Audi Q5 2013 ECM replasing
olegvg
Ukraine
C?ID=384313
Hi need some advise how to program used ecm from other car on audi Q5 2013
problem is that engine on this car, time to time stop without any lights and warning
my idea is - ecm on this car is damaged when someone try to reprogram it, when engine was on rebuild
Wednesday,18,December,2019,14:22:58:54621
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WA1VFCFP1DA032279   License Plate:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
          6C 6D 72
VIN: WA1VFCFP1DA032279   Mileage: 165230km-102669miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8R1 907 115 B    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0006
   Revision: ECH09---
   Coding: 6A2A0013242600062000
   Shop #: WSC 33093 002 1048576
   ASAM Dataset: EV_ECM20TFS0118R1907115B 001007
   ROD: EV_ECM20TFS0118R1907115B.rod
   VCID: 342402DF9FEE32EF73-8060
Readiness: 0000 0100
   Part No SW: 8R1 927 158 C    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1002
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 3E3020F7A1A2E8BF95-806A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 AK    HW: 8R0 907 379 AK
   Component: ESP8 quattro  H09 0080
   Coding: 151508
   Shop #: WSC 06335 000 00000
   VCID: 095A832BA0EC1F07F0-805C
                    Fault Status: 00101101
                    Reset counter: 123
                    Mileage: 164928 km
                    Date: 2019.12.04
                    Time: 17:17:35
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x000B
                    Hex Value: 0x469A
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H11 0621
   Coding: 0D854000000000000000
   VCID: 0444921F87CE426F83-8050
   Serial number: 2312000232565003
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01231020121713
   Coding: 6481208000
   VCID: 393A33EBB08CCF87A0-806C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000038783202
   Coding: 26000096863CAFC00000480300003D0D0F1C4708A2090221000008004400010200040034000000
   VCID: 7AB8ECE7F50A049FE9-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 121010  H11 0050
   Serial number: 90243014121006214925
   Coding: 01DD13
   Serial number: 20674721
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001210121600
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R3H3202
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 37084056000000000001
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD90WMZQ
   Coding: 30373431343230303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 47DE4513FE78A97726-8012
   Serial number: 6334MSME715274201
   Serial number: 6344MSME73354A2FN
   Serial number: 6352QSME6822245EK
   Serial number: 6362QSME1425547CI
   Serial number: 63732SME2C221842W
   Serial number: 63832SME2C221658
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372LJ8000MA
   Coding: 000017
   VCID: 43C65103C2408557FA-8016
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 N    HW: 8R0 920 930 N
   Component: KOMBIINSTR.   H35 0556
   Revision: 00000000    Serial number: UWF75XAAD
   Coding: 8BA622000A010008020000
   VCID: 3FCE5DF3AEA8E1B79E-806A
   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 1Z090025    Serial number: 2541Z12A050083
   Coding: 80C303FF00
   VCID: 46C04817F172B07FDD-8012
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790393592
                    Reset counter: 124
                    Mileage: 164987 km
                    Date: 2019.12.05
                    Time: 17:30:14
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 124
                    Mileage: 164987 km
                    Date: 2019.12.05
                    Time: 20:07:01
                    Reset counter: 124
                    Mileage: 164987 km
                    Date: 2019.12.05
                    Time: 23:05:59
                    Bin. Bits:    00000
                    Voltage: 12.40 V
                    Count: 7
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000040708114
   Coding: 00581B00000000000000
   VCID: 42C85407DD5A8C5FF1-8016
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H18 0040
   Serial number: 0186141244
   Coding: 010211
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H18 0040
   Serial number: 0186022365
   Coding: 010211
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000042174021
   Coding: 011D13205E00440004
   VCID: 4DD2773B140443271C-8018
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0010954635
   Coding: 100000000000
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B3629E3B2B0FD97B2-806E
   Revision: 00002001    Serial number: 0185999396
   Coding: 0126023A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000588411
   Component: J245EE20SKB13  H03 0220
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H03 0220
                    Reset counter: 83
                    Mileage: 164928 km
                    Date: 2019.12.04
                    Time: 17:12:35
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000041982597
   VCID: 4CD47A3FEF1E4A2F0B-8018
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000164853
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 383C36EF8386D68F5F-806C
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 123
                    Mileage: 164928 km
                    Date: 2019.12.04
                    Time: 17:17:35
                    Voltage terminal 30: 12.4 V
                    Internal Fault ID: 188
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156J40C7648408
   Coding: 020007020100000001
   VCID: 210AFB8B381CB74788-8074
   Part No SW: 8R1 035 664 B    HW: 8R1 035 664 B
   Component: H-BN-NA       H43 0552
   Revision: --------    Serial number: 203JS0C7510480
   Coding: 16020006000581EF51028B4E00000403F40000020000000000
   VCID: 35223FDB9C942BE744-8060
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130JY0C2570549
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001310436
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000042038803
   Coding: 010C13204000240004
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J27A6F4
   Coding: 1020010
   Shop #: WSC 06325 000 00000
   VCID: 342402DF57EE32EF73-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B3629E3BAB0FD97B2-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000042038844
End----------(Elapsed Time: 02:00, VBatt start/end: 12.2V/12.2V)-----------
Installing a different ECM cannot be done with VCDS on this car. Doing so "correctly" requires access to the Fazit server at Audi.
Are you sure that the problem is actually in the ECM rather than some external influence, for example a dodgy voltage supply to it?
olegvg
Ukraine
C?ID=384313
i check all harness and all connections!
Engine can stop any moment without any mistake, any lights on dash. all what you need - press start button and drive again!
As you see autoscan start/stop system is not instaled!
Gone But Not Forgotten
Reset counter: 124
Mileage: 164987 km
Date: 2019.12.05
Time: 20:07:01
Reset counter: 124
Mileage: 164987 km
Date: 2019.12.05
Time: 23:05:59
Bin. Bits: 00000
Voltage: 12.40 V
Count: 7
OP:
Are you sure a terminal relay isn't dropping out when it happens allowing a reset from internal point contact being weak or inadequate charging on LIN?
olegvg
Ukraine
C?ID=384313
We play with this now! I will describe a problem (or how we fix it) here.
olegvg
Ukraine
C?ID=384313
ECM swap in all done. Running good if interesting autoscan will be on Monday.
olegvg
Ukraine
C?ID=384313
Sorry! for long time without any posts.
Car move to scrab :( sorry but no final scan and description of problem - all gone with a car
