Adaptation is grayed out on Controller A5
findcoop
Canada
C?ID=6102
Hello all,
I'm not sure if it was always this way, or I somehow broke it with tweaking, or if it's another problem. To the best of my knowledge, coding for A5 is stock. I only have Coding and Security buttons on the right side available for this controller. Adaptation works with other controllers, such as 09. Vehicle is 2018 Atlas Execline (Canada). TIA!
Friday,20,December,2019,15:27:50:55377
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
VCDS Version 19.6.2.0
VIN: 1V2NR2CA3JCxxxxxx   License Plate:
Chassis Type  CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
          52 5F 69 6C 6D A5 CA
VIN: 1V2NR2CA3JCxxxxxx   Mileage: 27314km-16972miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (0-32-CDVC)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 026 J    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 6026
   Revision: 52H21000
   Coding: 012A003244740108B0000000000000000000000000000000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM36FSI01103H906026J 001005
   ROD: EV_ECM36FSI01103H906026J.rod
   VCID: 2C5683F547D3662F2B-8079
   CAN Converter 01:
4718 - No Communication with Transmission Control Module
          U0101 00 [032] - -
   Part No SW: 09G 927 158 A    HW: 09G 927 158
   Component: AISIN AQ8     206 3387
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 3168928160F10BC718-8065
   Revision: 00000000    Serial number: 51768000000083
   Coding: 44FC6B8D84281A70C57F0308A2CA6922D62158A3C045967E38415058C2AA4200002F641C12141A118DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
   VCID: 77FC6C99CE1515F796-8023
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0480530147
   Coding: 1F20000723
   VCID: 3E72B9BDA1AFE4BF95-806B
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11078902
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CN 907 044 M    HW: 3CN 907 044 M
   Component: Climatronic   H05 2009
   Revision: 00001K03
   Coding: 1602002620001C001104214C5210150C
   ASAM Dataset: EV_ACClimaBHBVW416 002012
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 4998DA61E861530730-801D
   Fresh Air Blower Back:
   Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H36 0253
   Serial number: 8163005002ÿÿÿÿ
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081E1F65B3EB6A0FEF-805D
   Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  050 0122
   Serial number: S6Y18M05D15H20M25S36
   Coding: 00382D
   Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z00IL02
   Coding: 150000
   Garage Door Opener Operating Unit:
   Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
   Component: GTO BF  H06 0007
   Serial number: 8MW00108021800010090
   Seat Backrest Fan 1 Front Left:
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE1002752
   Seat Cushion Fan 1 Front Left:
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1025960
   Seat Backrest Fan 1 Front Right:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1005133
   Seat Cushion Fan 1 Front Right:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1026516
8970 - Bulb for Right Fog Lamp
          B1220 15 [008] - Open or Short to Plus
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
   Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0453
   Serial number: 000145451R18168
   Coding: 0271267951
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 53A4F8093A2D19D74A-8007
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 320007C959FFC728949C810530400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
1236 - Databus
   Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
   Component: Airbag VW21   006 0713
   Revision: --------    Serial number: 003SUMII5KMb
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B142069A29D0117C2-805F
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J180009MFKY02
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 000 605 18
   Serial number: 357000000009240D3036
   Subsystem 3 - Part No SW: -----------    HW: 454 001 204 18
   Serial number: 358000000001A74CDF2.
   Subsystem 4 - Part No SW: -----------    HW: 454 800 906 18
   Serial number: 351001737BA14000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 800 706 18
   Serial number: 352001E2CF214000000I
   Subsystem 6 - Part No SW: -----------    HW: 454 801 204 18
   Serial number: 35500DC793114000000K
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 801 204 18
   Component: FrontSensor_P  304 0149
   Serial number: 35600767431140000004
   Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0140
   Revision: --------    Serial number: 26041804400771
   Coding: 0C10
   VCID: 030408498ACD4957BA-8057
   Part No SW: 3CG 920 791 A    HW: 3CG 920 791 A
   Component: KOMBI         406 3196
   Coding: 0BAD0F1DEF8C880902886B0B50010000A0000000
   VCID: 3A7AB5ADBD87C89FA9-806F
16777012 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
   Component: GW MQB High   518 5323
   Serial number: 02021800840537
   Coding: 0B0500347F087300FB0322581E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 387EAFA5838BDA8F5F-806D
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 33180000793870081439
   Coding: 36FFFF
   Serial number: 9436445800
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0860
   Serial number: 0035597
   Serial number: HA1-00007.05.18
   Coding: 0301
   VCID: 4C96E375E713462F0B-8019
   Serial number: 18000172160001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 336498899AED39D76A-8067
No ASAM data for: "EV_ELVMarqMQBA0" (VW41)
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Serial number: Y0006RFE20574
   Coding: 0010000000000500018280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D70BEB1ACA9FFA78C-8069
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Serial number: 0480117485
   Coding: 02012103
   ROD: EV_HREntryHella_VW27.rod
No ASAM data for: "EV_HREntryHella" (VW41)
   Serial number: 210518A0080TB7
   Coding: 001F1B20D200020000000000
   VCID: 4384C849CA4D8957FA-8017
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000425611
   Coding: 011000
   Revision: 00000000    Serial number: 0002534175
   Coding: 01010311004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 408EC745DB5B924FE7-8015
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD02J7T
   Coding: 2214060002AAAFAA000000000000
   ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
   ROD: EV_AMPMst12C3Gen2ALPI.rod
   VCID: 2E5289FD71CF143F05-807B
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Serial number: 270518A0080L89
   Coding: 001F1320DE00020000000000
   VCID: 428ACD4DD557805FF1-8017
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000458364
   Coding: 091000
   Part No SW: 3QF 035 876 A    HW: 3QF 035 876 A
   Component: MU-S-NS-US    851 0867
   Coding: 021406020000000051220002001828001F0500E4012004008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 489EDF65F36BAA0F2F-801D
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV1450327
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0479210374
   Coding: 0200000200000000
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG028414
   Coding: 01140604A30F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 3978AAA1B881C387A0-806D
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: A2-C758-8680-2
   Coding: 0988
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 4580D651C479B767D4-8011
Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 16031841P13324
   Coding: 000401060001020100221355C150890084000E200120
   ROD: EV_MFKBoschMQBB_001_VW27.rod
No ASAM data for: "EV_MFKBoschMQBB" (VW41)
Address CA: Sunroof
End-------------------------(Elapsed Time: 07:08)--------------------------
Adaptation is grayed out because VCDS couldn't load any ASAM data. I'm not exactly sure why. It may be a chassis identification problem with the HEX+CAN you're using on that vehicle. As you can see from some of the other modules that it can't talk to at all, that's a marginal situation at best.
Santos
Have you tried running it on a non emulated environment?
findcoop
Canada
C?ID=6102
Hi Santos, it would be worth a try but I don't have a bare-metal Windows device at present.
findcoop
Canada
C?ID=6102
Adaptation is grayed out because VCDS couldn't load any ASAM data. I'm not exactly sure why. It may be a chassis identification problem with the HEX+CAN yoTu're using on that vehicle. As you can see from some of the other modules that it can't talk to at all, that's a marginal situation at best.
Thanks, Uwe. I assumed the non-communicative modules were the ones that I couldn't get to because my cable is too old. Did you see some other ones that I should be able to get to, adding another symptom to my problem? TIA.
