Headlight Range (J431), Can someone decipher these codes for me?
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Hi I got these codes which won't go away and the adaptive light in the dashboard is always on.
The two codes relating to this headlight range fall under 2 addresses:
1. Address 09: Cent. Elect. (J519)
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 33
Mileage: 167382 km
Date: 2019.11.29
Time: 17:28:00
2. Address 55: Headlight Range (J431)
0061 - Function Restriction due to Implausible Message(s)
U1112 00 [137] - -
[Fehlerhafter DLC der CAN-Messages Kamera_Status (0x318)]
Reset counter: 33
Mileage: 167382 km
Date: 2019.11.29
Time: 17:28:52
Can someone tell me what is these codes are trying to say. It hard for me since no faulty parts is mentioned. Most of the 01771 codes I've read will show some faulty parts (like the level sender) to be replaced. This adaptive light in the instrument cluster has been an eye sore for months. Your help is appreciated. The full scan is below.
Friday,29,November,2019,17:32:50:34670
VIN: WAUZZZ4G9BN031X10   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
          56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031X10   Mileage: 167382km-104006miles
Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551     HW: 4H0 907 551
   Component: 3.0l V6 TFSI  H05 0007
   Revision: --H05---
   Coding: 0A250034052701020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551 002010
   ROD: EV_ECM30TFS0214G0907551_002.rod
   VCID: 6695B5FFE8EFBBD753B-8032
Readiness: 0110 0001
   Part No SW: 4G0 927 156 M    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0024
   Revision: --H10---    Serial number: 0000000785
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 363525BFF8CF0B5723B-8062
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 44A687002265E100DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6E85CDDFC01F73972BB-803A
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Coding: 05B82F00000000000000
   VCID: 77ABE8BBBFC5325FF8D-8022
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000097450009
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 06051100040574
   Coding: 6621007824
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 270BF8FB2F6562DFA8D-8072
0379 - Supply Voltage Terminal 30 for Coolant Pump
          B11D5 01 [009] - Electrical Failure
                    Reset counter: 33
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:49
                    Voltage terminal 30: 12.45 V
                    Outside air temperature: 32.5 °C
                    Interior temperature: 35.37 °C
   Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0092
   Revision: 20012002    Serial number: 00000001044197
   Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
   VCID: 33331CABEB3D1E7F045-8066
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 110404  H35 0051
   Serial number:         110407090850
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11418017
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 04 2011  00000235
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 5228C6A5000000000001
                    Reset counter: 33
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:00
   Part No SW: 4H0 919 475 J    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0032
   Revision: 11001001    Serial number: 55901107004778
   Coding: 300306
   Shop #: WSC 00097 210 98728
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 392F2E83C9D1E42FCE9-806C
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG002BRPH
   Coding: 30323436313330303631554A305234473053
   Serial number: 3575HRB404T0HM766GDR
   Serial number: 3585HRB405H0H0LUC8R2
   Serial number: 3515JRB405D0H4DU9P4N
   Serial number: 3525JRB405F0G944N0G$
   Serial number: 3554VRB40630GR36HOS5
   Serial number: 3564VRB405D0GR36IHD.
