Audi A4 2009 battery coding issue
Dp41n8w
C?ID=372411
Hello. I changed battery to audi and the battery needs coding. I have tried code battery, but when I press TEST then there comes old battery coding value back. There is 26 digits but car dont accept new coding? can someone give me advice?
Wednesday,11,December,2019,15:11:31:19148
VIN: WAUZZZ8K59A085140   License Plate: AUDI
Mileage: 211710km-131550mi   Repair Order:
Long Adaptation Channel 004:
Stored value 8K0915105D  MLA 180722MRY1
Test value 8K0915105D  MLA 180722MRY1
Battery Information/Replacement
  N/A
  N/A
  N/A
  N/A
Autoscan:
Wednesday,11,December,2019,15:17:52:19148
VIN: WAUZZZ8K59A085140   License Plate: GML-530
Mileage: 211710km-131550mi   Repair Order: AUDIA4B8
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 69 72
VIN: WAUZZZ8K59A085140   Mileage: 211710km-131550miles
Address 01: Engine (-----CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 A    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H12 0002
   Revision: E1H12---
   Coding: 010C000C180F0920
   Shop #: WSC 40350 222 93973
   ASAM Dataset: EV_ECM20TFS8K2907115A A01003
   ROD: EV_ECM20TFS8K2907115A.rod
   VCID: 2D0709A39D9592AF521-8078
Readiness: 0110 0101
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 07C500
   Shop #: WSC 06335 000 00000
   VCID: 7BA3F7FB13E1CC1F9C5-802E
   Part No SW: 8K0 907 064 AD    HW: 8K0 907 064 AD
   Component: BCM2 1.1      H71 0134
   Coding: 070200
   VCID: 72BDDADF44AB8D57CF3-8026
   Subsystem 1 - Part No SW: 8K0 959 754 D    HW: 8K0 959 754 D
   Serial number: 0816000082984019
   Serial number: 0208000036243002
03286 - Sensor for Contact with Door Handle; Front Right
                    Fault Status: 00100111
                    Reset counter: 57
                    Mileage: 211717 km
                    Date: 2019.12.11
                    Time: 10:18:07
03285 - Sensor for Contact with Door Handle; Front Left
                    Fault Status: 01101011
                    Reset counter: 17
                    Mileage: 211717 km
                    Date: 2019.12.11
                    Time: 11:05:50
                    Reset counter: 17
                    Mileage: 211717 km
                    Date: 2019.12.11
                    Time: 11:05:50
   Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
   Component: KLIMA 1 ZONE  H06 0140
   Revision: A1000000    Serial number: 0125.07.080210
   Coding: 64000000
   VCID: 70B9D0D74AA7BF47397-8024
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Revision: 05022001    Serial number: 00000000187436
   Coding: 2600D0914034AF010001000300001D0D0F1C270800010101000000
   VCID: 303910D78A27FF47797-8064
   Component: WWS 190708  H06 0070
   Serial number: SWFBIE 0006256
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10196430
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002607080796
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD17TWM5
   Coding: 30343434363030303030554A304C384B3053
   VCID: 3C2134E756EF0B27D5F-8068
   Serial number: 6334MSME3E15624EM
   Serial number: 6344MSME526D5824J
   Serial number: 6352QSME7E612123D
   Serial number: 6362QSME750B3231A
   Serial number: 63732SME6A492D4BF
   Serial number: 63832SME20522060H
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HGM000C0
   Coding: 000017
   VCID: 3D2739E34D75022FE21-8068
   Part No SW: 8K0 920 930 A    HW: 8K0 920 930 A
   Component: KOMBIINSTR.   H16 0224
   Revision: 00000000    Serial number: 9DZ195W78
   Coding: 0F04110002000008010000
   VCID: 2B0307BBA3019C9F4C5-807E
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G0871482C2
   Coding: 000303
   VCID: 46D5560F18A341F7B3B-8012
   Component: J367-BDM  H04 0150
   Serial number: 180316C1110708
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Revision: 00000000
   Coding: 020202
   VCID: 78A9E8F722D7E707F17-802C
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007498221
   Coding: 011C12204000410001
   VCID: 3FDB43EB4779103FF0D-806A
   Revision: 00002001    Serial number: 0113125985
   Coding: 013A0E2020390041003002
   Shop #: WSC 06325 000 00000
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 17
                    Mileage: 211717 km
                    Date: 2019.12.11
                    Time: 11:22:18
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 17
                    Mileage: 211717 km
                    Date: 2019.12.11
                    Time: 11:22:27
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S1900000
   Coding: 0203010101
   VCID: 6E85CEAF5093A9B72BB-803A
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007485641
   VCID: 3E253EEF40731937FBB-806A
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000184803
   VCID: 313F15D3812DF64F769-8064
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 34311CC7723FC3671DF-8060
   Part No SW: 8T1 035 186 C    HW: 8T1 035 186 C
   Component: Concert3      H02 0210
   Revision: 00000004    Serial number: AUZ5Z6H1097355
   Coding: 04020080010205000159070800
   VCID: 372B2BCB6F49287F38D-8062
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007493288
   Coding: 010C12204000210001
   VCID: 7F5B03EB07F9D03FB0D-802A
   Part No SW: 8K0 907 383 A    HW: 8K0 907 383 A
   Component: Anhaenger     H06 0040
   Revision: 1A002002    Serial number: 00000113071515
   Coding: 0100000000000000
   VCID: 323D1ADF842BCD570F3-8066
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007479851
   VCID: 7EA5FEEF00F3D937BBB-802A
End----------(Elapsed Time: 01:27, VBatt start/end: 14.1V/14.2V)-----------
New battery:
BEM Code:
000915105DH
VAO39060220EQ
And I tried to write coding to 19->Long adaption -> channel 004:
000915105DH VAO 39060220EQ
Try: 000915105DH VA0 39060220EQ
(VA0 instead of VAO)
Dp41n8w
C?ID=372411
I tried VAO and VA0. Always same result after I press TEST - old coding comes back.
What happens if you just change one digit of the existing coding's serial number?
For example, change:
8K0915105D MLA 180722MRY1 to
8K0915105D MLA 180722MRY2
Dp41n8w
C?ID=372411
Nothing change. Always after pressed TEST - Old coding is there. 😮
Dp41n8w
C?ID=372411
There was that 8k0 coding and bosh battery 85Ah. No fault codes to battery. But car went after battery replace to dealer for service and they said that batterytest gived "bad battery" and need to replace and recode.
Next thing I would try is setting some values for WSC, Importer, and Equipment Number.
Go to [Options], click on the User Interface and Identification tab. Your screen will look like this:
Put non-zero numbers in there.
For WSC, I suggest the a '0' followed by the last four digits of your postal code or phone number.
For Importer, use your country's importer code (or pick a 3-digit number at random).
For Equipment Number, I suggest a '0' followed by the last for digits of your interface serial number.
Using this method ensures enough randomness that it can't possibly be blocked.
Then click [Save], and exit and re-start VCDS for these values to take effect.
Dp41n8w
C?ID=372411
Hello. Thanks for advice. I tried and changed all those number and tried but nothing changed. Old coding comes back
Scratching head.
What happens if you click [Save] despite having the old coding in the Test Value field?
Dp41n8w
C?ID=372411
Still old coding stays. But I dont think that it saves the new value. I think the old value Stay there in the field.. 😕
Dp41n8w
C?ID=372411
I tried to do with another tester battery coding and it accepted then I did to Golf Mk7 my 15 battery coding with my vcds, bit different, but it worked.
Dp41n8w
C?ID=372411
Have you Uwe figured it out?
