- Sep 5, 2016
- 1,150
- 1,230
- Riga, Latvia
- C?ID=268515
Why "Extended UDS fault detail is only supported by current gen. interfaces" MY09?
My question is in the title. Why does this show up instead of fault code details/description using HEX-CAN-USB interface and 19.x VCDS on 09' MY Golf, for example?
I can't remember seeing this with older 17.x, 18.x VCDS versions.
One example:
One example:
Friday,20,December,2019,21:09:09:32442
VCDS Version: 19.6.1.0
VIN: WVWZZZ1KZ9W535590 License Plate:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 77
VIN: WVWZZZ1KZ9W535590 Mileage: 483100km-300184miles
42-Door Elect, Driver -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 MC HW: 03L 906 022 G
Component: R4 2,0L EDC G000SG 3593
Revision: 13H01--- Serial number:
Coding: 0000071
Shop #: WSC 12345 935 999999
VCID: 72EBB0F76DD19BDF9F-8026
001652 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Mileage: 451300 km
Date: 2013.05.17
Time: 17:58:34
RPM: 1081 /min
Voltage: 11.25 V
Temperature: -1.8°C
Bin. Bits: 10110000
Time: 2.52 s
Temperature: -1.8°C
008200 - Intake Manifold Flap; Bank 1
P2008 - 000 - Electrical Malfunction - Intermittent
Fault Frequency: 28
Mileage: 480008 km
Date: 2014.03.17
Time: 17:36:37
Load: 17.3 %
Load: 100.0 %
Lambda: 100.2 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 15.3°C
001575 - Fuel Pump Relay Control Circuit
P0627 - 000 - Open Circuit - Intermittent
Mileage: 481481 km
Voltage: 11.78 V
Pressure: 8.0 bar
Inj. Quantity: 0.0 mg/str
Lambda: 15.0 %
Lambda: 7.9 %
009778 - Relay for Fuel Pump 2 (J49)
P2632 - 000 - Open Circuit - Intermittent
Mileage: 481481 km
Date: 2014.04.12
Time: 14:55:37
Voltage: 10.49 V
Pressure: 0.0 bar
Lambda: 31.6 %
Lambda: 11.0 %
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - Intermittent
Mileage: 481658 km
Date: 2014.04.22
Time: 21:37:25
RPM: 782 /min
Voltage: 14.29 V
Lambda: 88.4 %
Lambda: -20.5 %
Bin. Bits: 00011110
Voltage: 1.748 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Voltage: 0.00 V
Hex Value: 0xFF00
Bin. Bits: 00000000
Temperature: -90.0°C
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B200D092500FF881004ED901900423000
VCID: 74E7B6EFD7C595EF8D-8020
Part No SW: 3C8 907 336 HW: 3C8 907 336
Component: Climatic 120 0102
Revision: 00004001
Coding: 0000000000
Shop #: WSC 80093 222 69422
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 6ADBA8978D01531F27-803E
9473905 - Motor for Temperature Flap
B108F 71 [008] - Actuator stuck
Fault Frequency: 61
Reset counter: 32
Mileage: 482177 km
Date: 2019.12.11
Time: 19:55:40
9477394 - Motor for Air Distribution Flap
B109D 12 [009] - Short to Plus
Reset counter: 253
Mileage: 450843 km
Date: 2018.12.19
Time: 07:32:04
13701488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[COLOR="#FF0000"] [New feature! Extended UDS fault detail is only supported by current gen. interfaces][/COLOR]
Reset counter: 20
Mileage: 481481 km
Date: 2019.11.19
Time: 14:19:06
13701504 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 31
Mileage: 482134 km
Date: 2019.12.07
Time: 15:13:59
Part No SW: 1K0 937 085 HW: 1K0 937 085
Component: BCM PQ35 B+ 020 0360
Revision: 00020000
Coding: 46180A3A90251A9040000080100000E445010088524D8960648000000000
Shop #: WSC 79103 146 83050
VCID: 6CD7AE8F8FF54D2F55-8038
Component: Wischer 13030 21 0501
Coding: 009795
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 76
Reset counter: 6
Mileage: 482229 km
Date: 2014.05.07
Time: 19:24:36
Voltage: 14.40 V
Term 50 Off
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 248
Mileage: 482229 km
Date: 2014.05.07
Time: 19:24:36
Voltage: 14.40 V
Term 50 Off
Fault Frequency: 26
Reset counter: 45
Mileage: 482229 km
Date: 2014.05.07
Time: 20:15:11
Voltage: 11.90 V
Term 50 Off
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 033 0604
Serial number: 003C2R36057M
Coding: 00003135
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77FD81E3CEB3FEF7A8-8022
Component: S.Sens.Fahr.V U01 ----
Serial number: 5F280243ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 19523146ZZZZZZZZZZZZ
Serial number: 12231C11ZZZZZZZZZZZZ
Serial number: 16041E0EZZZZZZZZZZZZ
Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
Component: J0527 051 0101
Coding: 0001042
VCID: 7CF79ECF3F95DDAFC5-8028
Part No SW: 5K0 920 860 E HW: 5K0 920 860 E
Component: KOMBI H21 0030
Coding: 170A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: 2E5364877169FF3F3B-807A
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K09316059F
Coding: E9801F06000602000002
VCID: 377D41E346333EF768-8062
01304 - Radio
Reset counter: 5
Mileage: 450177 km
Date: 2013.05.04
Time: 00:02:05
Reset counter: 19
Mileage: 481481 km
Date: 2014.04.11
Time: 14:19:05
Reset counter: 30
Mileage: 482134 km
Date: 2014.04.29
Time: 15:13:59
00469 - Infotainment Databus in Single Wire Operation
Reset counter: 5
Mileage: 478411 km
Date: 2014.02.22
Time: 22:11:07
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0030
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09.rod
Part No SW: 1K0 959 701 AM HW: 1K0 959 701 AM
Component: Tuer-SG 008 2041
Coding: 0000118
VCID: 79F987DB30A7E887DE-802C
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A5B68978581931FE7-807E
Part No SW: 1K0 959 702 AM HW: 1K0 959 702 AM
Coding: 0000118
VCID: 7AFB98D735A1E39FD7-802E
00940 - Mirror Adjust Motor; Passenger Side (V150)
Address 56: Radio
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 B HW: 1K8 035 730 B
Component: Telefon H08 5400
Revision: 00008000 Serial number: 20389520082400
Coding: 001120
VCID: 285F929F5B8DA10FF1-807C
03427 - Right Audio Channel
Reset counter: 238
Mileage: 450177 km
Date: 2013.05.04
Time: 00:01:30
01304 - Radio
Reset counter: 5
Mileage: 450177 km
Date: 2013.05.04
Time: 00:02:08
End-------------------------(Elapsed Time: 02:19)--------------------------
