A3 8P RVC retro problem
Oski
Poland
C?ID=266615
Hi guys, I've just stuck an R8 RVC module on my 8p 04 plate, however I still have a problem. When I put in reverse RNS-E screen flickers and image from RVC comes up for a few seconds, and then RNS-E gets back to function screen. RVC module throws 02283 - Video Connection to Output [End Unit] 011 - Open Circuit fault. Sticking in reverse again won't bring the RVC screen unless I go thought iginition cycle or clear the DTC with VCDS, but again it appears for few sec and comes back to function. Over and over again. I've triple checked the loom, and camera signal cable, all seems to be good (worked flawlessly on my previous 8P). Anyone has an idea where the problem could be? What is indicated as End Unit as per DTC? RNS-E?
South Molton, UK
Please post a FULL UNEDITED Auto-Scan showing the fault code.
Oski
Poland
C?ID=266615
Here's the full scan. A/V fault is due to unplugged camera from the module
Thursday,12,December,2019,12:08:10:60351
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: Dash Solutions
VIN: WAUZZZ8P44A039450   License Plate:
Chassis Type: 8P (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 47 52 56 6C 7D
VIN: WAUZZZ8P44A039450   Mileage: 332560km-206643miles
6C-Back-up Cam. -- Status: Malfunction 1010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 FF    HW: 028 101 136 4
   Component: R4 2,0L EDC G000SG  7364
   Revision: 12345678    Serial number: AUX7Z0C6FN80AP
   Coding: 0000072
   Shop #: WSC 00046 000 00000
   VCID: 6CD7A1BA4F60482F6B-8038
16497 - Intake Air Temp. Sensor (G42)
            P0113 - 000 - Signal too High
                    RPM: 2184 /min
                    Torque: 4.0 Nm
                    Speed: 72.0 km/h
                    Voltage: 13.98 V
                    Temperature: 17.1°C
                    Temperature: 84.6°C
                    Temperature: 84.6°C
   Part No: 1K0 907 379 D
   Coding: 0055942
   Shop #: WSC 06435 000 00000
   VCID: 33657AC652DED7D76A-8066
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0180
   Revision: 000355      Serial number: 8P0820043BM
   VCID: 78FF8DEA0B38F48F9F-802C
00483 - Control Module for Auxiliary Air Heater
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 99
                    Mileage: 332139 km
                    Date: 2019.12.06
                    Time: 13:56:52
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
   Component: Bordnetz-SG     H54 2501
   Revision: 00H54000    Serial number: 00000007412374
   Coding: F5885F06821410001F000000000000000009FE0F5C01022E000000000000
   Shop #: WSC 06314 122 00001
   VCID: 4581341E0C4A5967D4-8010
   Subsystem 1 - Part No: 8P1 955 119   Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0130
   Coding: 15925264
   Shop #: WSC 06314
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0040
   Coding: 00216109
   Shop #: WSC 06314
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5P0 919 475 B    HW: 5P0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 89320931800356
   Coding: 300004
   Shop #: WSC 00046 123 12345
   VCID: 3A7B57E2B5B4269FA9-806E
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
   Component: Airbag 8.4ED    H01 0130
   Coding: 0010602
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0002042
   Shop #: WSC 00046 412 16384
   VCID: 4189200E18627547E8-8014
   Component: E0221           H03 0030
   Part No SW: 8P0 920 932 S    HW: 8P0 920 932 S
   Component: KOMBIINSTR. VDO H03 0380
   Revision: D0H03005    Serial number: 2247L005012630
   Coding: 0260128
   Shop #: WSC 50741 143 61874
   VCID: 4487291A0770606FC3-8010
   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1682
   Revision:   H58       Serial number: 270813F2000634
   Coding: 350100
   Shop #: WSC 61064 064 61064
   VCID: 79F988EEF032ED87E0-802C
                    Fault Status: 00110100
                    Reset counter: 147
                    Mileage: 332507 km
                    Date: 2019.12.10
                    Time: 15:38:07
   Revision: D0H03005    Serial number: AUX7Z0C6FN80AP
   Shop #: WSC 00137 211 56823
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 193 A    HW: 8E0 035 193 A
   Component: RNS-E PU EU     H06 0220
   Revision: 0000011S    Serial number: AUZBZ7KD205532
   Coding: 0225115
   VCID: 23458A86E23E47579A-8076
