Hello. I changed battery to audi and the battery needs coding. I have tried code battery, but when I press TEST then there comes old battery coding value back. There is 26 digits but car dont accept new coding? can someone give me advice?
Autoscan:
New battery:
BEM Code:
000915105DH
VAO39060220EQ
And I tried to write coding to 19->Long adaption -> channel 004:
000915105DH VAO 39060220EQ
Wednesday,11,December,2019,15:11:31:19148
VIN: WAUZZZ8K59A085140 License Plate: AUDI
Mileage: 211710km-131550mi Repair Order:
Long Adaptation Channel 004:
Stored value 8K0915105D MLA 180722MRY1
Test value 8K0915105D MLA 180722MRY1
Battery Information/Replacement
N/A
N/A
N/A
N/A
Wednesday,11,December,2019,15:17:52:19148
VIN: WAUZZZ8K59A085140 License Plate: GML-530
Mileage: 211710km-131550mi Repair Order: AUDIA4B8
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 69 72
VIN: WAUZZZ8K59A085140 Mileage: 211710km-131550miles
Address 01: Engine (-----CDNC) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 A HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H12 0002
Revision: E1H12---
Coding: 010C000C180F0920
Shop #: WSC 40350 222 93973
ASAM Dataset: EV_ECM20TFS8K2907115A A01003
ROD: EV_ECM20TFS8K2907115A.rod
VCID: 2D0709A39D9592AF521-8078
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Coding: 07C500
Shop #: WSC 06335 000 00000
VCID: 7BA3F7FB13E1CC1F9C5-802E
Part No SW: 8K0 907 064 AD HW: 8K0 907 064 AD
Component: BCM2 1.1 H71 0134
Coding: 070200
VCID: 72BDDADF44AB8D57CF3-8026
Subsystem 1 - Part No SW: 8K0 959 754 D HW: 8K0 959 754 D
Serial number: 0816000082984019
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Serial number: 0208000036243002
03286 - Sensor for Contact with Door Handle; Front Right
Fault Status: 00100111
Reset counter: 57
Mileage: 211717 km
Date: 2019.12.11
Time: 10:18:07
03285 - Sensor for Contact with Door Handle; Front Left
Reset counter: 17
Mileage: 211717 km
Date: 2019.12.11
Time: 11:05:50
Reset counter: 17
Mileage: 211717 km
Date: 2019.12.11
Time: 11:05:50
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0125.07.080210
Coding: 64000000
VCID: 70B9D0D74AA7BF47397-8024
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000187436
Coding: 2600D0914034AF010001000300001D0D0F1C270800010101000000
VCID: 303910D78A27FF47797-8064
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 190708 H06 0070
Serial number: SWFBIE 0006256
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10196430
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000002607080796
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD17TWM5
Coding: 30343434363030303030554A304C384B3053
VCID: 3C2134E756EF0B27D5F-8068
Serial number: 6334MSME3E15624EM
Serial number: 6344MSME526D5824J
Serial number: 6352QSME7E612123D
Serial number: 6362QSME750B3231A
Serial number: 63732SME6A492D4BF
Serial number: 63832SME20522060H
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HGM000C0
Coding: 000017
VCID: 3D2739E34D75022FE21-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 930 A HW: 8K0 920 930 A
Component: KOMBIINSTR. H16 0224
Revision: 00000000 Serial number: 9DZ195W78
Coding: 0F04110002000008010000
VCID: 2B0307BBA3019C9F4C5-807E
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0871482C2
Coding: 000303
VCID: 46D5560F18A341F7B3B-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 180316C1110708
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H06 0210
Revision: 00000000
Coding: 020202
VCID: 78A9E8F722D7E707F17-802C
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007498221
Coding: 011C12204000410001
VCID: 3FDB43EB4779103FF0D-806A
Revision: 00002001 Serial number: 0113125985
Coding: 013A0E2020390041003002
Shop #: WSC 06325 000 00000
Component: LIN BACKUP HO H03 1301
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 17
Mileage: 211717 km
Date: 2019.12.11
Time: 11:22:18
02616 - Fuel Tank Cap; Unlock
Reset counter: 17
Mileage: 211717 km
Date: 2019.12.11
Time: 11:22:27
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010101
VCID: 6E85CEAF5093A9B72BB-803A
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007485641
VCID: 3E253EEF40731937FBB-806A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000184803
VCID: 313F15D3812DF64F769-8064
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 34311CC7723FC3671DF-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
Component: Concert3 H02 0210
Revision: 00000004 Serial number: AUZ5Z6H1097355
Coding: 04020080010205000159070800
VCID: 372B2BCB6F49287F38D-8062
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007493288
Coding: 010C12204000210001
VCID: 7F5B03EB07F9D03FB0D-802A
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 A HW: 8K0 907 383 A
Component: Anhaenger H06 0040
Revision: 1A002002 Serial number: 00000113071515
Coding: 0100000000000000
VCID: 323D1ADF842BCD570F3-8066
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007479851
VCID: 7EA5FEEF00F3D937BBB-802A
End----------(Elapsed Time: 01:27, VBatt start/end: 14.1V/14.2V)-----------
BEM Code:
000915105DH
VAO39060220EQ
