Audi A3 E-tron 2016 crash shut-down active
torehobb
Norway
C?ID=337383
Hello
I have 2016 A3 E-tron involved in a car crash. As a result of this the hybridbattery got an error "26623 crash shut-down active"
I have tryed to reset this error to be abel to move the car.I have tried to log into Hybrid battery and use securety axsess code 20103. The modul acept this .
I went into basic settings and trye to perform "IDE 06504 Reset of reversible crash shut-of" but the result is: "ERROR: conditions not correct or request sequence error"
Anyone have some idea how to do this??
Tore
 Sunday,08,December,2019,10:49:21:18625
Workshop Code: 000 00000 008060
VIN: WAUZZZ8V5GA174455   License Plate: KJ24273
Mileage: 55803km-34674mi   Repair Order: etter rep bak
Chassis Type: 8V-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 23 2B 42 44 51 52 55 5F
          75 8C BB BC C6
VIN: WAUZZZ8V5GA174455   Mileage: 55803km-34674miles
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AF    HW: 04E 907 309 F
   Component: 1.4l TFSI hy  H22 2660
   Revision: X3H22---
   Coding: 021D0012632401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906023AF 005006
   ROD: EV_ECM14TFS_005.rod
   VCID: 649150103EDF33374DF-8030
4527 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:04:12
                    Engine speed: 0.00 /min
                    Coolant temperature: -2 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 10.820 V
                    Outside air temperature: -2 °C
                    Absolute intake pressure: 100 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 27.00 l
                    E-machine torque actual value: 0.0 Nm
                    Operating mode control expanded electrical driving: Correct result
                    Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 1
                    High-volt. battery: charge state: abs. value: 48.09 %
17161 - Databus
          U1123 00 [038] - Received Error Message
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:07:12
                    Voltage terminal 30: 11.460 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
Readiness: 1110 0001
   Part No SW: 0DD 300 045 K    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1121
   Revision: 00031033    Serial number: TFK01603180017
   Shop #: WSC 12344 003 1048576
   ROD: EV_TCMDQ400021_VW41.rod
   VCID: 2F3BEF3C2799C06F60D-807A
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
   Component: ESC           H31 0809
   Revision: 00000000    Serial number: 61296000000363
   Coding: 12F140A238273270017B060541C82948021C4C80608294F402A100788608
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001_AU37.rod
   VCID: 05576D94D5A5AA3FFA1-8050
   Revision: 00021000    Serial number: 0404588406
   Coding: 030C0C
   VCID: 3A2DCE68ECDB15C7C73-806E
   Part No SW: 8V0 820 043 G    HW: 8V0 820 043 G
   Component: AC Automat    H06 0040
   Revision: 20011000    Serial number: 00000000917285
   Coding: 0300000000000000000000000000100001000000
   ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
   ROD: EV_AirCondiFrontRDWAU37X.rod
   VCID: 3635DA58D8C3F1A723B-8062
   Subsystem 1 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number: LM161353003807000273
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 3A594228000000000001
   Air Conditioning Compressor Sub:
   Subsystem 3 - Part No SW: 12E 820 803 E    HW: 12E 820 803 E
   Component: J842 eKK  H02 0005
459030 - Implausible Data Received From Electric A/C Compressor
          U046C 00 [047] - -
          [EKK - unplausibles Signal]
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:04:15
                    Unlearning counter according OBD-OBD Parameter: 40
                    Compressor shut-off requirement: Compressor activation: malfunction in activation path
                    Compressor status: global-A/C compressor release status: transmitted
                    Compressor status: global-A/C compressor: target speed: 0 /min
                    Compressor status: global-A/C compressor: actual speed: Measured value not available
                    Compressor status: global-A/C compressor: function status: Air conditioner compressor off
                    Compressor status: global-A/C compressor error indicator: not active
                    Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
                    Compressor status: global-A/C compressor: inverter temperature: Measured value not available
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061614403934
   Coding: 04051B46C25122F5438C5004001C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04517090DE9F9337EDF-8050
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160428  043 0580
   Serial number:         160511072159
