System Too Lean off Idle 2014 allroad 2.0
Aallroad
Hi all
2014 Audi allroad 2.0 60K miles. Borrowed my friends VCDS
Been getting this every so often. used to self clear but now returning.
Trips usually after a mile or so after restart when engine is hot.
2821 - Bank 1; System Too Lean off Idle
P2177 00 [101] - -
Mileage: 97738 km
Date: 2019.11.29
Time: 13:38:25
Engine speed: 1694.00 /min
Normed load value: 17.3 %
Vehicle speed: 68 km/h
Coolant temperature: 96 °C
Intake air temperature: 33 °C
Voltage terminal 30: 14.771 V
Unlearning counter according OBD: 80
Engine status: COENG_RUNNING
Back story abut 9 months ago had this same code and replaced the oil breather assembly which fixed it (along w/ an erratic idle)
Idle is ok now.
Data logged (3 mile drive) Long term adaptation of mixture formation bank 1. Running between 3 and 7% typically 5% Is this bad?
Short term bounces +/- . Air leak somewhere? Smoke test next?
Also seeing cylinder 1 and 3 misfires during warmup / first mile driving (not at start or hot) Replaced coil packs and plugs not change Clys 2 and 4 are quiet.
Aallroad
Friday,29,November,2019,15:33:50:30821
VCDS Version: 19.6.2.0 (x64)
VIN: WA1UFAFL9EA120893   License Plate:
Mileage: 60736 airfil   Repair Order:
                Address 01: Engine       Labels: 06H-907-115-CDN.clb
Control Module Part Number: 8K5 907 115 N    HW: 8K2 907 115 L
  Component and/or Version: 2.0l R4/4V TF H09 0005
           Software Coding: 722A0013242600062000
            Work Shop Code: WSC 09153 003 1048576
              ASAM Dataset: EV_ECM20TFS0118K5907115N 001006 (AU48)
                       ROD: EV_ECM20TFS0118K5907115N.rod
                      VCID: 3D7BC726AC09CBA78C-8068
          P2177 00 [101] - -
                    Mileage: 97738 km
                    Date: 2019.11.29
                    Time: 13:38:25
Readiness: 0000 0001
South Molton, UK
That's still not a FULL UNEDITED Auto-Scan ... :popcorn:
