VW t5 OEM RC High Line retrofit
AlexJoe
Poland
C?ID=348213
I have installed:
BCM 7H0937090B
high line camera module 7E0907441 (coding 0000016) - I haven't OPS and trailer hitch module installed.
Camera 7E0980551A
RNS 510 (1T0035680R)
TV tuner 7L6919148A
wiring harness 7E7971327C
Steering angle sensor 6Q0959654D
Steering angle sensor and RNS 510 working properly, in addition, reverse gear is correctly detected.
I 've no error in RNS 510, in RVC module (6c) I've information that camera is not calibrated.
Unfortunately, when starting on RNS 510, a message is displayed saying that the rear view camera system is not currently available.
Nothing happens when reverse gear is engaged (no camera image displayed).
In the camera module measuring blocks I have:
Terminal 15 Status Term 15 On
Reverse Gear Status Reverse ON
Voltage (Terminal 30) 12.14 V
Camera Voltage 6.40 V
Connection to Camera Camera-sync
Connection Status (Camera) Active
Connection to Display Display-sync
Connection Status (Display) Active
Steering Angle (Current) -11.85°
Back-Up Cam. Status 3
Can anyone tell me what else I could have done wrong?
Should this hardware kit work? Does the BCM version support the camera module?
iichel
Eindhoven, NB, NL
C?ID=284912
--> yes, we need an autoscan please :) See below on how to post
AlexJoe
Poland
C?ID=348213
Tuesday,17,December,2019,12:53:05:64257
Chassis Type: 6N0
Scan: 04 09 19 37 56 57 6C
57-TV Tuner -- Status: Malfunction 0010
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 308130974
   Coding: E0A0393A0A212012002008102C2B8CFC0080430F60860000320000000000
   VCID: 2D070A04FD1E8E7F521-8078
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 042200
   VCID: 70B9D3702AACA397397-8024
                    Reset counter: 234
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H31 6276
   Revision: AB001001    Serial number: VWZ6Z7T1195825
   Coding: 00010200010000A00014
   VCID: 3D273A442D7E1EFFE21-8068
   Component: EU West V15  8515
00869 - Line Output; Rear Right
                    Reset counter: 199
00860 - Line-Output; Rear Left
                    Reset counter: 199
                    Reset counter: 199
00001 - Brake Control Unit
                    Reset counter: 200
                    Reset counter: 199
                    Reset counter: 199
                    Reset counter: 199
                    Reset counter: 200
Address 57: TV Tuner        Labels: 7L6-919-148.clb
   Part No SW: 7L6 919 148 A    HW: 7L6 919 148
   Component: R0078 TVhybridDVB   0150
   Revision: R0H21000    Serial number: 93900500870301
   Coding: 0020801
   Shop #: WSC 01065 000 00000
   VCID: 3A2D3158305029C7C73-806E
03230 - Video Input for Rear Seat Entertainment
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 234
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Revision: 00H13000    Serial number: 525PA8-J440305
   Coding: 0000016
   Shop #: WSC 02971 612 181466
   VCID: 6597B224E96E763F5A1-8030
03006 - Back-up Camera System not calibrated
                    Reset counter: 234
                    Reset counter: 234
                        Reverse OFF
                    Count: 3
                    Reset counter: 234
                        Reverse OFF
                    Count: 3
End----(Elapsed Time: 00:50, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
Spacewalker
Poland
C?ID=159607
why you edit VCDS autoscan ?
do we ask for part of Autoscan ?
or.....just begining ?
maybe unvisible??
or.....custom ?
no .....
AlexJoe
Poland
C?ID=348213
I don't edit autoscan. I have two CAN installations. One factory vehicle (2005 and TP1.6), the other with separate BCM and TP2.0.
iichel
Eindhoven, NB, NL
C?ID=284912
RVC will not work if instrument cluster is not present.
AlexJoe
Poland
C?ID=348213
Even if I've gateway in BCM?
iichel
Eindhoven, NB, NL
C?ID=284912
yes, will not work. it needs instrument cluster, just like the PDC. I don't know why, but it is the case.
AlexJoe
Poland
C?ID=348213
Ups.... It hurt ... It means that I would have to replace the cockpit installation. Has anyone tried to run ECU16U31 (old engine) the new BCM?
AlexJoe
Poland
C?ID=348213
I knew that. But I did not find information anywhere that someone had done it before.
AlexJoe
Poland
C?ID=348213
I did it. At the moment I have a BCM from T6 7E0937090D, on bit 24, the conversion is turned on for the CAN Drivetrain TP 1.6 <-> 2.0 line, the engine controller is not changed from the T5 (AXD 2.5 TDI engine, manual 6-speed gearbox). The driver assistance systems are already all from the T6 (so communication in TP 2.0). I still have problems with communication between the dash and ABS (the ABS is working properly, but the dash has an error message ESP and brake assist on hills, which I do not have) . I have not started webasto yet, but by the way I upgraded the air conditioning from CLIMATIC to full CLIMATRONIC (front and rear).
