2009 JSW 2.5L 5-Speed Stock Condition-ABS, ESP Blinking Brake Light
N2VDUBZ
C?ID=389080
Good day all. I am a Ross-Tech NEWB. I am having the "ABS, ESP, Blinking Brake Light" issue. No modifications were done prior to the issue happening. I did the scan and there are three faults, as you can see below. Now I need some assistance with understanding what these faults mean and how to correct them. I am still able to drive the vehicle, but I'd like to get it fixed, as it is my teenage daughter's car. Can someone provide a newbie some guidance? Thanks.
Brian from Kansas
Monday,09,December,2019,18:07:58:28052
VIN: 3VWKM71K09M284730   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWKM71K09M284730   Mileage: 262730km-163252miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 Q    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9204
   Revision: G6H02---    Serial number: VWX7Z0H82410V1
   Coding: 0000071
   Shop #: WSC 00066 000 00000
   VCID: 3C21334A1A6D7EA7D5F-8068
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 113B400D492A00FE881202E7921900413000
   Shop #: WSC 53968 001 1048576
   VCID: 76B5E16268C1E4F7E3B-8022
16352 - Control Module - Electrical Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 205
                    Mileage: 262283 km
                    Count: 32768
                    Count: 4608
                    Count: 96
                    Count: 52265
                    Count: 3
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EF5A6ED59287F17-802C
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001070697
   Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
   VCID: 323D1D72C829B8D70F3-8066
   Component: Wischer 021008 021  0501
   Coding: 00038805
   Shop #: WSC 00066
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 247
                    Mileage: 262289 km
                    Voltage: 12.30 V
00927 - Terminal 30 (Right)
                    Reset counter: 247
                    Mileage: 262289 km
                    Voltage: 12.30 V
   Component: 78 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M070AT2
   Coding: 0014136
   VCID: 6C81C30A2A8D2E2705F-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3E1471629
   Subsystem 3 - Serial number: 6342MSME38302E002
   Subsystem 4 - Serial number: 6351HSME16612C689
   Subsystem 5 - Serial number: 6361HSME16723444%
   Subsystem 6 - Serial number: 63727SME173C3551/
   Subsystem 7 - Serial number: 63827SME157E043C7
   Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
   Coding: 0000022
   VCID: 73B3D87677B3F1DFC45-8026
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H82410V1
   Coding: 0007203
   Shop #: WSC 12345 067 57207
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 130808F1001314
   Coding: E9807F070002022002
   VCID: 3537266E3947AFEF2A1-8060
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000928688918
   Coding: 0001205
   VCID: 6FBBD4061B9BD53F20D-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A0D0512E0F9F017B73-807E
   Coding: 139007885283281B0904058FB0880F0488DCA0
   VCID: 04518BAA221DC667EDF-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000253788903
   Coding: 0001204
   VCID: 70B9D77A06A5CAC7397-8024
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       018 0021
   Revision: 00018000    Serial number: VWZ4Z7H6381199
   Coding: 0040401
   VCID: 2019E73A96C53A47E97-8074
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003496907
   Coding: 0001168
   VCID: 76B5E16264C1E4F7E3B-8022
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003466929
   Coding: 0001168
   VCID: 77ABEC6663CB9DFFF8D-8022
End----(Elapsed Time: 01:16, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
N2VDUBZ
C?ID=389080
Thanks Uwe. I checked my VIN and it doesn't show up on the recall list. Any recommendations?
