VCDS Mobile No Asam data found
ciprianglg
Romania
C?ID=383325
I try to use my hex-net on my passat 2011, 2.0TDI CFGB, using mobile app, but if i try to go to the engine module, or even if i do auto scan, i end up with the message that ASAM data is not found locally.
I then push the download button, but it then downloads something and is stuck. I tried this several times, but result is the same.
This the engine module using desktop version:
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BD HW: 03L 907 309 N
Component: R4 2,0L EDC H24 9953
Revision: 47H24--- Serial number: 00000000000000
Coding: 001D0012040401080000
Shop #: WSC 10127 599 00000
ASAM Dataset: EV_ECM20TDI01103L906018BD 003007
ROD: EV_ECM20TDI01103L906018BD.rod
VCID: ED92519C3CB9F027FC-80B8
Also these are error messages from the mobile app:
https://ibb.co/G3MvvDD
https://ibb.co/KXPyZDN
Can you let me know how i can fix this? I read several posts but no concrete steps to solve it. Is there an official guideline for this issue, as i see i'm not the only one with this issue.
Thanks,
Ciprian
Shaun
You can connect with usb and check for updates with VCIConfig
ciprianglg
Romania
C?ID=383325
Hi Shaun,
This helped, and missing files were downloaded and written to hex-net, but i still have HVAC module for which i think there is no available file, since is the only module for which is still complaining of missing asam data.
If i connect the interface to the laptop and use VCIConfig, it says that that rods needs to be update, downloads it, and then it will be written to the interface.
Next time i do autoscan, finds that i have missing asam data. I connect then interface again via usb, i do the updates using VCIConfig, but still no asam data for HVAC:
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 AB
Component: ClimatronicPQ35 066 0404
VCID: 6791289F5E86C479DF18EC-8032
Can something be done about this?
Thanks,
Ciprian
Hawkeye9723
C?ID=389466
I was getting the same issue with my Hex-Net too. I had to do the 50 second reset first before it would accept the data.
Shaun
I'm a little bit confused, that appears to be a regular CAN hvac, it doesn't have ASAM data since it does not talk with the UDS protocol. Any info that is documented should be in that label file, is there some information in particular that you feel is missing?
ciprianglg
Romania
C?ID=383325
Hi Shaun,
Happy new year!!!
Well the problem i have is that i can't use Advanced Measuring Values at all. When i enter to that module it says No Asam data found locally, and i select Continue Anyway. Then if i try to choose Advanced Measuring Values, i receive a screen where it says Loading ASAM dataset 0% and it stays like this forever. Only way to get rid is to choose exit, which closes the mobile app, which also don't know if is safe, as somehow the communication is ongoing during that time.
Also entering the module it says Communicating UDS.
https://ibb.co/RHjtC3D
https://ibb.co/gyPjqmH
https://ibb.co/7yC0TPz
Hi Shaun,
Happy new year!!!
Let's check some basics here. Is this happening on the HVAC module you showed details about in post #3? Because that makes no sense at all...
ciprianglg
Romania
C?ID=383325
Hi Uwe,
Yes it is happening when i select from the the list of installed modules, HVAC one.
Also when i do autoscan, when hits this HVAC module it says i have missing ASAM data.
Thanks,
Ciprian
Hi Uwe,
I'm scratching my head. This HVAC module:
... does not need, want, or use ASAM data.
Please post a complete Auto-Scan. The only explanation I can think of is that VCDS-Mobile is actually complaining about needing a ASAM data for a different module.
ciprianglg
Romania
C?ID=383325
Hi Uwe,
This is it:
VCDS Mobile 0.4508.0.4
VIN: WVWZZZ3CZBE320102
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61
	 62 6C 72 77
08-Auto HVAC -- Status: OK 16000
09-Cent. Elect. -- Status: Malfunction 16010
16-Steering wheel -- Status: OK 16000
17-Instruments -- Status: OK 16000
25-Immobilizer -- Status: OK 16000
42-Door Elect, Driver -- Status: OK 16000
46-Central Conv. -- Status: OK 16000
4F-Centr. Electr. II -- Status: OK 16000
52-Door Elect, Pass. -- Status: OK 16000
62-Door, Rear Left -- Status: OK 16000
72-Door, Rear Right -- Status: OK 16000
Address 01: Engine  (CFGB J)	Labels: 03L-906-018-CFF.clb
	Revision: 47H24---
	VCID: 6D9D5AB77C7A7629A5542E-8038
No fault codes found.
