Original brake controller stopped communicating, sent it away to a shop in Cali still came back not communicating. They sent me a used unit reprogrammed and now I have communication but dash lights still on and says incorrect coding. The people from Ross-Tech said there was one other car with my same ABS and ECU part numbers and they had the same coding. They asked me to post here for ideas. I can post pic of tag in trunk, vin, tire size etc if necessary. Thanks DC
VCDS-Lite Version: Release 1.2
Monday, 02 December 2019, 16:03:51:1374
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8N0 906 018 S
Component: 1.8L R4/5VT G 0007
Coding: 06600
Shop #: WSC 01236
VCID: 41F5C3595891
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit
P1432 - 35-00 - -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-00 - -
Readiness: 0010 0101
Address 03: ABS Brakes Labels: None
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
VCID: 3E0FB8A5296F
9 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
35-00 - -
35-00 - -
01312 - Powertrain Data Bus
37-00 - Faulty
00812 - Brake Pressure Release Solenoid (F84)
35-00 - -
62-00 - No or Incorrect Adjustment
49-00 - No Communications
16-10 - Signal Outside Specifications - Intermittent
00814 - Solenoid for Brake Pressure (N247)
Address 08: Auto HVAC Labels: 8N0-820-043.LBL
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 28237EFDDBEB
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8N8-909-601.LBL
Controller: 8N8 909 601
Component: Airbag Front+Seite 0005
Coding: 10102
Shop #: WSC 01236
VCID: F781ED81C6D5
Address 17: Instruments Labels: 8Nx-919-xxx-17.LBL
Controller: 8N1 919 930 B
Component: KOMBI+WEGFAHRS. M73 D30
Coding: 06244
Shop #: WSC 25061
VCID: 3803AEBD0B4B
Address 22: AWD Labels: 02D-900-554.LBL
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F3165218EA5
Address 35: Centr. Locks Labels: None
Controller: 8N
Component: Zentralverrieg. D04
Coding: 00000
VCID: 867F9045B13F
01559 - Drivers Door
61-00 - Won't De-Safe
01560 - Passenger Door
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Controller: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
VCID: 3D0DBFA92469
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 01236
VCID: E5BDB7C96C79
End
