P032A, P0171 3.0 TDI
Yamajet
C?ID=206536
Any ideas where to start on this one? Thanks
Saturday,14,December,2019,14:51:31:00348
VCDS Version: 19.6.2.0 (x64)
VIN: WVGEP9BP8ED00xxxx License Plate:
Mileage: 71309 Repair Order:
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 7P0 907 401 K HW: 7P0 907 401 K
Component and/or Version: 3.0TDI FSA X21 0011
Software Coding: 292A4012233600050000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_ECM30TDI0117P0907401K 001012 (VW52)
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: 377D2C2E8E4CD8F756-8062
37624 - Cylinder 2 Pressure Sensor
P03A2 00 [108] - Short to Plus
Fault Frequency: 131
Mileage: 114404 km
Date: 2019.12.07
Time: 07:30:19
Engine speed: 2544.50 /min
Normed load value: 79.2 %
Vehicle speed: 73 km/h
Coolant temperature: 64 °C
Intake air temperature: 10 °C
Voltage terminal 30: 14.740 V
Maximum cylinder 2 cylinder pressure: 230.352 bar
Cylinder 2 max pressure position in deceleration mode: 0.68 °
Cylinder_pressure_offset_cylinder_2: 0.000 bar
Malfunction status of combustion chamber pressure of cylinder 2-Bits 0-7: 0
Group run time cylinder pressure sensor 2: -0.5 µs
21232 - Fuel Trim; Bank 1
P0171 00 [236] - System Too Lean
Mileage: 114547 km
Date: 2019.12.11
Time: 11:44:26
Engine speed: 1232.00 /min
Normed load value: 29.0 %
Vehicle speed: 23 km/h
Coolant temperature: 59 °C
Intake air temperature: 9 °C
Voltage terminal 30: 14.840 V
Air mass: actual value (mg/stroke): 645.7 mg/stroke
Standardised airflow ratio: 0.9015
Ambient temperature: 8.5 °C
Mean injection quantity: 11.99 mg/stroke
O2 sensor 1 bank 1: O2 sensor actual value: 7.407
Pressure control valve adaptation factor: 1.0916
myounus
Northwest UK
C?ID=321059
Please post a full scan for completness.
I'd check the wiring for breaks/damage water ingress.