   Coding: 0A47F7
   Serial number: 61865063
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 19 01 2016  00002118
7 Faults Found:
10506 - Bulb for Left Tail Light
          B12BE 15 [009] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:06:49
10762 - Bulb for Right Tail Light
          B12BF 15 [009] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:06:48
11018 - Bulb for Left Brake Light
          B12C2 15 [009] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:07:09
11530 - Bulb for Right Brake Light
          B12C3 15 [009] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:07:08
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:06:49
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:06:48
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:23:06
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39231614603376
   Coding: 0000040011
   VCID: 3C21C870E6EF2BF7D5F-8068
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [008] - Open Circuit
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.23
                    Time: 13:24:28
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 82
                    Mileage: 55803 km
                    Date: 2019.10.21
                    Time: 19:38:33
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR0265C6
   Coding: 98CCC0000C2000009C5400CA004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 50F98CC05A67BF97197-8004
   Subsystem 1 - Part No SW: -----------    HW: 480 002 705 16
   Serial number: 3570000000045D7CBB1-
   Subsystem 2 - Part No SW: -----------    HW: 480 002 705 16
   Serial number: 3580000000023D7CBB1X
   Subsystem 3 - Part No SW: -----------    HW: 480 402 405 16
   Serial number: 3510002A52057292C25T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 405 16
   Serial number: 3520002A5205729321ET
   Subsystem 5 - Part No SW: -----------    HW: 480 401 604 16
   Serial number: 3550002A920178D4029.
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: -----------
   Component: PedP_Sensor_D  --- ----
   Serial number: -------------------$
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Component: PedP_Sensor_P  --- ----
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Component: PedPSensor_D2  --- ----
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Component: PedPSensor_P2  --- ----
9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1A [137] - Resistance Too Low
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:00:41
          B1006 1B [137] - Resistance Too High
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:00:41
9450005 - Pedestrian Protection Crash Sensor (driver's side)
          B1032 15 [137] - Open or Short to Plus
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:00:43
9450261 - Pedestrian Protection Crash Sensor (passenger's side)
          B1033 15 [137] - Open or Short to Plus
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:00:43
9735445 - Pedestrian Protection Crash Sensor 2; Driver Side
          B148D 15 [137] - Open or Short to Plus
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:00:47
9735701 - Pedestrian Protection Crash Sensor 2; Passenger Side
          B148E 15 [137] - Open or Short to Plus
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:00:47
   Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 29051604400438
   Coding: A418
   VCID: 7F5BFF7CB779F0EFB0D-802A
   Part No SW: 8V0 920 872 J    HW: 8V0 920 872 J
   Component: KOMBI         H03 6423
   Coding: 07240C182B8000080103A8101200000000000000
   VCID: 44D1B0909E1F5337ADF-8010
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3245
   Revision: --------    Serial number: 10051610802110
   Coding: 0201001726F200005B001208580000000001010100010000000000000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 48C9A4A0A2377757417-801C
   Subsystem 1 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 14 05 2016  D0042036
   Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
   Serial number: 7709298203
8526354 - Generator
          P1B01 00 [008] - Electrical Malfunction
                    Reset counter: 82
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:04:47
                    Supply voltage: Terminal 30: 10.7 V
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 82
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:03:18
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 8S0 857 511 C    HW: 8S0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 0202000700000000000001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 392FD164E9DD1EDFCE9-806C
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
   Component: EBKV          H14 0182
   Serial number:   085430010181
   Coding: 03720100331902030002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
