Function not supported by gateway
samridh
India
C?ID=336220
My car just came back from Audi service center after service and i found they have deleted all the tweaks done by me and restore it to original so i tried to do all that again but as i connected vcds its coming Function not supported by gateway. Please help what could be the reason before this i have used same laptop same cable on same car never had this issue.
Santos
What kind of car? What version of VCDS? Is the key on in the ignition? What color are the LEDs on the interface cable?
samridh
India
C?ID=336220
Audi A6 c7 2018 petrol, VCDS 19.6.2, yes it’s in ignition, green blink on cable.
Green LED just means it has power on Vbatt (pin 16 of the diagnostic connector).
[Options] -> [Test] in VCDS please. Look at the last line: What is the voltage shown by Vign?
If that's less than 11V, your ignition isn't really on. If it's over 11V, try opening the car's hood ("bonnet").
samridh
India
C?ID=336220
It’s showing 12.5v
samridh
India
C?ID=336220
Have done by opening Bonet also result is same.
What happens if you try to access the Gateway directly?
[Select]
[19-CAN Gateway]
samridh
India
C?ID=336220
Same not supported by gateway
That doesn't make sense to me.
At what point, exactly, does VCDS say that when you click:
[Select]
[19-CAN Gateway]
samridh
India
C?ID=336220
It try 2-3 times then this error comes
samridh
India
C?ID=336220
Any other scanners are also not working is it possible there may be problem with my OBD.
