Detlef Trapp
This is the same car I had trouble with VCDS mobile, so now tried VCDS 19.6.2 but the 'Clear all DTCs' button did not work even though I tried several times, also tried running several complete Auto-Scans, also tried ignition off, but no success.
Ended up clearing the DTCs individually in each controller :-(
Monday,09,December,2019,17:28:34:10727
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4513.4
VIN: WVWZZZ3CZDExxxxxx License Plate:
Mileage: 210920km-131059mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 25 2E 37 42 44 46 4C 4F
52 53 56 61 62 6C 72
VIN: WVWZZZ3CZDExxxxxx Mileage: 210920km-131059miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PA HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9978
Revision: 41H28--- Serial number: 00000000000000
Coding: 001D0032046401080000
Shop #: WSC 35475 184 00000
ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
ROD: EV_ECM20TDI01103L906018PA.rod
VCID: 78BC28FBC3FAAC8F9F-802C
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
5286 - Throttle Position Sensor (G69)
P0121 00 [104] - Implausible Signal
Fault Frequency: 60
Mileage: 206029 km
Date: 2019.09.24
Time: 09:02:15
Engine speed: 118.50 /min
Normed load value: 100.0 %
Coolant temperature: 86 °C
Intake air temperature: 38 °C
Voltage terminal 30: 12.680 V
Air mass: actual value (mg/stroke): 448.7 mg/stroke
Throttle valve adapter: specified value: 0.00 %
Throttle valve adapter: actual value: 1.12 %
Throttle valve adapter: offset closed: -11.95 %
Throttle valve adapter: status-Bits 0-7: 0
Throttle valve adapter: status-Bits 0-7: 8
Throttle valve adapter: status-Bits 0-7: 55
Throttle valve adapter: status-Bits 0-7: 14
Throttle valve adapter: uncond voltage actual value: 977.4 mV
Readiness: 0 1 0 0 0
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3509
Revision: 05551213 Serial number: 00001205101083
Shop #: WSC 05311 000 00000
VCID: 24042C8BE7F2186FE3-8070
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BL HW: 3AA 614 109 BL
Component: J104 C2 450M VE2A 0024
Revision: --H07--- Serial number: 00000005776183
Coding: 0122291
VCID: 78BC28FB0BFAAC8F9F-802C
02214 - Tire Pressure Warning
Reset counter: 80
Mileage: 207768 km
Date: 2014.03.16
Time: 18:16:15
Speed: 61.0 km/h
Hex Value: 0x0001
Bin. Bits: 00000000 00000000
Voltage: 13.25 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Part No SW: 3AA 907 044 AK HW: 3AA 907 044 AK
Component: Climatronic H03 0202
Revision: 00001K01
Coding: 0011004803
Shop #: WSC 00015 115 00000
VCID: 79BA2DFFF8F0B587E0-802C
9474417 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Reset counter: 75
Mileage: 209860 km
Date: 2019.11.16
Time: 17:26:54
9481988 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Fault Frequency: 119
Reset counter: 42
Mileage: 204858 km
Date: 2019.09.10
Time: 20:01:22
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 G HW: 3AA 937 087 G
Component: BCM PQ47 H 421 0464
Revision: BB421001
Coding: 0008000000000000009C00885400816403510088466D87606480C7200041
VCID: 3E30FEE3A95E52BF95-806A
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 25041 10 0603
Coding: 00B795
Component: RLS 230512 05 54 0403
Coding: 024D2A
03789 - Terminal 75 Limp Mode Active
Reset counter: 59
Mileage: 208757 km
Date: 2014.03.25
Time: 10:34:03
Voltage: 12.65 V
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261212900439
Coding: 348306
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 44C48C0BCFB2386FC3-8010
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000548512
Coding: 0010000
VCID: 383CE8FB4B7A6C8F5F-806C
Fault Frequency: 22
Reset counter: 81
Mileage: 206211 km
Date: 2014.02.20
Time: 08:20:57
Count: 92
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__107 VW10 HI 2118
Revision: 24017000 Serial number: 003L7PAQC3L%
Coding: 0012343
VCID: 7CB434EB3FC280AFFB-8028
Subsystem 1 - Serial number: 6332MTS639271282
Subsystem 2 - Serial number: 6342MTS656441282
Subsystem 3 - Serial number: 6351HTS6RL0N4BKJ
Subsystem 4 - Serial number: 6361HTS6CABM3BKJ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120530201964
Coding: 399AA50001
VCID: 75A221CFD4E8D1E784-8020
Component: E221__MFL-TK6 H07 0022
Coding: E30000
Part No SW: 3AA 920 870 J HW: 3AA 920 870 J
Component: KOMBI H05 0705
Coding: 161F01
Shop #: WSC 05314 115 00000
VCID: 393AEDFFB8707587A0-806C
Part No SW: 7N0 907 530 AA HW: 7N0 907 530 G
Component: J533 Gateway H41 1632
Revision: H41 Serial number: 210512F1001621
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: 6FAE13A7BEB4EB374E-803A
Part No SW: 5K0 857 511 C HW: 8P0 857 511 C
Component: FLA H04 0006
Revision: AA001002
Coding: 01018E67727261565623393E01
VCID: 2E10CEA3793EA23F05-807A
Part No SW: 3AA 959 799 A HW: 3AA 959 799 A
Component: IMMO 083 0402
Revision: 00083000 Serial number: VWZCZ000000000
Shop #: WSC 49646 001 1048576
VCID: 46C09603318E0A7FDD-8012
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662676166
Coding: 020100
VCID: 2A18C2B345D6CE1FD9-807E
Part No SW: 3C0 035 279 N HW: 3C0 035 279 N
Component: RNS315-EU H52 0319
Serial number: VWZAZ2M5913900
Coding: 040004110400110000011301
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E10CEA3713EA23F05-807A
Component: EUR_W_0038 0038
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0005057512
Coding: 0210B7
Shop #: WSC 05311 115 00000
VCID: 3522E1CF946891E744-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000002939625
Coding: 010090
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Reset counter: 72
Mileage: 207552 km
Date: 2019.10.21
Time: 18:49:43
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
Component: J500__APA-BS KL.310 1101
Revision: 1AH03735 Serial number: 00121390064901
Coding: 0000258
VCID: 3D32F9EF645849A78C-8068
Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
Component: 02 KESSY PQ47 083 0346
Coding: 0191020052C30E76340494157E004FCE705801030434B8
Component: Neigungssensor 004 0611
Subsystem 4 - Component: ViP n.mounted
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Fault Status: 01100111
Reset counter: 245
Mileage: 201524 km
Date: 2013.11.09
Time: 16:16:38
Part No SW: 7N0 907 532 HW: 7N0 907 530 G
Component: EZE_2 H41 1632
Coding: 00000008
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0005064612
Coding: 0210B6
VCID: 3620E6C3896E9AFF4D-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000002944470
Coding: 010090
Fault Frequency: 17
Reset counter: 79
Mileage: 204631 km
Date: 2019.09.05
Time: 08:17:17
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000238755
Coding: 0022167
VCID: 3620E6C3416E9AFF4D-8062
Part No SW: 7N0 907 534 HW: 7N0 907 530 G
Component: Batt.regelung H41 1632
Coding: 030F1859
VCID: 71AA15DFA880FDC758-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900464600
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J242575
Coding: 0020007
VCID: 689C78BB5B5A3C0F0F-803C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 162
Mileage: 201524 km
Reverse OFF
Count: 3
End----(Elapsed Time: 01:40, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
