VCDS-Mobile iOS app
JohnnyFiama
C?ID=288500
I understand this is a helper app, essentially only "discovering" the interface.
In order to get the most out of VCDS mobile it seems that you should run in infrastructure mode, the iPhone's hotspot helps with this, however in my experience the app does not scan the temporary 172.x.x.x subnet for the interface.
Does a workaround exist for this, or do you have plans to update the app? Updating the app would be preferable given its core purpose.
It certainly isn't impossible to derive the interface IP through guesswork, but the app appears to exist to give some level of slickness.
Moving this to HEX-NET support.
If you don't hear anything further, I suggest bumping this thread sometime during the first full week of January when everyone is back from holiday break.
Zenerdiode
Newcastle, England
C?ID=24330
Happens the same with me. As a work around, search for the free version of 'iNet - Network Scanner' on the App Store and run a network scan whilst you HEX-NET is connected to the Hotspot. XXX.XXX.XXX.1 is the host (iPhone) and the other address will be your HEX-NET. You may then open a Safari page and manually type the 172... address.
Note to self - must address that SD Critical error...
JohnnyFiama
C?ID=288500
Perfect, thanks! I was struggling to find a tool that scans the iOS bridge interface.
I am still interested to hear what the VCDS-Mobile developers have to say regarding this, if possible it would be good to see an updated app.
Indeed, it would. :)
But the fact that you were "struggling to find a tool that scans the iOS bridge interface" is somewhat telling, isn't it?
JohnnyFiama
C?ID=288500
I do concede this may not be straight forward, and I'm unclear what discovery method the app uses (which could be a complicating factor). Fingers crossed that your guys and girls have some bright ideas :)
romad
Oroville, California People's Republic
C?ID=208765
I use Fing. But then it is just copy and paste. On my Macs I have the address bookmarked for future use.
gawied
Developer
South Africa
Please confirm that you are using VCDS-Mobile Version 1.07. This update addresses various compatibility issues with iOS 13 - like retrieving WiFI SSID and Dark mode UI.
I have seen it working correctly when both the iPhone and HN are connected to the same WiFi Infrastructure, but it seems your issue is when your HN is connected to the iPhone's hotspot. Correct?
We will test this in the coming week and let you know.
gawied
Developer
South Africa
Hi JohnnyFiama and Zenerdiode
We manage to replicate the hotspot issue and are busy testing a fix for it.
Will keep you posted.
Cheers,
Gawie
Spacewalker
Poland
C?ID=159607
last time I was try to use my Hex NET , on the bench , w/o gateway .....
from PC software - I can connect cluster directly (UDS cluster)
but from Mobile APP - I can not
:confused:
:confused:
AP Mode?
Infrastructure Mode?
- Both phone and HEX-NET connected to a WiFi router?
- Or using hotspot on phone?
Did you try pointing a browser directly at the IP address of the HN?
Spacewalker
Poland
C?ID=159607
99% it was AP mode via Android
i will look that again this evening
JohnnyFiama
C?ID=288500
Cheers,
Gawie
You guys are pretty awesome :)
Thank you for investigating, and pushing out a fix so quickly (also apologies for my recent absence on this thread).