   ROD: EV_BrakeBoostBoschMQBOMG_003_AU37.rod
   VCID: 4FFB8FBC4759A06F00D-801A
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861250416183804
   Revision: 00000000    Serial number: 16000091266010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E050CEBFE3B71DF-8060
   Serial number: 050516EE123163
   Coding: 00109F204000040000001002
   VCID: 43D3B38C9B11540F945-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: C106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D7AD9495256A3FBA1-8010
11776 - Supply voltage
          [Warnung vor dauerhaft zu geringer Versorgungsspannung Anzeige von Unterspannung]
                    Reset counter: 82
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:06:34
                    Motor status: 00
                    Supply voltage: 10.50 V
                    Temperature: 9.0 °C
                    KFC: 2E
                    KFA: 00 00
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 10.70 V
                    uAdSensI_SwitchedKl30_xdu16: 10.72 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
   Component: VW370P3815010 H07 4492
   Revision: 00H07000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM09550115G0907080D 001018
   ROD: EV_DMCM09550115G0907080D.rod
   VCID: 2809042002779757A17-807C
   Serial number: 080516EE717088
   Coding: 001097204000040000001002
   VCID: 42DDB688840B5D079F3-8016
   Coding: 011A000001000000
   VCID: 75B71D548545BABFEA1-8020
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
                    Reset counter: 42
5277205 - Positioning Motor for Headlight Range Right
          C1086 15 [137] - Open or Short to Plus
                    Reset counter: 42
   Part No SW: 8V0 035 842 C    HW: 8V0 035 842 B
   Component: MU-S-D-ER     042 0461
   Serial number: A7E01904160151
   Coding: 01730300FF0A000011111101000A02002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 372BD75CDFC908AF38D-8062
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9GY30JCSE
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: ALJAL123031600020051
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0715
   Coding: 0173930110949A0100F800000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 915 182 E    HW: 5Q0 915 182 C
   Component: BECM          H05 1101
   Serial number: U1180034
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006042
   ROD: EV_BECM09620115Q0915182.rod
   VCID: 3537DD54C5C5FABF2A1-8060
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
   Component: BJB  H27 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0481
   Serial number: V013C1612630390
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0481
   Serial number: V013C1612630386
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0481
   Serial number: V013C1612630392
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0481
   Serial number: V013C1612630385
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0481
   Serial number: V013C1612630209
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0481
   Serial number: V013C1612630389
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0481
   Serial number: V013C1612630268
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0481
   Serial number: V013C1612630396
26623 - Crash Shut-Down Activated
          P1609 00 [167] - -
          [Diag_F_Crash_ShutOff_CAN]
                    Mileage: 55802 km
                    Date: 2019.09.20
                    Time: 15:51:12
                    Pack Voltage: 352.0 V
                    Pack Current: -0.10 A
                    Isolation Resistance: 5080 kOhm
                    Maxumum charge current limit: 0 A
                    Maximum discharge current limit: 0.0 A
                    Contactor Voltage: 328 V
                    OBD unlearned counter: 40
                    Crash status: 01
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 00
                    (Plus) Contactor Status: 00
                    Terminal 15 status: 01
                    Max Cell Temperature: 17 °C
                    Min Cell Temperature: 16 °C
                    Air inlet temperature: 23 °C
                    Air outlet temperature: 21 °C
                    LV Battery Voltage: 15.1 V
                    Min.cell voltage: 3.668 V
                    Max.cell Voltage: 3.674 V
                    Max.cell SOC: 48 %
                    Min.cell SOC: 47 %
                    Hybrid Battery Pack Remaining Life: 47.8 %
                    Max Charge Pack Current(10s duration): 73 A
                    Max Discharge Pack Current(10s duration): 40.5 A
                    Max Pack Voltage(10s duration): 360 V
                    Min Pack Voltage(10s duration): 344 V
                    Max.cell Voltage(10s duration): 3.760 V
