Coding: 000D190000010480000010A0
   VCID: 40D940730A04FB67897-8014
   Component: TSG HBFS006 0737
   Serial number: CLSM1QD50091B
   Component: SAD_STG_1     013 0005
   Coding: 728000042602
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 4E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736.rod
   VCID: 33331FBF4BB250FF045-8066
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   VCID: 1A6DD21BCC1881B7273-804E
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
I do not think that a "Mechanical Failure" type fault code can be fixed via a re-calibration of any kind.
manzp
Australia
C?ID=274140
Thanks for the reply.
I can see that the ride height does work as normal looking at the vcds measurements. I can see that the "calibrated" height is around 15mm away from the actual height.
Therefore I think if I can re-calibrate to the actual height it will stop giving me the message.
If I pull off the plastic that connects the sensor to the lower control arm it is easy to move it up and down and change the ride height (on the live data through VCDS) so everything electrically should be working.
Can you offer any further assistance for security access to module 74? and do you think the bulk of the air suspension adjustment link I linked in my first post will do the job?
manzp
Australia
C?ID=274140
Anyone know the security code for module 74??