Address 02: Auto Trans	Labels: 02E-927-770.lbl
	Part No SW: 02E 300 054 H	HW: 02E927770AL
	Component: GSG DSG AG6     511  2602
	Revision: 05351112	Serial Number: 00001011020719
	Shop #: WSC 05311 000 00000
	VCID: 1B79446FD24ED0998B00B0-804E
Address 03: ABS Brakes	Labels: 3AA-614-109.clb
	Part No SW: 3AA 614 109 M	HW: 3AA614109M
	Component: J104   C2 450M V4F5  0005
	Revision: --H07---	Serial Number: 00000003484231
	Coding: 0006588
	VCID: 3731B8DF4EA694F98F38FC-8062
Address 08: Auto HVAC  (J255)	Labels: 5K0-907-044.clb
	Part No SW: 5K0 907 044 EA	HW: 5K0 907 044 EA
	Component: Climatronic   H17 1010
	Revision: 00003001
	Coding: 0000000003
	Shop #: WSC 00015 115 00000
	ROD: N/A
	VCID: 6E9F5DBB717C8D319C5E21-803B
	No ASAM data for: "EV_Climatronic"
Address 09: Cent. Elect.  (J519)	Labels: 3AA-937-087.clb
	Part No SW: 3AA 937 087 A	HW: 3AA 937 087 A
	Component: BCM PQ47 H    413 0452
	Revision: BB413001
	Coding: 000000000000000000180080540081E443510088426D85606480C7200041
	VCID: 3833BBE343B81B818622F7-806D
	Subsystem 1 - 	Part No SW: 3AB-955-419	Labels: 1Kx-955-119.clb
	Component: Wischer 1511110  0603
	Coding: 00B795
	Subsystem 2 - 	Part No SW: 1K0-955-559-AH	Labels: 1K0-955-559-AG.clb
	Component: RLS 171110 0554  0403
	Coding: 033028
		Fault Status: 00100001
		Reset Counter: 27
		Mileage: 239694 km
		Date: 2039.14.12
		Time: 15:36:36
		: Term 15 On
		Voltage: 14.85 V
		: ON
		: ON
		: ON
		: OFF
		: ON
Address 10: Park/Steer Assist  (J446)	Labels: 3AE-919-475.clb
	Part No SW: 3AE 919 475	HW: 7N0 919 475
	Component: PARKHILFE 8K  H04 0009
	Revision: --------
	Coding: 308102
	ASAM Dataset: EV_EPHVA18VW47X0000 001003
	ROD: EV_EPHVA18VW47X0000.rod
	VCID: FCBBE7F3B7006FA1A2CA4B-80A9
Address 15: Airbags	Labels: 5N0-959-655.lbl
	Part No SW: 5N0 959 655 R	HW: 5N0959655R
	Component: J234__101 VW10 HI    1918
	Revision: 22014000	Serial Number: 003K0PPEDR42
	Coding: 0012337
	VCID: 4CDBF73327200721D2EADB-8019
	Subsystem 1 - 	Serial Number: 6332MTS647353070
	Subsystem 2 - 	Serial Number: 6342MTS654763070
	Subsystem 3 - 	Serial Number: 6351HTS6FQA1G6KJ
	Subsystem 4 - 	Serial Number: 6361HTS61HC1G6KJ
	Subsystem 5 - 	Serial Number: 00000000000000000
	Subsystem 6 - 	Serial Number: 00000000000000000
Address 16: Steering wheel  (J527)	Labels: 3C-16.lbl
	Part No SW: 3C9 953 501 BF	HW: 5K0 953 569 S
	Component: LENKS.MODUL   009 0136
	Revision: FF010039
	Coding: 199A050000
Address 17: Instruments  (J285)	Labels: 3C8-920-xxx-17.clb
	Part No SW: 3AA 920 870 A	HW: 3AA 920 870 A
	Coding: 161B00
	Shop #: WSC 36860 001 1048576
	ROD: EV_Kombi_UDS_VDD_RM09_A04_VW46.rod
	VCID: 302383C3ABC8DBC1CEF28F-8065
Address 19: CAN Gateway  (J533)	Labels: 7N0-907-530-V2.clb
	Part No SW: 7N0 907 530 G	HW: 1K0 907 951
	Component: J533  Gateway H41 1614
	Revision:   H41
	Coding: 462006
	Shop #: WSC 05314 000 00000
	VCID: 342B8FD35FD0FFE1AA1AA3-8061
Address 25: Immobilizer	Labels: 3C0-959-433-25.clb
	Part No SW: 3AA 959 433	HW: 3AA959433
	Component:    IMMO         043  0399
	Revision: 00043000	Serial Number: VWZCZ000000000
	VCID: F6AFF5DB892CADF1D48E09-80A3
	Subsystem 1 - 	Part No SW: 3C0-905-861-J
	Component:    ELV          029  0380
Address 37: Navigation  (J0506)	Labels: 1T0-035-680.clb
	Part No SW: 1T0 035 680 C	HW: 1T0 035 680 C
	Component: RNS-MID       H42 2720
	Revision: AB001001
	Coding: 0C0004000400008000
	Shop #: WSC 49522 150 89505
	VCID: 2E1F9DBBB1FCD531DCDE61-807B
Address 42: Door Elect, Driver  (J386)	Labels: 3C0-959-70X-GEN4.clb
	Part No SW: 3AA 959 701 A	HW: 3C0 959 793 C
	Component: TUER-SG FT    002 0529
	Revision: 12110009
	Coding: 0200B7
	Shop #: WSC 05311 115 00000
	ROD: EV_TSGFPQ35BRFVW46X.rod
	VCID: 352DB2D754AAFEE99D04D6-8060
Address 44: Steering Assist	Labels: 5N1-909-144.clb
