2018 Audi A3 - ABS FAULTS
Gashhey
C?ID=350180
I have replaced the ABS Wheel Speed Sensor and now it shows this fault and there's around 5+ faults on my dash, EPB, ABS, Parking Sensors, Stop / start etc
Thursday,26,December,2019,19:00:41:18214
VIN: WAUZZZ8V5JA110391   License Plate: A3
Mileage: 43849km-27246mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 29 39 42 44 4B 52 5F BB BC D6 D7
VIN: WAUZZZ8V5JA110391   Mileage: 43849km-27246miles
Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 AB    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H26 3494
   Revision: W1H26---
   Coding: 02190032232401082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM10TFS01104C906026AB 002006
   ROD: EV_ECM10TFS_VW37.rod
   VCID: 619FA66E31CDD86FA69-8034
   CAN Converter 01:
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:46:01
                    Engine speed: 0.00 /min
                    Coolant temperature: 93 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 12.651 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 3
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:38:36
                    Engine speed: 931.50 /min
                    Normed load value: 11.8 %
                    Coolant temperature: 92 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 13.052 V
                    Outside air temperature: 9 °C
                    Absolute intake pressure: 33 kPa abs
                    Engine torque: 12.5 Nm
                    Fuel level: 17.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Engine operating condition: Idling
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 CT    HW: 5Q0 614 517 AG
   Component: ESC           H62 0653
   Revision: 00000000    Serial number: 60798000000714
   Coding: 12F18AA22421226C4B7A0E0960C42448512444D2700624730221F0788008420B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: 055792FEC5A5544FFA1-8050
0087 - Rear Right Wheel Speed Sensor
          C101D 4A [137] - Incorrect component(s) installed
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:46:40
16417 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:46:51
32994 - Control Module for Electric Parking Brake
          C10E2 F0 [009] - RPM Sensor Implausble Signal
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:46:41
   Part No SW: 8V0 820 043 AE    HW: 8V0 820 043 AE
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001505735
   Coding: 03100003000000001000000000001000
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 75B7E23E954544CFEA1-8020
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: F040581900PAG0MUFU03
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001807901489
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08499BCAF2B74927817-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 180212  043 0580
   Serial number:         180219164909
   Coding: 0A47F7
   Serial number: 21285354X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 29 12 2017  00000639
   Serial number: 000000000ZY180443WVH
   Serial number: 00000000000026232141
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419618078
   Coding: 0600050001
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009.rod
   VCID: 49CF5ECEA93D702F5E9-801C
13637410 - Databus
          [Bremsensteuergerät - ESP_10.ESP_WegimpulsHR - Fehlerspeicher auslesen]
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:38:35
13637423 - Databus
          [ESP - ESP_19.ESP_HR_Radgeschw_02 - Fehlerspeicher auslesen]
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:38:36
13637426 - Databus
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:38:34
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR41BWU%
   Coding: 98CCC0000C0000005C5400CA00C8000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F9ECEE9BD302F9E9-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 903 18
   Serial number: 3570000000066151EC2J
   Subsystem 2 - Part No SW: -----------    HW: 480 001 903 18
   Serial number: 35800000000CAA54AC2
   Subsystem 3 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3510001A92919B94234/
   Subsystem 4 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3520001A92919B94424%
   Subsystem 5 - Part No SW: -----------    HW: 480 400 302 18
   Serial number: 3550002C525325B191C/
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 401 18
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C32843FB312C3
   Subsystem 7 - Part No SW: -----------    HW: 480 402 401 18
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001C32843FB0F5FL
   Subsystem 8 - Part No SW: -----------    HW: 480 000 903 18
   Serial number: I0M00000000234547C2-
   Subsystem 9 - Part No SW: -----------    HW: 480 000 903 18
   Serial number: I0N00000000CC538CC2L
   Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18031820240033
   Coding: 2408
   VCID: 015F86EED18D786FC69-8054
   Part No SW: 8V0 920 973 F    HW: 8V0 920 973 F
   Component: KOMBI         H01 0311
   Coding: 27AD0A002B8006000100FA001000000000000000
   Shop #: WSC 12345 123 61029
   VCID: 42DD49E2940BA3779F3-8016
   Component: GW MQB High   518 5323
   Serial number: 06031810522600
   Coding: 030100043F0857005B00004A000B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 38292B0AC2D7F9A7317-806C
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0004
   Serial number: 20180302161356 21579
   Serial number: 75886000001803230314
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Serial number: 200118EAI08889
   Coding: 001C8A204001040000001002
   VCID: 43D34CE68B11AA7F945-8016
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3DC269B315AFFC45-8026
20228 - Databus
          [ESP_19 Botschaft - SNA-Check]
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:38:33
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 13.00 V
                    Temperature: 39.0 °C
                    KFC: 4F
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 13.28 V
                    uAdSensI_SwitchedKl30_xdu16: 13.19 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
19716 - Databus
          [ESP_10 Botschaft - SNA-Check]
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:38:33
                    Motor status: 02
                    KFC: 4D
                    KFA: 00 04
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 09031810801377
   Coding: 000000050100146600102B03020000000000000000000000000000000000
   VCID: 72BDD922E42B53F7CF3-8026
13705987 - Databus
          [ESP_HR_Radgeschw received error value]
                    Reset counter: 103
                    Mileage: 43849 km
                    Date: 2019.12.26
                    Time: 18:38:33
   Serial number: 200118EAK1516A
   Coding: 001C82204401040000001002
   Part No SW: 81A 035 192 F    HW: 81A 035 192
   Component: MU-HS-LND-EU  050 0213
   Coding: 01730301FF0A000011111101000A00102F022EC601F00100CE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 2411EF7A6E5F8D478DF-8070
   Subsystem 1 - Part No SW: 8W0 919 866 AB    HW: -----------
   Component: ECE 2018  --- 0032
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y09K3Y
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL118011800050364
   Serial number: 060218EB525336
   Coding: 000C82204001040000001002
   VCID: 45D752FE8525944FBA1-8010
   Serial number: 060218EB525333
   VCID: 176BC8B6AF09D6DF18D-8042
End----------(Elapsed Time: 01:23, VBatt start/end: 12.0V/12.0V)-----------
Any idea how / why its doing this?
does it need online coding?
First question: Why would you replace a wheel speed sensor on a 2018 car with only 27,000 miles on it?
Second question: What was the source of the replacement part? The ABS module doesn't seem to like the replacement part:
Gashhey
C?ID=350180
it was around £70 the part
it was physically damaged and causing faults
