2000 Audi TT Quattro 1.8T Brake Controller Replaced Says Incorrect Coding
Oswaldusa
Verified VCDS-Lite User
C?ID=367614
Original brake controller stopped communicating, sent it away to a shop in Cali still came back not communicating. They sent me a used unit reprogrammed and now I have communication but dash lights still on and says incorrect coding. The people from Ross-Tech said there was one other car with my same ABS and ECU part numbers and they had the same coding. They asked me to post here for ideas. I can post pic of tag in trunk, vin, tire size etc if necessary. Thanks DC
VCDS-Lite Version: Release 1.2
Monday, 02 December 2019, 16:03:51:1374
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77
Address 01: Engine       Labels: Redir Fail!
   Controller: 8N0 906 018 S
   Component: 1.8L R4/5VT     G   0007
   Coding: 06600
   Shop #: WSC 01236
   VCID: 41F5C3595891
18057 -  Powertrain Data Bus: Missing Message from ABS Controller
            P1649 - 35-10 -   - - Intermittent
17840 -  Secondary Air Injection Solenoid Valve (N112): Open Circuit
            P1432 - 35-00 -   -
16490 -  Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
            P0106 - 35-00 -   -
16622 -  Manifold Pressure / Boost Sensor (G31): Signal too High
            P0238 - 35-00 -   -
Readiness: 0010 0101
Address 03: ABS Brakes       Labels: None
   Controller: 8N0 907 379 E
   Component: ESP     20    CAN  V005
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E0FB8A5296F
9 Faults Found:
00283 -  ABS Wheel Speed Sensor; Front Left (G47)
            35-00 -   -
00285 -  ABS Wheel Speed Sensor; Front Right (G45)
            35-00 -   -
01044 -  Control Module Incorrectly Coded
            35-00 -   -
01312 -  Powertrain Data Bus
            37-00 -  Faulty
00812 -  Brake Pressure Release Solenoid (F84)
            35-00 -   -
00778 -  Steering Angle Sensor (G85)
            62-00 -  No or Incorrect Adjustment
            49-00 -  No Communications
01276 -  ABS Hydraulic Pump (V64)
            16-10 -  Signal Outside Specifications - Intermittent
00814 -  Solenoid for Brake Pressure (N247)
Address 08: Auto HVAC       Labels: 8N0-820-043.LBL
   Controller: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 28237EFDDBEB
00779 -  Outside Air Temp Sensor (G17)
            30-00 -  Open or Short to Plus
Address 15: Airbags       Labels: 8N8-909-601.LBL
   Controller: 8N8 909 601
   Component: Airbag Front+Seite 0005
   Coding: 10102
   Shop #: WSC 01236
   VCID: F781ED81C6D5
Address 17: Instruments       Labels: 8Nx-919-xxx-17.LBL
   Controller: 8N1 919 930 B
   Component: KOMBI+WEGFAHRS. M73 D30
   Coding: 06244
   Shop #: WSC 25061
   VCID: 3803AEBD0B4B
Address 22: AWD       Labels: 02D-900-554.LBL
   Controller: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 1F3165218EA5
01316 -  ABS Control Module
Address 35: Centr. Locks       Labels: None
   Controller: 8N
   Component: Zentralverrieg.     D04
   Coding: 00000
   VCID: 867F9045B13F
01559 -  Drivers Door
            61-00 -  Won't De-Safe
01560 -  Passenger Door
Address 45: Inter. Monitor       Labels: 8E0-951-177.LBL
   Controller: 8N8 951 177 A
   Component: Innenraumueberw.    D09
   Coding: 00001
   VCID: 3D0DBFA92469
Address 55: Xenon Range       Labels: 4B0-907-357-AUT.LBL
   Controller: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D003
   Coding: 00010
   Shop #: WSC 01236
   VCID: E5BDB7C96C79
End
Oswaldusa
C?ID=367614
VIN TRUUC28N6Y1015859
NostraJackAss
Vehicle Identification No.TRUUC28N6Y1015859
ModelAudi TT Coupe 1,8 qu.
ATT
Date of production08.08.1999
Model year2000
Sales type8N355N
Engine CodeATC
Transmission CodeDXW
Emission standard0GLEmission standard TLEV
PART NUMBERFOD!DESCRIPTIONREMARKMODEL
8N0907375E
Control unit for ABSLEGACY
8N0907379C
quattro
Oswaldusa
C?ID=367614
Control Module Incorrectly Coded So what does above mean please?
Oswaldusa
C?ID=367614
No sorry Im not a mechanic. But i think you might be saying 8N0907375E is correct module??? Not 8N0907379C
NostraJackAss
FOD WINS!
You have the wrong module installed sir, don't you see that and the replacement part number or possible legacy in green color are in bold aforementioned?
Oswaldusa
C?ID=367614
awesome thank you so much for your help....:)
Andy
Sector 7G
HC424490
Have you contacted an Audi dealership parts department with your VIN to see what part number they show for the ABS module?
Oswaldusa
C?ID=367614
John at Autotec In California disagrees says thats Incorrect and there is no way the car needs the controller you are stating and that the controller i have is FOD. If its the worng controller you are saying that someone switched the controller long ago and suddenly now its the wrong one??? if you look on the forum there are many other TT threads with same issue, They have the same controller as me. Just google my controller number.
Oswaldusa
C?ID=367614
yes and I have correct one
Oswaldusa
C?ID=367614
Actually he said they dont go by the abs module only for part number it is a diff part number sold WITH the pump but from what he could find I have the correct part.
NostraJackAss
TRUUC28N6Y1015859
Is it fixed yet?
Oswaldusa
C?ID=367614
No it's not they are trying to find me a correct code for the control module.
Oswaldusa
C?ID=367614
Yes it does.