	Part No SW: 5N1 909 144 L	HW: 5N1909148G
	Component: J500__APA-BS KL.310  0802
	Revision: 1AH03729	Serial Number: 00103270191001
	Coding: 0000258
	VCID: 3B39A4EF728EB0996B4010-806E
Address 46: Central Conv.	Labels: 3C0-959-433-46.clb
	Component:    KSG PQ47 ELV 043  0631
	Coding: 0091020052830E76300494157C084F0B607801
	Subsystem 1 - 	Component:   Sounder n.mounted
	Subsystem 2 - 	Component:       NGS n.mounted
	Subsystem 3 - 	Component:      IRUE n.mounted
Address 4F: Centr. Electr. II  (J520)	Labels: 1K0-907-532.clb
	Part No SW: 7N0 907 532	HW: 1K0 907 951
	Component: EZE_2         H41 1614
	Revision:   H41
	Coding: 00000008
	VCID: EFA1C0BFF6761C391748D4-80BA
	Subsystem 1 - 	Part No SW: 3AA-919-204
	Component: Analoguhr    003 0003
Address 52: Door Elect, Pass.  (J387)	Labels: 3C0-959-70X-GEN4.clb
	Part No SW: 3AA 959 702 A	HW: 3C0 959 792 C
	Component: TUER-SG BT    002 0529
	Revision: 14110009
	Coding: 0200B6
	ROD: EV_TSGBPQ35BRFVW46X.rod
	VCID: 362FB5DB49ACF5F1940EC9-8063
Address 53: Parking Brake	Labels: 3AA-907-801.clb
	Part No SW: 3AA 907 801 E	HW: 3AA907801E
	Component: J540 EPB4  VW-55183  0007
	Revision:   H18   	Serial Number: 00000000059084
	Coding: 0022067
	VCID: 33298CCF5ADE78D9B310A8-8066
Address 56: Radio  (J0506)	Labels: 1T0-035-680.clb
	Revision: AB001001
Address 61: Battery Regul.  (J840)	Labels: 1K0-907-534.clb
	Part No SW: 7N0 907 534	HW: 1K0 907 951
	Component: Batt.regelung H41 1614
	Coding: 030B185A
	VCID: F1A5C6C7E0420AC9017CC2-80A4
	Subsystem 1 - 	Part No SW: 1K0-915-181-F
	Component: J367-BDM     H07 0150
Address 6C: Back-up Cam.	Labels: 5N0-907-441.clb
	Part No SW: 3C9 907 441	HW: 3C9907441
	Component: J772__Rearview       0020
	Revision: 00H08000	Serial Number: 525PA8-J0Y0628
	Coding: 0020007
	VCID: E893ABA3D3984B01560267-80BD
Address 77: Telephone  (J412)	Labels: 7P6-035-730.clb
	Part No SW: 7P6 035 730 D	HW: 7P6 035 730 D
	Component: TELEFON       H05 0440
	Revision: 1B001001
	Coding: 0A01000000000001
	ASAM Dataset: UHVNA A01007
	ROD: UHVNA.rod
	VCID: 33298CCF5ADEE0D9B310A8-8066
End--(Elapsed Time: 02:20, VBatt start/end: 12.2/12.2 Vign: 12.2)-
So seems there is an ASAM dataset used by HVAC module, and my previously paste didn't included this one, which is odd somehow as i don't recall from where i took it, either mobile or desktop.
Anyway now maybe makes more sense:
Revision: 00003001
Coding: 0000000003
ROD: N/A
Sir, that is clearly not the same HVAC module that you previously posted the details from. ;)
It is not clear to me why the server is not giving your HEX-NET ASAM data for that module, but I can see that it is indeed not doing so.
ciprianglg
Romania
C?ID=383325
Hi Uwe,
Seems like if i push save after autoscan, i was expecting to have the file seen on the cloud, but seems like for this car didn't happen, and i figure out today when i tried to put the autoscan ( i didn't find it in the cloud). So the HVAC module is actually from my other car, because i didn't paid attention to the vin, i was looking to.
I looked on the saved files on the mobile, and tried to upload them manually, but didn't had luck, might be a limit/time/upload.
Anyway sorry for that mistake, and hopefully we can find a solution to this.
Also i looked on an older log now, for which i didn't had ASAM data, and now those are fixed, except this HVAC:
Revision: 1B001001
ROD: N/A
No ASAM data for: "UHVNA"
Revision: 14110009
Coding: 0200B6
ROD: N/A
No ASAM data for: "EV_TSGBPQ35BRFVW46X"
Coding: 161B00
ROD: N/A
No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
And so on..
ciprianglg
Romania
C?ID=383325
Hey guys,
Any way, we can figure out how i can solve my issue on vcds mobile app for the following module?
Revision: 00003001
Coding: 0000000003
ROD: N/A
Thanks,
Ciprian
