ABS coding/calibration
1990loyale
KY, USA
C?ID=335210
So, I have a 2012 Jetta 2.0. My brakes go to the floor before grabbing. I checked a few things before running VCDS only to find out out it's my ABS module that's bad...
My question is, do I need to swap it with one of the exact part number or can i use one that has a slightly different number? For example, mine is 1K0 907 379 BJ, could i use one with slightly different number(letters) as in one that ends in BC or BL or so on, or get the one ending with BJ? And do I still need to code it and calibrate the sensors if I get one with the same part number? Thanks you in advance.
myounus
Northwest UK
C?ID=321059
Hi
Please can you provide a full autoscan.
You can change to one with different letters after it, usually this refers to a later version, e.g A is the first and AG is a later revision.
1990loyale
KY, USA
C?ID=335210
Ok, I can provide a full auto scan later. Currently at work... I found a used replacement from a 2015, same part number but the letters end with "BS".. the attached pump doesnt have the same part number as my current pump. Does that matter?
myounus
Northwest UK
C?ID=321059
That should be fine. We need to see the scan and you'll need to make a record of the coding and adaptations to save headache later. Upload it when you get a chance.
1990loyale
KY, USA
C?ID=335210
below is my AutoScan on the vehicle.
Monday,23,December,2019,16:59:19:33639
VIN: 3VW2K7AJ7CM304346   License Plate: 2012JETTA
Mileage: 123210km-76559mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VW2K7AJ7CM304346   Mileage: 123210km-76559miles
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 S    HW: 06G 906 055 B
   Component: 2.0l / 85 KW     01 1106
   Revision: T5H04---    Serial number:
   Coding: 0001015
   Shop #: WSC 03200 444 83878
   VCID: 392FD1DEB551A4BFCE9-806C
   Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
   Component: AQ 250 6F           1791
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7F5BFFC6EBF54A8FB0D-802A
   Revision: 00H31001
   Coding: B14B240C512208FE8D0E24E88A1F1061A70000
   VCID: 7BA30BD6F3ED56AF9C5-802E
02214 - Tire Pressure Warning
                    Reset counter: 50
                    Mileage: 122773 km
                    Date: 2014.05.09
                    Time: 08:05:54
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 51713
                    Count: 1023
                    Count: 49
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AM    HW: 5C0 820 047 AM
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000443369
   VCID: 6B833B968F8DC62F0C5-803E
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371190110523
   Coding: 7B994B3828AB0B0000302000240884D4904250EE60000000300000000000
   Shop #: WSC 00066 123 12345
   VCID: 2F3BEF8677157A0F60D-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTD0B8YM7
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3431E0EA9EB359D71DF-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100005FXZ0E
   Coding: 303148
   Serial number: 3572MSME742E555FZZZ7
   Serial number: 3582MSME577A135EZZZ3
   Serial number: 3516KSME6F1F7710ZZZ+
   Serial number: 3526KSME59236C10ZZZS
   Serial number: 3556LSME5A023610ZZZL
   Serial number: 3566LSME442C3610ZZZR
   Part No SW: 5C6 920 951     HW: 5C6 920 951
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00122
   VCID: 6889449A92FBED37617-803C
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: 70B92CFAAAAB25F7397-8024
   Component: IMMO          H04 0604
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3E928CF7DF27773-803E
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3159832
   Coding: 05000400010006
   VCID: 231313B62BDDCE6FF45-8076
End----------(Elapsed Time: 01:00, VBatt start/end: 12.1V/12.0V)-----------
OP is now Verified; moving to Car Repair Support.
myounus
Northwest UK
C?ID=321059
You now need to make a admap of 03 ABS. If you search the wiki it will tell you how to do it, it's very easy.
1990loyale
KY, USA
C?ID=335210
Ok, thank you! I found it... I'm new to the coding part of all this, I've only done basic coding for tweaks and such. Where will I find the coding to program the new module?
myounus
Northwest UK
C?ID=321059
You put in your current coding as that is what your car is set to.
1990loyale
KY, USA
C?ID=335210
Ok. Thanks for all the help!... the code will be the really long one, the one below? Or is there something inside the coding tab?
"Coding: B14B240C512208FE8D0E24E88A1F1061A70000"
myounus
Northwest UK
C?ID=321059
Yep that's the coding. But also as I stated you need to make an adaptation map. That will tell you (in simple terms) the 'other' settings for the module.
1990loyale
KY, USA
C?ID=335210
Got it! Adaption map for ABS module has been made. Thanks again!
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
I've been following the discussion between you and myounus and would like to learn more. I've read in the wiki that you can set a replacement module coding with existing coding using the raw hex in an adaptation map. Are you doing the same thing? This is the steps that I've understood so far in order to replace a module:
1. you create an adaptation map using data from your old module using VCDS Controller Channel Map (in Raw Hex output)
2. you swap the old module with the new one
3. you go again to the Controller Channel Map in VCDS enter the module address
4. Choose Function = Restore Adaptation and Choose Output = Raw Hex (I assume VCDS will able to detect the whereabout of the created raw hex file)
5. Click Go and the new module is all coded as it should be.
Are the above correct or am I missing anything? Is there precaution before I can disconnect a module from its connector and replacing it? Will appreciate your answer.
coconutaudi
C?ID=345326
When or at what stage do we need to enter this long coding? Is this the same as restoring the raw hex?
1990loyale
KY, USA
C?ID=335210
I'm actually curious now myself to being able to just upload the adaption map to restore coding for the new module. Is that a possible thing to do?
myounus
Northwest UK
C?ID=321059
I wouldn't advise using this function as software differences in different modules/revisions and paramaterisation affects the line items being transferred back to the module. It only takes a couple of minutes to update each adaptation list manually.
The only pain however is the newer BCM's that have around 2000 channels!
1990loyale
KY, USA
C?ID=335210
Just want to be clear before I swap this thing, i dont want to mess anything up.... I got the long code, then there is more coding inside the coding tab. Where will i get that from? Will that be inside that AdMap I made for the abs module?
myounus
Northwest UK
C?ID=321059
Yes you've already got the long code and made a copy of the admap. If it makes it more comfortable for you go into the 10 adaptations section and screenshot every page - this is the same as an admap. You can post your admap on here if you like. Once you've swapped the module you'll have to run some basic settings after coding. 04 basic settings.
If you get stuck or have any issues we are here to help.
1990loyale
KY, USA
C?ID=335210
Ok, screenshoting it does sound a bit easier than running threw the map. Lol... I will definitely give it a shot, if I get to a point where I'm stuck, I'll definitely be back here for more help! I dont have a thing that opens PLA and PLB files to really read threw the map. But thank you for everything!
