RS4 B8 automatic parking brake activation
adamrj
C?ID=214457
Is it possible to activate the parking brake automatically when turning off the ignition on an RS4 without hill hold? Doesn't seem like a big ask!
South Molton, UK
You'll need to post an Auto-Scan for someone to be able to answer that - it all depends IF VAG have included the feature in their firmware...
adamrj
C?ID=214457
Thanks for the response, please see scan below:
Tuesday,03,December,2019,20:15:32:31354
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WUAZZZ8K6EA900767   License Plate: RS4
Mileage: 91940km-57128mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 30 36 42 44 46 47 52 53
          56 5C 5F 62 6C 6D 72
VIN: WUAZZZ8K6EA900767   Mileage: 91940km-57128miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 E    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0003
   Revision: NAH04---
   Coding: 1225003225C6000A3000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560E 001002
   ROD: EV_ECM42FSI0118T2907560E.rod
   VCID: 3E30C158A10DCFBFAB-806A
7036 - Thermostat for Mapped Engine Cooling (F265)
          P0597 00 [047] - Open Circuit
                    Mileage: 71706 km
                    Date: 2018.03.20
                    Time: 18:11:07
                    Engine speed: 741.50 /min
                    Normed load value: 18.4 %
                    Coolant temperature: 63 °C
                    Intake air temperature: 20 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 14.371 V
                    Engine status-Bits 0-7: 3
                    Engine oil temperature: 43.0 °C
                    Engine operating condition: Idling
                    Driver-side belt buckle status-Bits 0-7: 166
                    Current system status: SYC_DRIVE
                    Current system status-Test_Program_Exe Con State 02 UBYTE: 4
   Part No SW: 8T0 927 156 J    HW: 0B5 927 156 K
   Component: 0B5 42 FSIRdW H02 0002
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 44C4B3B0CFE1A56FFD-8010
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 341D4A
   VCID: 45C2AEB4CCDB9C67EA-8010
                    Fault Status: 00101101
                    Reset counter: 201
                    Mileage: 91575 km
                    Date: 2019.12.02
                    Time: 15:17:55
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001C
                    Hex Value: 0x0295
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 HH    HW: 8K0 907 064 GH
   Component: BCM2 2.0      H13 0641
   Coding: 05924040000000000000
   VCID: 7DB20654E48B14A7F2-8028
   Serial number: 0213000326398014
00956 - Key 2
                    Reset counter: 200
                    Mileage: 85271 km
                    Date: 2019.06.11
                    Time: 13:32:37
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01250920131496
   Coding: 4804000000
   VCID: 3A38CD48B525E39F97-806E
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000678362401
   Coding: 0600001000349FE2258140C3000019090F9DC70A23090201000008004400010200020034000000
   VCID: 7AB80D48F5A5239FD7-802E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 230913  H06 0080
   Serial number: SWF13090235208
   Coding: 00FD11
   Serial number: 21796907
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000909130659
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 4C388EC6000000000001
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H11 0100
   Coding: 003352
   VCID: 3228E5686D551BDF5F-8066
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KFDB23GEB
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 39809 001 1048576
   VCID: 48DCA780F3C9810F11-801C
   Serial number: 6334MSME7F054843J
   Serial number: 6344MSME7F310808G
   Serial number: 6352QSME48390E56Q
   Serial number: 6362QSME30353F5CO
   Serial number: 63732SME3136524AX
   Serial number: 63832SME3B3957522
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MIP0007T
   Coding: 0000FF
   VCID: 44C4B3B0C7E1A56FFD-8010
   Part No SW: 8K0 920 983 D    HW: 8K0 920 983 D
   Component: KOMBIINSTR.   H35 0563
   Revision: 00400000    Serial number: WWT60YH9E
   Coding: 33EF1100CF012600010000
   VCID: 3620D978813D07FF73-8062
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z139190DEB
   Coding: 80E3031600
   VCID: 4CD49B90EFB16D2F35-8018
   Serial number: 2707991303
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 200
                    Mileage: 91554 km
                    Date: 2019.11.29
                    Time: 11:47:26
                    Bin. Bits:    10000
                    Voltage: 11.60 V
                    Count: 11
                    Bin. Bits:    00000
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 001809130001376
   VCID: 2F2EEC1C7667363730-807A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000087724
   Coding: 01010101000000000001000102
   VCID: 2D12F614746B442702-8078
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000073704301
   Coding: 00781B00000000000000
   VCID: 3B36C84CBA1FDA978C-806E
03325 - Switch for Backrest Angle Adjustment: Back
                    Fault Status: 00100011
                    Reset counter: 200
                    Mileage: 91554 km
                    Date: 2019.12.02
                    Time: 09:46:12
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C12205E21410001
   VCID: 56E079F8217D27FF93-8002
02117 - Motor for Mirror Folding
                    Reset counter: 200
                    Mileage: 91554 km
                    Date: 2019.11.29
                    Time: 12:07:44
                    Fault Status: 00101100
                    Reset counter: 200
                    Mileage: 91554 km
                    Date: 2019.11.29
                    Time: 12:51:30
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0022885745
   Coding: 100001010001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3424E3709F4115EF4D-8060
   Revision: 00002001    Serial number: 0312381243
   Coding: 013B0E22A0B938958030023280000000
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
03128 - Switch 1 for Sunroof
                    Fault Frequency: 68
                    Reset counter: 173
                    Mileage: 89973 km
                    Date: 2019.09.18
                    Time: 08:45:10
01514 - Regulator for Roof
                    Fault Frequency: 61
                    Reset counter: 173
                    Mileage: 89973 km
                    Date: 2019.09.18
                    Time: 08:45:10
   Revision: 00005001    Serial number: 94813020611003
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55E27EF43C7B2CE79A-8000
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 20000000339697
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 393AD244B823E8879E-806C
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109J/0D7710358
   Coding: 010103010000000001
   VCID: 26000938519D777FC3-8072
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600213A02000D2
   Coding: 0022201
   VCID: 373ED47C4637FEF768-8062
   Part No SW: 8R2 035 670 F    HW: 8R2 035 670 C
   Component: H-BNT-EU      H46 0739
   Revision: --------    Serial number: 208J 0D7510736
   Coding: 120101010306A9EF6D80CB5E00000403040000000000000000
   VCID: 373ED47C8637FEF768-8062
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Component: DU7 High  H42 0104
   Serial number: A130IW0D2835741
   Subsystem 3 - Part No SW: 8T0 919 611 N    HW: 8T0 919 611 J
   Serial number: 00000001625868
   Component: CD-Database  5298
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 200
                    Mileage: 91554 km
                    Date: 2019.11.29
                    Time: 11:45:54
                    Voltage: 11.60 V
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C12204021210001
   VCID: 59FA72C450630887BE-800C
   Revision: --H08---    Serial number: 525PA8-J3792Z0
   Coding: 1020007
   VCID: 383CD7404B29F18F61-806C
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C34CB50BF11DDAF85-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
   Component: TSG HR        H07 0305
End----------(Elapsed Time: 02:11, VBatt start/end: 12.0V/12.1V)-----------
When turning off the ignition -- I don't see how.
But when putting the transmission in park, perhaps:
IDE07959 -- Automatic parking brake for selector lever position (not activated / activated)