                    Min.cell Voltage(10s duration): 3.599 V
                    Accelerator Pedal Position D: 14.5 %
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 77 °C
                    Engine RPM: 0.00 /min
                    Vehicle Speed Sensor: 30 km/h
                    Ambient Air Temperature: 215 °C
                    Hybrid Battery Pack Remaining Life: 47.84 %
                    control module system voltage: 15.111 V
                    absolute load: 0.0 %
                    Time After Engine Start: 474 s
26624 - Crash Shut-Down Activated
          P1609 00 [175] - -
          [Diag_F_Crash_ShutOff_HW]
                    Mileage: 55802 km
                    Date: 2019.09.20
                    Time: 15:51:12
                    Pack Voltage: 352.4 V
                    Pack Current: 6.70 A
                    Isolation Resistance: 4140 kOhm
                    Maxumum charge current limit: 126 A
                    Maximum discharge current limit: 292.5 A
                    Contactor Voltage: 352 V
                    Crash status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 01
                    (Plus) Contactor Status: 01
                    LV Battery Voltage: 14.5 V
                    Max.cell SOC: 48 %
                    Min.cell SOC: 47 %
                    Vehicle Speed Sensor: 22 km/h
                    control module system voltage: 14.541 V
26721 - Proximity Sensing
          P0D59 00 [175] - Short to Plus
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:04:15
                    Pack Voltage: 350.9 V
                    Pack Current: 0.10 A
                    Contactor Voltage: 22 V
                    Crash status: 01
                    Fuse Status: 00
                    Max Cell Temperature: 0 °C
                    Min Cell Temperature: -1 °C
                    Air inlet temperature: 0 °C
                    Air outlet temperature: 0 °C
                    LV Battery Voltage: 10.7 V
                    Min.cell voltage: 3.654 V
                    Max.cell Voltage: 3.660 V
                    Max.cell SOC: 49 %
                    Min.cell SOC: 48 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0.0 A
                    Max Pack Voltage(10s duration): 350 V
                    Min Pack Voltage(10s duration): 350 V
                    Max.cell Voltage(10s duration): 3.660 V
                    Min.cell Voltage(10s duration): 3.653 V
                    Engine coolant temperature: -2 °C
                    Vehicle Speed Sensor: 0 km/h
                    control module system voltage: 10.716 V
                    Time After Engine Start: 0 s
27146 - Position Sensor for Battery Charger Coupling Lock
          P0DA1 00 [167] - Short to Plus
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:06:52
                    Pack Current: -0.00 A
                    Crash status: 01
                    Fuse Status: 00
                    LV Battery Voltage: 11.4 V
                    Max.cell Voltage: 3.659 V
                    Max.cell SOC: 49 %
                    Min.cell SOC: 48 %
                    control module system voltage: 11.489 V
   Serial number: 250416EDN09456
   Coding: 000097204000040000001002
   Serial number: 250416EDN01144
   Part No SW: 5QE 915 682 AA    HW: 5QE 915 682 AA
   Component: OBC KOSTAL    H61 3018
   Revision: --------    Serial number: 0804160D5000AW
   Coding: 115068203000
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
   ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
   VCID: 0C4158B0F6CFDB77A5F-8058
1054722 - Charging Socket A; Plug Locking Detection
          P31D5 00 [009] - Electrical Malfunction
          [Socket_A_Lock_Check_short_circuit_high]
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:06:51
14749440 - Charging Cover A; Locking Control Circuit
          P31CD 00 [009] - Electrical Malfunction
          [Socket_A_Lock_2_Check_disconnected]
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:23:11
1055490 - Charging Socket A
          P33E1 00 [009] - Electrical Malfunction
                    Reset counter: 42
                    Mileage: 55803 km
                    Date: 2019.11.29
                    Time: 15:04:14
End----------(Elapsed Time: 01:49, VBatt start/end: 14.2V/14.1V)-----------
Speculation: Is it possible that some of the other hard faults in the battery module need to be addressed first?
torehobb
Norway
C?ID=337383
Sorry about late replay
I have don som investigation about the problem.
Error. 26721 and 27146 was trigged when i disconnected the cabel from HV charcher and chargerport.
I reconnected the cabel and tryed to erase this errorcodes without any luck use vcds.
I had to use ODIS to fix the problem.