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20110505000939
   Coding: 000034
   VCID: 303913A71A2B2567797-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H07 0009
   Part No SW: 4G8 920 981 A    HW: 4G8 920 981 A
   Component: TBenGb        H34 0312
   Revision: 19100074    Serial number: 658020411593026
   Coding: 33A709000B012600010000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 313F16A311A12C6F769-8064
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000141378
   Coding: 00CD073000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 303913A71AAB2567797-8064
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650387009
   Voltage stabilizer:
   Serial number: 11130001538021200181
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 06051100040012
   Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 2F3B10DB07953A9F60D-807A
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006129999
   Coding: 00781B0000006001000001010101102030303232203232
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200UA850
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D070AD30D99488F521-8078
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011F16205E01628002080002
   Shop #: WSC 02312 785 00200
   VCID: 40D94367AA8BB5E7897-8014
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0010073316
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D19AF14A717770F3-8066
   Revision: 00002001    Serial number: 0149428872
   Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 33
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:50
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: 3FDB409BD775CA1FF0D-806A
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000070722
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D01CF3C775FB7B73-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110502-0004-033
   Coding: 1121A633F918EB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H02 0008
   Coding: 1D0000
H02 0008
   Coding: 1D0000
          U1112 00 [137] - -
                    Reset counter: 33
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:52
   Part No SW: 4G0 035 056 A    HW: 4G0 035 056
   Component: Radio U STD   H52 0050
   Revision: AB001007    Serial number: 051EY0B7516476
   Coding: 010003020100000001
   VCID: 1F1BE01B77B5AA1FD0D-804A
   Part No SW: 4G0 035 670 B    HW: 4G0 035 670
   Component: H-BNT-EU      H46 0239
   Revision: --------    Serial number: 428EX0B7514227
   Coding: 050101000003E1EF45108B3E000000030000010000000000
   VCID: 221DE9EF44C787F7FF3-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300QPJ1
   Subsystem 3 - Part No SW: 4G2 919 612 L    HW: 4G2 919 612 L
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KDT0007U
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F14204001628002080002
   VCID: 42DD496FA487A7F79F3-8016
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J14F0S1
   Coding: 1020004
   VCID: 2517F2F359E970CF9A1-8070
   Component: TSG HR        H03 0210
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F315E9B0CF5A1-8030
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBBD0DBC7157A9F20D-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B9D3A7DA2B6567397-8024
End----------(Elapsed Time: 02:06, VBatt start/end: 12.5V/12.5V)-----------
Thank you.
A6 C7 4G 3.0 TFSI
The 55- Headlight Range module is unhappy about something with 85 - On Board Cam. (J852), but it is not clear what.
^^^^ coconutaudi: Hi. If I might add to Uwe's observation - perhaps look at the records in CodingLog.CSV and AdpLog.CSV files in the C:\Ross-Tech\VCDS\Debug directory on the laptop that you use for VCDS for any changes that were made to the car on 29th November 2019 @ about 5:30 PM.
coconutaudi
C?ID=345326
Uwe, up until now, I don't even realize that I have an onboard camera in my car, especially since I don't have this lane departure warning system or any system that uses an onboard camera. Not to my limited knowledge at least. So it is baffling as to how these two J431 and J852 are related. Maybe we can explore further from this info.
Nevertheless thank you for the info.
coconutaudi
C?ID=345326
Hi Don, no changes was made on the 29th Nov @ 5.30pm. The only change I've made was on 27th Nov when I changed the battery serial number because I've replaced the battery. And this headlight range problem has been bugging me for months.
Gremling
Norway, Nordland
C?ID=319714
Hi, In your service folder, first page(s), in the rows with many 3 letter/numbers, does one combo say 8Q3?
I think the cam is used by the Auto dimming/full light function (AFS).
Have you checked wiring to level sensors on drivetrain pressune left side front and rear? Also check fuse 8 in fuseholder C, this is J745 control module for corn light and headlight range control. Which also has CAN hi&lo
Regards
Gremling
coconutaudi
C?ID=345326
Regards
Gremling
Hi Gremling,
I've checked and my options didn't include 8Q3. I found the list in the spare tire compartment. But I noticed my car has AFS13 stated in address 55 along with EV_AdvanFrontSyste, if indeed they are the same thing as the AFS you've mentioned. As suggested I will check fuse 8 in fuseholder C along with the fuse for the onboard camera (fuse 11 on fuseholder B) as there might be problem as pointed out by Uwe. As for the level sensors, I will check them too once I can get the car lifted.
Thank you for the suggestions. I will update you guys.
Thank you.
coconutaudi
C?ID=345326
So I've checked the followings
1. the fuse for the headlight range control J431 and it is good (fuse 8 in fuseholder C passenger side)
2. the fuse for the onboard camera which is also ok (fuse 11 on fuseholder B driver side)
3. the front left level sender (G78). No corrosion, wires are intact, no water ingress
4. the rear left level sender (G76). No corrosion, wires are intact, no water ingress
Those are the things which I have ruled out as being the source of the problem.
What is the next step? I'm thinking of replacing the headlight range control unit J431 next. My questions are:
1. Can I just swap the new J431 with the old one (part no 4H4 907 357 A)?
2. Do I need to code the new J431 unit and how do I go about it using the VCDS.
3. I've noticed that under address 55 there is Coding: 1121A633F918EB00. Is this the code we need to enter to the new unit?
Thanks a lot in advance.
