ABS coding/calibration
   #21
Ok, screenshoting it does sound a bit easier than running threw the map. Lol... I will definitely give it a shot, if I get to a point where I'm stuck, I'll definitely be back here for more help! I dont have a thing that opens PLA and PLB files to really read threw the map. But thank you for everything!
Making a map is a couple of clicks.
PLA and PLB files are just text. Tell Windows to open them with Notepad. Also, there is the choice to make maps in .CSV format, which is also just text, but should open with Excel by default (assuming you have Excel installed).
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
I wouldn't advise using this function as software differences in different modules/revisions and paramaterisation affects the line items being transferred back to the module. It only takes a couple of minutes to update each adaptation list manually.
The only pain however is the newer BCM's that have around 2000 channels!
Wow! I thought the process is straightforward as described in the manual. Thank you for the warning myounus.