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 149
                    Mileage: 332496 km
                    Date: 2019.12.10
                    Time: 12:51:04
                    Mileage: 332550 km
                    Count: 1212
                    Clock: 09:05
00856 - Radio Antenna
                    Reset counter: 103
                    Mileage: 332432 km
                    Date: 2019.12.08
                    Time: 15:23:40
                    Mileage: 332430 km
                    Count: 812
                    Clock: 15:23
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 103
                    Mileage: 332432 km
                    Date: 2019.12.08
                    Time: 15:23:37
                    Mileage: 332430 km
                    Count: 812
                    Clock: 15:23
02454 - Microphone Unit (in Front Roof Module) (R164)
                    Fault Frequency: 72
                    Reset counter: 110
                    Mileage: 332432 km
                    Date: 2019.12.08
                    Time: 15:23:21
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H09 0010
   Coding: 0000120
   VCID: 397948EE70B22D87A0-806C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 239    3501
   Revision: 00H17000
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1880222002487F00870FC08A0167
   Shop #: WSC 08224 085 73347
   VCID: 43852A06027E6757FA-8016
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH27 0160
   Revision: 00005       Serial number: 30659630294399
   VCID: 70EFB5CA6348ACCF57-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000120
   VCID: 3A7B57E275B4269FA9-806E
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0225115
02261 - Data Medium
                    Reset counter: 149
                    Mileage: 332496 km
                    Date: 2019.12.10
                    Time: 12:51:04
                    Mileage: 332550 km
                    Count: 1212
                    Clock: 09:05
                    Reset counter: 103
                    Mileage: 332432 km
                    Date: 2019.12.08
                    Time: 15:23:40
                    Mileage: 332430 km
                    Count: 812
                    Clock: 15:23
                    Reset counter: 103
                    Mileage: 332432 km
                    Date: 2019.12.08
                    Time: 15:23:37
                    Mileage: 332430 km
                    Count: 812
                    Clock: 15:23
                    Fault Frequency: 72
                    Reset counter: 110
                    Mileage: 332432 km
                    Date: 2019.12.08
                    Time: 15:23:21
Address 6C: Back-up Cam.        Labels: 420-910-441.clb
   Part No SW: 420 910 441 A    HW: 7L6 907 441 C
   Component: J772__Rearview      0010
   Revision: --H13---    Serial number: 525PA8-JA3600O
   Coding: 1020712
   Shop #: WSC 98765 666 38681
   VCID: 0A1BC72265D4F61FF9-805E
03006 - Back-up Camera System not calibrated
                    Reset counter: 107
                    Reset counter: 107
                    Mileage: 332507 km
                    Date: 2019.12.10
                    Time: 15:24:26
                        Reverse ON
                    Count: 4
02203 - Audio / Video Input 1
                    Reset counter: 107
                    Mileage: 332507 km
                        Reverse ON
                    Count: 9
Address 7D: Aux. Heat
End-------------------------(Elapsed Time: 02:00)--------------------------
Oski
Poland
C?ID=266615
Anyone knows what it stands for? RNS-E? "Video Connection to Output [End Unit]"
m87a
Bosnia and Herzegovina
C?ID=156900
this means that either a cable is broken or pins are wrongly pinned hence open circuit, so check cable behind rns e, sometimes there is a break or bad connection on these cables especially if it's removed and reinstalled.
Oski
Poland
C?ID=266615
Wiring must be good as video comes up for a few seconds, and then switches off and fault comes up
South Molton, UK
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 007 - Short to Ground
Is the RNS-E a retrofit from a Symphony II+?
I wonder if this is the problem?
Reset counter: 107
m87a
C?ID=156900
well either module or wiring from module to rns e is causing problem, just in case check wiring if ok try replacing module?