Regards
coconutaudi
C?ID=345326
Some more clues (maybe):
1. Just out of curiosity, I've tried to implement the Headlight Adjustment under Diagnostic Procedure with VCDS (wiki.ross-tech) to see what is the outcome.
I managed to follow the instructions (Actually I did not make any adjustment to the headlight position using the screw driver. I just clicked Stop after a minute) up until the Acknowledge Basis Setting. Here, when I clicked Go! instead of displaying running or learned, the phrase "Not Running" appeared. I've pressed Stop and cleared the fault codes. The fault codes immediately came back. Maybe this would give a clue to the problem.
2. In the fault code under address 55, it is stated "0061 - Function Restriction due to Implausible Message(s)
U1112 00 [137] -Fehlerhafter DLC der CAN-Messages Kamera_Status". According to Google the German phrase "Fehlerhafter DLC der CAN-Messages Kamera_Status" translates to "Faulty DLC of the CAN messages Camera_Status" . DLC means Data Link Connector. So the fault code should read "Faulty Data Link Connector of the CAN messages Camera_Status" which caused the Implausible Message, I think. Any idea what it is?
3. After starting the car, the "Audi adaptive light : system fault" will appear in the instrument cluster immediately after the headlights had done it swivel down and up routine. By the way is there any left and right movement during the headlight routine I've mentioned?
Thank you.
I'm not sure "DLC" in that context means what we commonly take it to mean.
coconutaudi
C?ID=345326
I was thinking CAN in the message should refer to Controller Area Network and therefore DLC should be interpreted Data Link Connector. Like you said it may not refer to the same thing.
BTW, I've tried the Output Test in the 55 Headlight Range address, I ran the Selective Output Test (UDS protocol) on all available output (swivel up down, left right etc) and they all work fine. In the Measuring Value function I got these values:
a) Right Dynamic AFS light motor status -- no error
b) Left Dynamic AFS light motor status -- no error
c) Adjusting motor for variable left front lighting -- Fault position 2 started
d)Adjusting motor for variable right front lighting -- Fault position 2 started
Are c) and d) considered problems?
Thank you.
myounus
Northwest UK
C?ID=321059
Hi
This could be down to a couple of things.
1. a coding issue with the front camera. Does this car have high beam assist? Have there been any attempts to code additional functionality/ tweaks?
2. It may require a software update or the gateway may. These cannot be done with VCDS.
coconutaudi
C?ID=345326
Hi
Hi,
I don’t know whether I can get a software upgrade since my car is an imported used from England. The audi dealership here only entertain vehicles bought from them. I did not do any tweaking apart from the usual needle sweep and I think since the headlight has AFS, it should have high beam assist.
I’ve read somewhere that an A8 with this problem had no choice but to disable the feature just to get rid of the annoying MIL in the cluster. Can it be done to an a6 c7? This should be my last resort.
myounus
Northwest UK
C?ID=321059
VW around the world can update any car from anywhere. Is everything on the car stock? Has it been remapped at all? Has it had an accident?
coconutaudi
C?ID=345326
I personally have never changed or mapped anything, but like I’ve said the car was imported used after being reconditioned in England. Somebody may or may not have done something there, I donÂ’t know. But I don’t think the car was involved in any accident.
Since you have mentioned it, how do I get my car’s software upgraded if the authorized audi dealers in Malaysia refused to do so? The car was imported by an independent car dealer and not by an authorized audi dealership.
myounus
Northwest UK
C?ID=321059
You only need to update the software on a module if there are issues. It is not advised to update every module as this can sometimes cause a module to be bricked. If this is for example the gearbox, it could be a costly update. Hence you only update software if necessary.
VW produce TPI's (technical produce information) publications to dealers, you can download these from erwin (search for a link on this forum). There are several tools to update software on a module but the easiest way for you would be to find a dealer. If they refuse then we can advise on alternative options.
coconutaudi
C?ID=345326
Thank you myounus, I will try my luck with the audi dealers around my area. BTW which module should I upgrade, the headlight range or the onboard camera?
coconutaudi
C?ID=345326
I found this CAN bus diagram which shows J431 and J852 next to each other. Not sure what to make out of it. Is J852 is the control module at fault? Loose connectors or wires, that J431 cannot understand? I've noticed that the J852 unit is on the windscreen.
