cu52
- Dec 10, 2019
- 15
- 4
- USA
- HC473845 (2nd hand?)
Short version 04 allroad 4.2 doing a manual swap: Car has never communicated with ABS since I owned it. No ABS lights, or issues on the cluster. Pulled engine, did timing chain package, reinstalled the engine, still no issues, lights or beeps. Went to scan before pulling engine to look into coding changes for 6 speed swap. Cannot connect to ABS. Look through all previous scans none of them connected to ABS. I swap the module with a known good one (parts car) No connection and now LIGHTS and the three beeps.
I read about the radio possibly being an issue. I remove radio still cannot connect, still 3 beeps. Previous owner modified the factory radio for aux in through CD Changer inputs.
I check the voltage at the ODB2 K line (4 and 7) 10.31 V same at the ABS harness pin 28 Ground and 46 K line
I am also seeing a sporadic connection issue to radio now.
I'd really like to figure this out before I finish the assembly of the swap package and have the same issue but a car ready to drive and program.
Thanks for any thoughts!
Auto scan from Purchase
Auto scan today (Ignore the faults engine / trans are out.
Saturday,13,April,2019,12:20:08:16173
VCDS Version: 18.9.1.0 (x64)
VIN: WA1YL64B34N032078 License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
75 76 77
Address 01: Engine Labels: None
Part No SW: 4D0 907 560 BE HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Coding: 0007755
Shop #: WSC 02334 785 00200
VCID: 6AD07B5E4640C41A63-5120
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
16815 - Warm Up Catalyst; Bank 2
P0431 - 001 - Efficiency Below Threshold
17738 - Knock-Control: Cylinder 6
P1330 - 001 - Regulation Limit Exceeded - Intermittent
17739 - Knock-Control: Cylinder 7
P1331 - 001 - Regulation Limit Exceeded - Intermittent
16395 - Bank 1: Camshaft A (Intake)
P0011 - 008 - Retard Setpoint not Reached (Over-Advanced)
Readiness: 0000 0001
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 S
Component: AG5 01V 4.2l5V USA 1215
Coding: 0001002
VCID: 56A83FAEE23870FAD7-5120
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00110
VCID: 6AD07B5E1640C41A63-2572
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 J
Component: Airbag 8.4EP 3000
Coding: 0000607
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01005
Shop #: WSC 02334
VCID: 2F66AA4AED22613274-5102
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 06283
Shop #: WSC 00222
VCID: 336EA63A010A45D210-5120
WA1YL64B34N032078 AUZ7Z0C2459363
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 02334
VCID: 4894E1D6688CD60A55-5120
01575 - Control Switched Off
35-00 - -
Address 35: Centr. Locks Labels:. 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 22122
VCID: 336EA63A010A45D210-4ECA
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
VCID: 2C5CBD46DC341A2A51-4B00
Address 37: Navigation Labels: 4B0-919-887-BNS4.lbl
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
VCID: 356A98220F7E5BE23E-4ACE
00-00 - -
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
VCID: 040C35E61424326AF9-4B18
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 N
Component: symphony II NP2 0400
Coding: 02017
Shop #: WSC 22016
VCID: 2B5EBE5AD93A1D1258-5072
00857 - CD Changer Unit (R41)
49-00 - No Communications
Address 75: Telematics Labels: 8E0-035-616.lbl
Part No SW: 8E0 035 616 B HW: 8E0 035 616 B
Component: Telematik USA1 1616
Coding: 0002333
Shop #: WSC 22122 444 01310
VCID: 244C5566E4E4D26A99-5120
01528 - Auxiliary Antenna for Telematic (R90)
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 02334
VCID: 020033FE0E303C5ACB-5120
End-------------------------(Elapsed Time: 04:59)--------------------------
Tuesday,10,December,2019,14:45:46:16173
VCDS Version: 19.6.2.0 (x64)
75 76 77
Coding: 0007755
VCID: 6AD07B5E4640C41F19-5120
8 Faults Found:
17951 - Angle Sensor 1 for Throttle Actuator (G187)
P1543 - 002 - Signal too Small
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 002 -
17987 - Throttle Actuator (J338)
P1579 - 001 - Adaptation Not Started
18320 - Pressure Sensor for Brake Boost (G294)
P1912 - 001 - Short to Plus - Intermittent
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
18080 - Coolant Fan Control 1
P1672 - 004 - Open or Short to Ground
18308 - Coolant Fan Control 2
P1900 - 004 - Open or Short to Ground
18010 - Power Supply Terminal 30
Readiness: 0110 1101
Coding: 0001002
VCID: 56A83FAEE23870FFAD-5120
17090 - Transmission Range Sensor (F125)
P0706 - 003 - Implausible Signal
17094 - Transmission Fluid Temp Sensor (G93)
P0710 - 003 - Malfunction
18265 - Load Signal
P1857 - 003 - Error Message from ECU
18155 - Transmission Solenoid Power Relay
P1747 - 003 - Open or Short to Ground
18158 - Supply Voltage
P1750 - 003 - too Low - Intermittent
Coding: 00110
VCID: 6AD07B5E1640C41F19-256C
30-00 - Open or Short to Plus
27-00 - Implausible Signal
Coding: 0000607
Coding: 01005
Shop #: WSC 02334
VCID: 2F66AA4AED2261370E-5120
01304 - Radio
Coding: 06283
Shop #: WSC 00222
VCID: 336EA63A010A45D76A-5120
01304 - Radio
Coding: 25500
Shop #: WSC 02334
VCID: 4894E1D6688CD60F2F-5120
79-00 - Please Check Fault Codes
Coding: 15885
Shop #: WSC 22122
VCID: 336EA63A010A45D76A-4ECA
58-00 - Can't Lock
Coding: 00001
VCID: 2C5CBD46DC341A2F2B-4AE6
VCID: 55AA38A2AC3E7BE7A4-4AB4
Note: Excessive Comm Errors
Coding: 00030
Shop #: WSC 02334
VCID: 040C35E61424326F83-4B18
Coding: 02017
Shop #: WSC 22016
VCID: 2B5EBE5AD93A1D1722-5072
00856 - Radio Antenna
36-00 - Open Circuit
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
37-10 - Faulty - Intermittent
Coding: 0002333
VCID: 244C5566E4E4D26FE3-5120
Coding: 01186
Shop #: WSC 02334
VCID: 020033FE0E303C5FB1-5102
End-------------------------(Elapsed Time: 05:34)--------------------------
